Old 09-15-2016, 08:10 AM   #81
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Cummins 6 in a row, makes 'em go!
GCinSC2 is offline   Reply With Quote
Old 09-16-2016, 06:10 AM   #82
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
If in we need more hp and torque , we'll use the KW with 500 hp Cat and 1850 ft lbs of torque....
Old 09-16-2016, 07:25 AM   #83
r carl's Avatar
Lin , Ne
Originally Posted by THEPILL View Post
Update:
2017 Ford Superduty numbers are in...
440 HP 925 lbs torque.
Hello?.........( crickets)....
Sounds like a tire eater to me.
Old 09-16-2016, 08:03 AM   #84
Anna Maria , Florida
I recently looked at a 2017 Ram 2500 Laramie with most of the goodies on it.
However payload 1,900# and in comparison to the 2017 F-250 it is one ugly duckling. I would be embarrassed hooking my beautiful AS behind that thing.
The F 250 also comes with a power step which is awesome for old folks.
franklyfrank is offline   Reply With Quote
Old 09-16-2016, 08:55 AM   #85
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Did that have the grill with the two large openings on each side of the "RAM" logo. Yes, I don't like it at all. I have a 2015 2500 Cummins Big Horn SLT and it only has 2089lbs payload. Doesn't have the bling of the Laramie.
Kelvin
Old 09-16-2016, 09:11 AM   #86
Vintage Kin
Fort Worth , Texas
Aftermarket custom grill will solve that.
Old 09-17-2016, 09:43 AM   #87
Kelvin
On a serious note, I did look and test drove a 2017 -2500 Ram Laramie with the Cummins and I actually liked it. However when I learned more about its specs I was disappointment. Especially the payload. At 1990# in comparison to the 3350# of the F-250 Lariat fully loaded it was puny. And the price believe it or not was withing a few hundred dollars. My current F-150 I load to about 1800# and I could use more capacity and that is why I am considering going to a 3/4 ton.
Old 09-17-2016, 10:19 AM   #88
Thiss's Avatar
1971 27' Overlander
2023 28' Flying Cloud
Monmouth , Oregon
Going to a 3500 gets you one ton payload. It also adds a limited slip diff and towing mirrors. Beauty is in the eye of the beholder. I think the Ford grill is pretty ugly. I agree on the Laramie grill being not so attractive though too. I opted for the lowly black Tradesman, but with my body color being the Maximum Steel Metallic it also mimics the far more expensive "Black Out" option on the Big Horn.
“Let’s be careful out there.”
Thiss is offline   Reply With Quote
Old 09-18-2016, 11:54 AM   #89
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
F250 To Ram Cummins
We just traded our 2011 F250 Lariat with 26,000 miles for the 2016 Ram Laramie 6.7 Cummins Diesel with 2250 max payload. It also has the side Ram Boxes. Not sure what the complaints about looks are but we think the grill is rather attractive. Yeah, the 250 was pretty, but that doesn't get you down the road when the engine problems start popping up.
Note: Can't get the two photos to rotate
ID:	271915   Click image for larger version
Silverbee is offline   Reply With Quote
Old 09-18-2016, 12:03 PM   #90
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
2011 f250 with 26,000 miles? Diesels need to be worked.
I just traded my 2011 f250 with 125,000 miles with no issues or problems and got the NEW 2017 F250.
440HP 925lbs of torque.
https://i52.photobucket.com/albums/g...h_postcard.jpg
Tow Vehicle" 2023 F250 Azure Gray!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 09-18-2016, 05:15 PM   #91
Silverbee's Avatar
2007 20' Safari SE
Well I do have a '64 Chevy Fleetside 283 V8 with 109,000 miles.
ID:	271960   Click image for larger version
Old 09-18-2016, 07:29 PM   #92
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have a 2007 Tundra with 55,000 miles.
I thought that was low miles till I ran across a guy with a 2006 Tundra with 43,000 miles.
My boss has a 2001 Jeep Wrangler with 26,000 miles.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-20-2016, 06:38 PM   #93
2016 27' Flying Cloud
Quebec , Quebec
Images: 8
Looks very nice. I own a 2016 Denali HD with Duramax and the RAM was on my shopping list.
Toutsi 1957 is offline   Reply With Quote
Old 09-20-2016, 09:48 PM   #94
Thiss's Avatar
1971 27' Overlander
Monmouth , Oregon
I just want to pause a moment and congratulate us all for making it to the 7th page of a thread about the big three diesels without getting it shut down. Good conversation folks!
Old 10-15-2016, 07:51 PM   #95
2016 30' International
Florence , Alabama
In case it hasn't been mentioned - last I checked Duramax were still putting the DEF filler under the hood which is idiotic. It should be next to the diesel filler.
joshjack is offline   Reply With Quote
Old 10-17-2016, 07:10 AM   #96
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Our 07 dodge 6.7 cumalong , big horn has 109,000, been coast to coast all with our airstream and never had any problems, traded it for a 2016 Laramie 2500, 6.7 , with 14000 miles today , we will see how these coil springs on the rear work out?
Old 10-17-2016, 07:41 AM   #97
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Where is the picture?....................
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 10-17-2016, 10:14 AM   #98
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
How ever shall we survive ...you can't check the oil from the diesel filler either ...
Old 10-17-2016, 10:56 AM   #99
r carl's Avatar
Lin , Ne
Can't put DEF in the diesel either.
Old 10-17-2016, 11:09 AM   #100
r carl's Avatar
Lin , Ne
Be careful you don't pull the frame out from under your trailer. Do you have to still pull off the cab on the 2017's to check the oil?
Duramax or Cummings Diesel? RivaHaven Towing, Tow Vehicles & Hitches 130 11-28-2015 06:24 AM
Ford 6.0 Powerstroke engine problems & fixes page.crow Tow Vehicles 15 10-29-2013 08:01 AM
Ford 6.7L Powerstroke nilesrob General Repair Forum 29 10-05-2013 02:28 PM
Anybody pull with stock Ford 7.3L Powerstroke diesel? JBCrete2 Tow Vehicles 15 08-07-2007 11:29 PM
'94-34' Cummings powered MH Tarheel General Motorhome Topics 1 06-10-2004 06:26 PM
