Old 09-17-2014, 05:21 PM   #99
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
hi from AZ. . . my '11 Ecoboost FX4 blah-blah, is getting 14+ towing (65 mph ave) & nearly 20 without AS. I've added the Heartthrob cat back exhaust & the Banks Ram-Air intake system. I'm pretty happy with the Truck (still). . . regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 09-17-2014, 05:37 PM   #100
2016 28' Pendleton
Hi again from AZ. . . let me add that I use premium when towing. Also, I was temporarily seduced by the Ram 1500, with the Italian diesel & the German automatic, but the reality of $61k including state sales tax, helped remind me how much I like my '11 EB . . . regards, Craig
WBCCI 2851,4CU
Old 09-17-2014, 06:00 PM   #101
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
I listed the optional Trailer tow for 2015
In 2015, the Huge trailer tow mirrors are avail with any Trailer Tow pack....
Power-folding, PowerScope@ Telescoping, Power Glass Trailer Tow Mirrors with Heat, Turn Signal, Memory, Auto-Dimming Feature (Drivefs Side), High-lntensity LED Security Approach Lamps, LED Side-mirror Spotlights and Chrome Skull Caps (req. 53A Trailer Tow Pkg. or 53C Max Trailer Tow Pkg.)
* CLASS IV TRATLER HTTCH (538) Usge: Required for towing up to 5,000 lbs. Availability:
. Optional on XL Base and Mid, XLT Base . lncluded in XLT Mid and Luxury
Standard on Lariat, King Ranch and Platinum
. 4-pin/7pin wiring harness
. Class lV trailer hitch receiver.
Smart Trailer Tow Connector
TRAILER TOW PACKAGE (53A)
Usage: Required for towing over 5,00O lbs
Availability:
. Optional on XL, XLT, Lariat, King Ranch@ and Platinum lnctudes:
* = New for this model year
Includes:
. 4-pin/7-pin wiring hamess
. Auxiliary transmission oil cooler
. Class lV traaler hitch rmeiver
. Engine oil cooler (3 5L V6 TiVCT only)
. Smart Trailer Tow Connector
. Upgraded front front stabilizer bar
Max Trailer Tow Package (req. 3.5L V6 EcoBoost@ engine)
MAX TRAILER TOW PACKAGE (53C) Usge: TBD
Aveilabitily:
. AII Series
Not available with:
. 2 7L V6 EcoBoost Payload Pkg. (622)
Reguires:
. 3.51 EcoBoost@ Engine (99G)
lnctudes;
. 3.55 Electronic-locking rear axle (axle is changed to 3.73 Heclrcnic-bcking differential if
odered with Heavy-Duty Payload Pkg. (627))
. 4-pinr/-pin wiring harness
. Class lV trailer hitch rmiver
. Smart Trailer Tow Connector (standard on Lariat and higher) . lntegrated Trailer Brake Controller
. Upgraded frcnt stabilizer bar
. upgraded rear bumper
FX4OFF-ROAD PACKAGE (55A)
Avaitabitity:
. Opt on XL, XLT, Lariat, King Ranch@ and Platinum (4x4 only) Not avaitebte with:
. 3.51 TFVCT engine (998)
Requirc:
. 4x4
tncludes:
. 3.31 Electronic-locking rear axle with or 5.01 V8 engine (99F) or 3.51 V6 EcoBoost@
engine (99G) (axle is changed lo 3.73 Electronic-locking diffeenlial if ordeed wtth Heavy-
. 3.55 Electroniclocking rear axle with 2.71 V6 EcoBoost@ (99P) (axle is changed lo 3.73
Electrcnic-locking differcntial it odered with 2.7L V6 E6Bo6t@ Payload Pkg. (622)) . 4x4 "FX4 Off-Road" de€l
. Hill Descent Control
. Off-Road tuned shock absorbers (front and rear)
. Skid plates fuel tank, transfer case and front differential
Optional Equipmenl:
. LT245/7OR17E BSW all-terarn tires (A/T) (T7C) (XL and XLT only) *
. LT275/65R18C OWL A/T (T8C) (Lariat and King Ranch@, or XLT w/868 XLT Chrome
Appearan@ Pkg. or 862 XLT Sport Appearance Pkg.)
LaBigDogs is offline   Reply With Quote
Old 09-17-2014, 06:29 PM   #102
LaBigDogs's Avatar
The only difference between the Tow Package
and the
Max Tow on the Platinum with the FX4 Off Road Package is...
3.55 Electronic Locking Rear axle on Max Tow Package
3.31 Electronic Locking Rear axle on Tow Package with FX4 Off Road Package
Upgraded rear bumper on Max Tow Package...
