Old 12-21-2013, 07:30 AM   #43
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Nice choice. Congrats. We had the Flex in our sights ever since we decided to replace the Suburban. We drove them twice, and liked most everything but the price. Of the few cars on our list, it was the most expensive. At the time, we were going to go with the eco-boost, which added almost $5k to the prices because they came only in the Limited model. Very nice car!
We ended up going with the Chrysler 300S, after a final duel with not the Flex, but rather the Edge. Nice to see someone has gone with the Flex so we can gather reports on it! I am sure it will be a great tow car for you. I can't wait to hear about your experience with it. Good luck!
mstephens is offline   Reply With Quote
Old 12-22-2013, 08:34 PM   #44
Ottawa , ON
Way to go, Steph! I LOVE that car, it looks sooo cool, and rides like a limo (a good limo).
Did yours come with the two glass roof openings? I thought from the beginning that those would be fantastic on a long trip, seeing almost 360* around the car.
It's white, right? Nice.
Old 12-22-2013, 11:05 PM   #45
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Silver, actually, so it will match the trailer It doesn't have the big roof openings, I think those would have been pretty cool too, but you know how it is when you buy used you have to take what you get!
Stephanie
Old 12-23-2013, 06:32 AM   #46
andreasduess's Avatar
1984 34' International
Toronto , Ontario
I recently had the opportunity to drive a Flex as a rental car. I loved it. Powerful, smooth and well put together.
Let us know how you like the towing experience.
andreasduess is offline   Reply With Quote
Old 12-26-2013, 10:34 PM   #47
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
We are still figuring out all the goodies on this car. Heated seats, TPMS, keyless entry, it's just loaded. Here's a picture of it in the driveway next to the soon to be retired van. The Flex is about a foot shorter in length, and in height, and It must be at least 8 inches shorter in width, at least it feels that way inside. I'm really happy with the size.
ID:	202394   Click image for larger version
Stephanie
Old 12-27-2013, 08:19 AM   #48
mstephens's Avatar
Nice comparison photos. Tells a story!
Old 05-21-2014, 06:44 PM   #49
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
All hooked up
We just got our rig back from RV Pro in Vancouver, WA, and they set us up with a nice WD hitch, got it all leveled out, and showed us how to hitch up. Because of the unusual arrangement of propane tanks and spare tire on our tongue they had to weld a plate on and fasten the snap up hooks to that. We got 550 lb bars which was the lightest they could get.
Dave drove it home and I followed him in the van. It looked good, and he said it felt good except he felt like he was more connected than he had been in the van. That might be because of the softer suspension, the van had a very stiff rear suspension. Might just be because of the connection through the new hitch. Either way it seemed to do just fine on the road and highway and neighborhood speedbumps, so I guess we're ready for our first trip this weekend.
Edit: Oh, and we can open the rear door with the trailer hitched up, which was a nice surprise.
ID:	212455   Click image for larger version
Stephanie
Old 05-22-2014, 08:14 AM   #50
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Stephanie
I am surprised how much your receiver has twisted up. It is not likely a problem but just check the attachement points and make sure they are not stressing.
It would be good to take your shank to a machine shop and have a new hole drilled in it so you can slide it in the rest of the way. This will reduce strain on the receiver and make it more stable. You should still be able to open the tailgate. Your ball mount could use some additional reward angle. If it has washers on a pin just add a couple more.
I hope this helps.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 05-22-2014, 12:40 PM   #51
Ottawa , ON
Andy, did you mean "rearward"? Just checking.
Old 05-22-2014, 12:49 PM   #52
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Thanks for the tips Andy, I'll check it out. I believe they drilled a hole to get it closer to the car by about two inches, but still clear the crank. I'll check it out when we get it hooked up tonight.
Question about the friction sway control - previously I had been told to just tighten it a bit, and then tighten it more if it sways. Of course it's never swayed. Well with this install they told me to crank it down as tight as I can get it. They had it damn tight, I had to use a pipe on the handle to get enough leverage to turn it down and remove it. Any advice there?
Edit: No, I was totally wrong, they did not add another hole to the move the ball closer, I'll definitely look into that after this trip.
Stephanie
Old 07-07-2014, 02:37 PM   #53
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Took a longer trip with the Flex this weekend, finally hit some freeways with semi trucks blasting by occasionally, it towed perfectly. Had a really comfortable trip. Absolutely no complaints. After such a long and daunting search for a tow vehicle, I think we really got the perfect one for our little trailer. This is at Ocean Breeze RV Resort in Ocean City, WA, and at the abandoned Satsop Nuclear Power Plant in Elma, WA, and of course one on the road because I needed a new avatar pic
ID:	215884   Click image for larger version
Stephanie
Old 07-07-2014, 04:36 PM   #54
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Not to thread hijack, but I love your photo in front of the coolant tower.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 07-07-2014, 04:51 PM   #55
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Thanks, if you ever get out here, the site is fairly open to visit and explore. Not a destination, but certainly worth seeing if you're nearby. It is a plant that was never completed, and turned into a business park. It's quite a sight!
Stephanie
Old 07-07-2014, 05:00 PM   #56
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Just a bit more evidence, spent 2 weeks going through ND, SD including Rushmore and Custer and Neb,Ks. etc, 3800mi. in all w/o a blip from the '12 Flex or the '66 Safari... averaged 12.8 mph while towing.
goshawks00 is offline   Reply With Quote
SOB body flex FordTruck On The Road... 7 02-11-2008 05:55 PM
LP flex line quality walter1 LP Gas, Piping, Tanks & Regulators 0 08-21-2007 11:17 PM
Flex in Floor - 71 Overlander Ganglin Repairing/Replacing Floor &/or Frame 10 09-26-2006 08:09 PM
Flex Fan vs Electric?? GlenCoombe Mechanics Corner - Engines, Transmission & More... 9 10-09-2005 12:50 PM
Are flex lines best? 63air Plumbing - Systems & Fixtures 1 08-10-2005 10:18 PM
