Old 09-30-2014, 08:59 AM   #141
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Read the fine print in the auxiliary Ford documentation.
When I was looking at Ford trucks, there was a nearly 500 pound decrement in useful load between the base trim and a King Ranch model that reflected all the "glitz" that gets added as the trim lines go up. There is a huge profit in all that "glitz" that is not doing anything to make a ½ ton truck a better towing maching, just more comfortable for the driver's backside.
Old 09-30-2014, 10:29 AM   #142
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
See it for your self and feel the power!
https://f150drive.com/events-home.aspx
LaBigDogs is offline   Reply With Quote
Old 09-30-2014, 10:39 AM   #143
Dobber's Avatar
2012 25' FB Flying Cloud
Queens , New York
<<adaptive cruise control system $1,250>>
what is 'adaptive' cruise control ?
"Common Sense is like Common Courtesy,
ain't neither one too common these days"
Dobber is offline   Reply With Quote
Old 09-30-2014, 10:44 AM   #144
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Cruise control that will slow down to match pace with traffic ahead of you if you're not paying attention, then speed back up to your set speed if/when the traffic clears.
— David
Old 09-30-2014, 06:16 PM   #145
LaBigDogs's Avatar
Did you say EcoBoost MAX TOW?
Ford Releases Towing and Payload Ratings for 2015 F-150 –Β*News –Β*Car and Driver | Car and Driver Blog
Old 09-30-2014, 09:04 PM   #146
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I have been searching for a new 2014 F-150 truck. I have made a few compromises to get as close as possible to what I want. No dealer near me has one in stock, but found one in another state. My problem/concern is the tow rating and payload of this vehicle. I need to see a picture of the door sticker showing the payload before I commit to buying this truck. I have the invoice and I have built one on line, but that sticker is the actual thing. I'm looking at a 2014 F-150 Eco-boost, crew cab, short bed, Max tow, Electronic locking 3:73 differential, 18" LT tires, off road package. Most everything else doesn't mean anything.
Here's the dilemma:
On line chat with Ford ...........Payload = 1560 lbs......Tow rating = 9,600 lbs.
From the dealer's sight where vehicle is located: Payload= 1700 lbs....Tow rating = 7,700 lbs.
From Ford sales brochure ......Payload = 1900 lbs (3) ....Tow rating = 11,200 lbs (3)
(3) means with "Max Trailer Tow Package Only"
Listed under "Super Crew 145.0" WB 4X2 / 4x4"
Now I know, or think that I know, These numbers aren't exact because different options weigh more and will reduce the payload, but I'm getting mixed signals on trying to find out the payload of this truck before I say yes to it.
Any thoughts from your experiences?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-30-2014, 09:47 PM   #147
N/A , N/A
Hi Bob,
Why don't you ask the dealer to snap a photo of the sticker on the driver's door and email/text it to you? You would then know the exact payload.
rostam is offline   Reply With Quote
Old 09-30-2014, 09:48 PM   #148
Lost in America
mojo's Avatar
2004 19' International CCD
Oak Creek , Arizona
Unfortunately everything else does mean something. Now, I have a a 2011 F150 with everything you describe above, so don't know what may have changed, but my truck was listed with a payload of 1960lbs. However what changes all that depends on what trim you go for, FX4, Lariat, Lariat Limited, Platinum, King Ranch, etc. These trim packages will very the payload. My Lariat with Max Tow & 20" wheels has a sticker a of 1760lbs, so that package with 4x4 cut 200lbs off the payload. Replacing the P rated tires with LTXL tires has raised the payload. But yes, the trim model you pick and 4x4 vs. 4x2 will affect the payload.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 09-30-2014, 10:41 PM   #149
Salem , Oregon
Images: 18
That's exactly what I asked for, but.....
Originally Posted by rostam View Post
Hi Bob,
Hi, the local dealer asked someone at the other dealer to look at the sticker, take and send a picture of it to us, but it has been two days so far.
I'm going on a trip in about a week and need to know if this is what I want or not.
2005 Safari 25-B
Old 09-30-2014, 10:48 PM   #150
Salem , Oregon
Images: 18
Xlt
Hi, yes I do know, but if something on this truck reduces the payload by a few hundred pounds, I'm OK with that. If a moon roof weighs 100 pounds more, then it will reduce the payload by that much. The point is, for me, that my Lincoln has a payload of 1600 lbs and if this truck is the same or lower, I don't want it. [note: I'm not getting a moon roof]
2005 Safari 25-B
Old 10-01-2014, 06:48 AM   #151
1981 31' Excella II
New Market , Alabama
Here is another article on the 2.7 Ecoboost. They don't make a truck I can afford so how cool it is does not really matter.
2015 Ford F-150 2.7 EcoBoost Four-Door Crew Cab Is Capable Of 23.5 MPG
Perry
Old 10-07-2014, 12:57 AM   #152
Salem , Oregon
Images: 18
New truck in my garage.
Hi, today we closed the deal and I drove home with a brand new 2014 F-150 XLT.
ID:	223864   Click image for larger version
2005 Safari 25-B
Old 10-07-2014, 05:30 AM   #153
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Very nice Bob
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 10-07-2014, 08:16 AM   #154
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Looks like a keeper!
Are you going to put a camper shell on, tonneau cover or leave the back open?
My sister has a similar truck and it is nice except for one thing. Ford made the bed sides very deep so it is tough to get anything out of the bed....... I think they did this so the cab doesn't look so high.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
2015 Ford Expedition with Eco-Boost Roadtech Tow Vehicles 16 02-24-2014 04:43 PM
