Old 11-02-2016, 06:16 AM   #127
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
The old Toyota landcruisers has straight sixes in them. We were never able to wear one out. Never even had to put a wrench one one. All had well over 200,000 miles.
One thing about them though, they got terrible gas mileage. My 4.0 jeep engine was the same. Ran great, but poor mileage. Is there something about a straight six that makes it bullet proof, but fuel innefficient? I have no clue.. Sorry, I'm also way off topic. I don't know if I'll ever go to a diesel. Just seems like too expensive to maintain. I like to keep a vehicle for a long time.
Jeff
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 11-02-2016, 07:22 AM   #128
dznf0g's Avatar
Oswego , Illinois
One thing about them though, they got terrible gas mileage. My 4.0 jeep engine was the same. Ran great, but poor mileage. Is there something about a straight six that makes it bullet proof, but fuel inefficient? I have no clue.. Sorry, I'm also way off topic. I don't know if I'll ever go to a diesel. Just seems like too expensive to maintain. I like to keep a vehicle for a long time.
Jeff
Yes there is...and I am not knocking them at all. I also had an FJ40. That six's design and rights belonged to GM. The old Chevy 235. Toyota purchased the rights and design because the 235 was used very heavily, globally, in everything from tractors to trucks and construction equipment. Smart move on Toyota's part, as many brands of parts bolted up to it and scavenged parts could literally be found in the middle of the desert.
A six cylinder has very long crankshaft, rods and camshaft. As such they have a lot of rotating and reciprocating mass. That spell out a fuel economy penalty. Also they have a very long block and a much greater quench area. (the amount of surface area for heat to escape from the combustion chambers to the cooling system). That spells out much more waste heat escaping to the atmosphere and not used for motion. Another fuel economy penalty.
But the ability of a tall block and long crank throws allows for a longer piston stroke, and thus more torque capability out of an inline engine per cu. in. of displacement.
Now, mind you, those are the mechanicals. Modern electronics and fuel delivery components can "cheat" the physics somewhat, but the physics still applies.
-Rich-
Old 11-02-2016, 11:10 AM   #129
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Ford Powerstroke VS Duramax and Cummings
4.0L in our 2001 2WD XJ Cherokee capable of 20+ mpg at around 65-mph. EFI really made a difference.
The other straight sixes I've had weren't quite thirsty, but never quite economical, either. They were meant to be cast iron reliable. That usually means FE takes a hit as the mechanical fuel delivery was as unsophisticated as possible for a given era.
1990 35' Silver Streak
2004 555 Cummins
Hensley Arrow. 9-cpm solo, 15-cpm towing
slowmover is online now   Reply With Quote
Old 11-02-2016, 11:19 AM   #130
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I've often heard the awesome 5.7 engine in my Tundra was bought from GM- the old 350- not sure how true it is. Worth a Google search I guess.
Apparently it is a myth that GM sold their 5.7L design to Toyota as the 2 engines are completely different.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 11-02-2016, 12:54 PM   #131
dznf0g's Avatar
Oswego , Illinois
Myth....!
-Rich-
Old 11-03-2016, 07:39 AM   #133
GettinAway's Avatar
Haha! 2500 HP!
Thanks dvzf0g, for the info on the old Landcruiser in line six. I had always heard it came from a GM design, but was made with tighter tolerances. Not sure about that last part.
We used to pull our huge pop up with a older Landcruiser. Two canoes on the roof of the cruiser, five bikes on the pop up, and grossly overloaded. I'd have a tough time holding 2nd gear going over some of the Colo passes. Just used to torture the engine and transmission. Took it over Imogene pass one day. Went anywhere, but we didn't drive by many gas stations without stopping. Ha
2011 FC 23FB
Old 11-03-2016, 09:05 AM   #134
dznf0g's Avatar
Oswego , Illinois
Haha! 2500 HP!
I don't know about the "tighter tolerances" part. The 237 (Toy had a slightly different head design which gained 2 Cubes over the out of production Chev 235) rattled like an old sewing machine....but was absolutely bullet proof, as was the 235.
I do know that Toyota's castings had a higher nickel content than the 235, and arguably had more resistance to wear in the cylinders than the 235. Valves and valve seats were a common issue with the LC though. Fortunately, I was then in my "advanced engines" class at the time and had full access to the university shop and machine shop. That was at about 70K. Normal for that generation of LC.
