Old 09-15-2016, 12:04 PM   #21
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
True, but I think that sway control should still be used so you would end up with some WD anyway. The reason for Ford saying no WD is because the frame and receiver are so beefed up WD is not needed.
TinCan
graysailor is offline   Reply With Quote
Old 09-15-2016, 12:04 PM   #22
Elizabethtown , Kentucky
How fast do you guys tow? I stick to 55-65 and never need sway control. And doesn't your tongue weight determine the need for WD?
"Step away from the accelerator pedal" :-)
Just teasing fellas.
jacksd3 is offline   Reply With Quote
Old 09-15-2016, 12:08 PM   #23
albuquerque , New Mexico
Good question
Originally Posted by THEPILL View Post
So is it feesiable to use the W/D hitch and no sway bars?
Or just hook up to the (hitch)and go?
900lb tounge weight on my Airsteam is a lot.
If pulling an AS, why even question it? No such thing as "over kill", when it comes to towing our trailer! Peace of mind.....
splintair is offline   Reply With Quote
Old 09-15-2016, 12:16 PM   #24
Gainesville , Florida
You do not have to have a WD hitch to get sc. You can tow on the ball mount equipped with sway control balls on it.
Old 09-15-2016, 12:16 PM   #25
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Maximum conventional towing is increased to 21,000 pounds – 1,000 pounds better than the nearest competitors’ trucks and without the need for a weight-distributing hitch. Maximum conventional towing with F-250, with the all-new trailer tow package, and F-350 single-rear wheel are increased to a class-leading 18,000 pounds.
This is directly from that Ford brochure posted earlier.
Weight distribution may not be necessary.
Sway control may or may not be necessary.
The truck may have active trailer sway control with braking, but it seems like a sway control would be peace of mind.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-15-2016, 02:24 PM   #26
2006 19' Safari
East Greenbush , New York
You need weight distribution if the front end raises when the trailer is coupled. If the front end of the truck gets too high, you have steering control issues.
That's what weight distribution does, puts some if the tongue weight onto the frame, so that the back end raises and the front drops, giving back safe steering.
Sway control is another concern. Often handled by attachments to the hitch. Which is why folks get themselves all confused.
If the front end of the truck raises when hitched, use weight distribution to bring it down. Use sway control on longer trailers, so that you can maneuver safely in an emergency.
Matt
2006 Safari Bambi 19'
2017 Silverado LT Z71 Double Cab 1500
heitkergm is offline   Reply With Quote
Old 09-15-2016, 03:00 PM   #27
If you are lifting your front end on a truck that weights about 8k pounds then you are probably exceeding the tongue weight limit of your hitch. I see WD solutions for smaller TVs.
Sway control is a good thing for any load. But I still question if speed is the underlying issue. Excluding weather factors and/or an unstable load in the trailer.
Just my .02c
Old 09-15-2016, 03:16 PM   #28
Urbanologist's Avatar
2009 34' Panamerica
2008 22' Safari
Metro Detroit Area & Metro Dallas Area , Michigan & Texas
Your OWN photo tells a lot...
Your truck's nose is pointing to the sky due to the tongue weight at the hitch. You could use WD (and possibly sway control). I agree with other comments on this. Your truck manufacturers are NOT going to be behind the wheel should you get into a dicey situation on the hills and valleys. I also would consider speaking to Andy at CanAm RV (London Ontario, Canada) on this subject.
Urbanologist is offline   Reply With Quote
Old 09-15-2016, 04:09 PM   #29
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
I have a F350 and tow a 25 foot International.
I have the Equalizer hitch that transfers weight and sway control. For the price... it would be recommended in your case. As already pointed out, you are really sitting down in the back of your truck. If you read the instructions, on line, on what the weight transfer does... this would be my number ONE correction.
My older Equalizer with chains did not have any sway control. It tracked perfectly and the half ton truck was borderline for cargo load capacity. This was with a 23 foot Safari.
You may feel offended at first, but you might want to investigate your hitch and trailer setup. No sense having a serious 'learning experience' when it is inexpensive to purchase even a used hitch that will do the job.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 09-15-2016, 04:10 PM   #30
gecko's Avatar
2009 28' International
Pacific Palisades , California
Our Suburban had automatic load leveling and therefore "didn't need" weight distribution. Not so!
Our Sprinter van one-ton also call for no WD, and actually lowers much less under trailer tongue weight than the 3/4 Suburban with self leveling did. And it also has a sophisticated balancing system doing asymmetric braking. But we are much happier using our Equalizr (for both WD and anti-sway.)
I think you will be, too. Transferring load off your rear axle and putting it back inti the front will give you much more positive road contact in your steering wheels. And using mechanical antisway will take all or most if the sway out before your truck starts to correct. The combination for antisway should give you a rock solid ride that you won't have to think twice about.