Other than that they are the same.
Old 09-17-2014, 10:03 PM   #103
1998 30' Excella 1000
Livingston , Texas
LaBigDogs, do you know if that "upgraded rear bumper" is actually part of the hitch? Seems I read a few years ago that it was, and therefore one could not easily replace the OEM hitch with an after-market hitch.
Siegmann is offline   Reply With Quote
Old 09-18-2014, 05:41 AM   #104
LaBigDogs's Avatar
Siegmann, not sure on the bumper, I have it on my 2013, but will not on my 2015... I don't think it has anything to do with the hitch, I will check today I have a 2011 without and a 2013 with.... on the 2015 I got the Tow Package with the 3.31
Old 09-18-2014, 07:41 AM   #105
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I think Max Tow also comes with an uprated front sway bar as well. In past years, there's been a modest increase in the GVWR associated with Max Tow as well, but it's never been set out as a part of the package in the description, you can just see if when you look at the payload selector. Unless they add more positions than they have placeholders for in the 2015 Ordering Guide, it this may not be true for 2015. While almost all the GVWRs show as "TBD" in the early version they released, there are fewer positions for different permutations.
David
Old 09-18-2014, 08:00 PM   #106
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
F150 eb
All good stuff! Thanks! My only comment is we like the ride better on the 4X4 much better for all our driving versus the Off Road package...drive both, and see which you prefer. We don't like the larger tow mirrors from Ford...the clip on trailer extension to stock mirrors on our Platinum work fine; they are smaller and are easy on/off when needed. I will also try premium fuel when towing going forward. If I had my wish list, I think an 8 speed would be nice match with new model...could possibly get to 15MPG towing??....
Old 09-19-2014, 09:34 AM   #107
LaBigDogs's Avatar
I have used premium fuel many times to test, and the it's all the same as cheap gas... so my EB's love them some cheap gas, and I am cool with that.
Old 09-19-2014, 07:21 PM   #108
Livingston , Texas
laBigDogs, did you get a chance to check if the "upgraded rear bumper'" is integral with the hitch?
Old 09-19-2014, 08:27 PM   #109
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I'm really curious to see the full specs and hear the real life experience on the new 2.7L engine for MPG and capabilities. On paper that motor is nearly as powerful as the 3.5 and appears to be technically more advanced. I think Ford is giving it a 8500lb tow rating, good enough for most Airstreams.
kscherzi is offline   Reply With Quote
Old 09-20-2014, 09:56 PM   #110
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 34
F150 EB Hill Climbing Question
This is a great thread, lots of useful info.
I have a question. I'm planning on buying a new TV in the next 12 months, maybe sooner. One option is an F150 w/ the 3.5 EB engine. The other is a Chevy 2500 diesel.
We tend to take extended trips.
When you EB owners are pulling a 27 FC Airstream, or similar weight model, up a long 5% or greater grade, what engine RPM are you seeing? Do you have any problems with overheating?
I kind of get the impression the a 27' Airstream might be in the upper quadrant of the 150 EB practical towing range. I realize my Airstream doesn't exceed the max tow weight, but my concern is about whether or not the engine is being stressed towing up grades and at highway speeds for extended periods of time.
I see the Duramax diesel as overkill; that's why the 150 EB is a consideration.
Thanks for your help,
Paul
As far as I know, this is the oldest I've ever been.
Road Geezer is offline   Reply With Quote
Old 09-20-2014, 10:21 PM   #111
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
The highest my transmission heat has been about 220 degrees after a long pull. The little down grades in between the pulls cools it down quite rapidly. I really am a conservative driver (slow) but I have felt no slow down on the upgrades. If you follow the speed limit you really won't notice any slow down on the upgrades at all. On the down grades the tow haul mode does most of the braking. The 2015's will be even better as they are 700lbs. lighter. No brainer...a diesel will be way over kill and with much higher maintenance costs.
TinCan
graysailor is offline   Reply With Quote
Old 09-21-2014, 06:52 AM   #112
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
My experience is nearly the same as grey sailor when towing my Serenity 28' with my EB - heading into the hills; I have no problem what-so-ever; the power is always there, even on short 10-degree climbs, to maintain speed or even accelerate. For me, the difference is in heading downhill, it takes tow/haul a bit longer to respond to the need to downshift than my concerns are able to handle. This is NOT a V8 or V10 engine compression capable machine, but it does work for me so far.
2011 Airstream International Serenity 28' - 30a/taupe
2013 Fors F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
2015 Ford Expedition with Eco-Boost Roadtech Tow Vehicles 16 02-24-2014 04:43 PM