-Rich-
Old 11-03-2016, 06:29 PM   #135
abone's Avatar
2017 27' International
Richmond , British Columbia
My brother and I each had twin '74 FJ40's, same colour, identical trucks when we were in our early 20's. Man we had fun with those trucks, they were beasts.
We both had to do the valves at around 40,000 miles, rust issues and poor fuel economy. Wish we still had them, they are collectors trucks now.
2017 27FB Intl Sig
2017 F350 Super Duty
abone is offline   Reply With Quote
Old 11-03-2016, 09:18 PM   #136
dznf0g's Avatar
Oswego , Illinois
Yup, mine was a 73. Pulled a lot of big blocks out of the mud holes with that "little engine that could" Rust was horrible. By 60k, there were holes in the rear 1/4 's. Let in a lot of exhaust fumes.
-Rich-
Old 11-04-2016, 05:41 AM   #137
edmonton , Alberta
Lackluster payload, economy, power, towing capacity and high price-
The Titan has never been a game changer or even in the game- not even a player.
Extremely disappointing news about the new cummins in the titan. The Gas version of the HD titan actually out performs the diesel in almost every category with only about a 10% loss in fuel economy. That isn't all that bad as diesel seems to average a high cost over the last 10 years. I do know that the gm's have always been consistently the best in one performance category for over a decade and that is in going downhill. They have engine braking down to an art.
If you look at the cost factors of purchasing and owning a diesel truck it really doesn't make sense, so why do people buy them to pull around a realtively light airstream. It's about percieved performance, comfort and of course image. If you look at a corvette as a car, it gets poor mileage, it can get hung up pretty easy because it's low to the ground, it's noisy, has really crappy storage and if the one leaf spring breaks in the rear suspension your toast. Funny they still sell lots of them.
I would definitely buy a 3/4 ton diesel if I had the money, they are much quieter underload, are heavier so less of the tail wagging the dog, easier downhill in the braking dept. and are mighter in the numbers racket.
lostcomma is offline   Reply With Quote
Old 11-04-2016, 06:21 AM   #138
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Originally Posted by lostcomma View Post
If you look at the cost factors of purchasing and owning a diesel truck it really doesn't make sense, so why do people buy them to pull around a relatively light airstream. It's about percieved performance, comfort and of course image.
As to your last sentence: NO, YES and NO.
I bought my particular truck because it was engineered to do the job for which it is being used - mainly towing and hauling duties plus long trips. It is comfortable enough that I would much rather drive it than a car.
There is no perceived performance about it. Braking - while a diesel 3/4 ton has the same brakes as a gas 3/4 ton the diesel will control the load with the use of the exhaust brake and much less use of the service brakes. Acceleration for merging into traffic and maintaining on hills - diesel torque makes the drive easier and safer - I can merge in heavy traffic, keep up with traffic without being a hinderance or pass a slow truck on an incline.
A gas truck will pull any Airstream trailer made just fine but the diesel truck will out perform in every category as the load gets bigger. Less than 27' AS go gas 1/2 ton - larger than 27' go diesel if you can swing it.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-07-2016, 06:55 AM   #139
2016 27' Flying Cloud
Quebec , Quebec
Images: 8
You are absolutely right a diesel is more expensive to drive and buy than a gas engine if you do less than 25000 miles a year. If you can afford a Diesel go for it. If you do more than 25000 miles think about it. If you do more than 30000 miles a year, go for it.
Toutsi 1957 is offline   Reply With Quote
Old 11-25-2016, 04:14 PM   #140
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
All those miles you listed, especially saying that 30,000 miles a year warrants buying a diesel, is silly. Today's gas engines can go 200,000 with no problem with decent maintenance. In actuality diesel engines start having their own problems after their 100,000 mile warranty runs out. Many things start to go bad that are very expensive on a diesel. Gas engines don't have much to go bad other than spark plugs or a water pump. Again, you don't need a diesel to haul your Airstream, you just want one.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Duramax or Cummings Diesel? RivaHaven Towing, Tow Vehicles & Hitches 130 11-28-2015 06:24 AM
Ford 6.0 Powerstroke engine problems & fixes page.crow Tow Vehicles 15 10-29-2013 08:01 AM
Ford 6.7L Powerstroke nilesrob General Repair Forum 29 10-05-2013 02:28 PM
Anybody pull with stock Ford 7.3L Powerstroke diesel? JBCrete2 Tow Vehicles 15 08-07-2007 11:29 PM
'94-34' Cummings powered MH Tarheel General Motorhome Topics 1 06-10-2004 06:26 PM