Good luck, and please let us know what your decision and experience is.
gecko is offline   Reply With Quote
Old 09-16-2016, 12:55 AM   #31
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
We could probably get away with not having WD, but I believe our Blue Ox Sway Pro helps soften the AS ride hitched to our F350.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 09-16-2016, 05:10 AM   #32
Naper's Avatar
Loretto , Ontario
I have gone through the manual, There is a section on WD but nothing saying you don't need it.
Naper is offline   Reply With Quote
Old 09-16-2016, 06:38 AM   #33
m.hony's Avatar
2013 30' Classic
It's better to have it and not need it than to need it and not have it.
TAC #MS-10
Airforums #70955
Old 09-16-2016, 07:04 AM   #34
It's also bad to have it, need it, and used it, only to find out that having it, needing it, and using it made no appreciable difference at the accident scene.
Old 09-16-2016, 08:13 AM   #35
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
To begin, I think Ford SD is a good platform all around... This is not a "hating" reply. So..... What follows are simple "perspectives" on the preceding statements about the 2017's..
Just from the physics perspective, with rear axle as pivot point, hanging gear on the stern of any truck will move the opposite end of the lever... Just saying.
Running No WD would tend to transmit more undamped moments on both vehicles at the stern pivot (ball)..
Additional concern of mine would be brake friction component wear and some added tire wear. Imagine, just enough sway to activate the "sway control"... I would consider possibility of some smoking AS brakes at the end of the pull?... Ok, maybe not smoking, but a life expectancy impact.
Next, imagine intermittent (depending upon sway physics) SC induced braking loads transferred to our axle type... Ford ain't gonna fix or replace those.
As mentioned in the replies on links to "writer" and Ford SD forum discussion there is an issue with "rear squat" and headlight aim points.. That is just a fact (unless Ford has compensating managing headlight system).
From the Ford specs, the max tow with F-250 is with the Gasoline powered model...
Oh, they made significant changes to reduce pilot available room by 2 inches from door panel to center console.
Otherwise should like a good truck for towing (but from specs some models may not handle our Excella.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-16-2016, 08:34 AM   #36
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Just my .02c
My dodge 4/4 short box with 6.7 weighs 8800 with 4500 on the steer, with out the equalizer hitch the 31' classic will drop the rear thus raising the front...these are loaded weights...
Old 09-16-2016, 09:24 AM   #37
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Without even factoring in the tow vehicle itself, look at the rating of the hitch. My hitch says:
"Maximum 500 lb. tongue weight/5000 lb. trailer weight without weight distribution; Maximum 1000 lb. tongue weight/10000 lb. trailer weight with weight distribution." My 25' Airstream exceeds 500 lbs. tongue weight, so I always use WD and I also choose to use sway control.
Your truck maybe has the power to tow a semi-load of elephants, but if you're exceeding the rated capacity of the hitch you might have a failure. A failure while towing can obviously be catastrophic for you, but there may be liability issues if you injure (or worse) someone else or cause property damage.
For towing, it's the weakest link, or combination of weak links, that will be the issue. Cheap, underrated tires, poor brakes, improper hitch set up, improper load distribution, excessive speed, driver inattention, etc. can all come together in a bad way.
Attention to the details will keep you safer!
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 09-16-2016, 09:53 AM   #38
Alluminati's Avatar
St. Louis , Missouri
Simply this:
Measure the height of your front bumper with and without the trailer. Your truck will handle the load without WD. But in emergency handling, your steering is compromised if the nose is raised.
99.9999% of the time, you don't need seatbelts, but when you do, they can save your life.
The Morgans
1989 Avion 34VB
Alluminati is offline   Reply With Quote
Old 09-16-2016, 02:08 PM   #39
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by Caffeinated View Post
That doesn't actually come from Ford. It comes from an automotive writer who states that it comes from Ford. Until I see it coming from Ford...
Mike
From Ford:
"Maximum conventional towing is increased to 21,000 pounds – 1,000 pounds better than the nearest competitors’ trucks and without the need for a weight-distributing hitch. Maximum conventional towing with F-250, with the all-new trailer tow package, and F-350 single-rear wheel are increased to a class-leading 18,000 pounds."
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 09-16-2016, 02:16 PM   #40
dznf0g's Avatar
Oswego , Illinois
Originally Posted by DavidsonOverlander View Post
From Ford:
It's not worded very well...my take is that the first sentence covers a 350 dually...followed by factoids on the SRW 350 and 250s. It is a confusing statement at best.
-Rich-
NorCal : 2017 Olema Spring Rally April 7-9, 2017 (formerly at Casini) HootMon-Frau Forum Rallies & Meet Ups 14 04-01-2017 01:46 PM
2017 Ford Super Duty paiceman Tow Vehicles 13 08-07-2016 09:37 PM
2017 Ford Super Duty Review pappy19 Tow Vehicles 15 03-06-2016 06:59 PM
