Old 09-26-2014, 10:03 PM   #127
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
Three Grand
Originally Posted by DC Bruce View Post
@Road Geezer
Check out the videos on "the fast lane truck" Thy run pickups up the 7-mile 7% grade on I-70 going east from Dillon, CO to the Eisenhower Tunnel at some 11,000 feet. They ran the Ecoboost pulling 10,000 lbs. up and down that grade and it did quite well: faster than either the Titan or the Chevy with the 6.2L ecotec, although thirstiest. As you would expect with a turbocharged engine's fat torque curve, RPM's were in the 3-4k range. Not as low as a diesel, but lower than the normally aspirated engines. Seems like it will be quite satisfactory.
Interesting. So you all are cool with 3000 -4000 RPM ?
What is the recommended oil change interval and what weight of oil do you run in the engine ? And sounds like you can run regular unleaded gasoline too?
Intriguing, Just asking.
Have a good one,
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 09-27-2014, 06:55 AM   #128
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
7500 miles is the recommended oil change interval. I have gone into Ford a couple of times to change it sooner and they say I would be wasting my money. They use a synthetic blend of oil.
The turbo's only kick in when they are needed and the 3-4000 rpm range is only used on very steep upgrades which do not go on forever. 90% of the time you are on flat to rolling hills terrain.
TinCan
graysailor is offline   Reply With Quote
Old 09-27-2014, 08:10 AM   #129
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Ford F-150 Eco-Boost.
Now that fact about the turbos I find interesting. When driving untowed, with the windows down, there's a pitched hiss I've always assumed to be the turbos. A comforting, reassuring, "the engine is still mounted and operating" kind of hiss....
2011 Airstream International Serenity 28' - 30a/taupe
2013 Fors F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 09-28-2014, 08:05 AM   #130
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Images: 8
As soon as exhaust gas is generated, a turbo charger starts spooling up. Thus the need for immediate oil flow to the turbo bearings when the engine starts. Blipping the throttle before oil pressure comes up is a good way to ruin the bearings in the center section.
Also, one should consider installing an EGT (exhaust gas temperature gage) and get the temperature down to under 375 degrees before turning off the motor so the oil does not bake onto the turbine shaft and bearings (a process called coking). This idle time also allows the turbo to spool down to much lower rpm so when the engine stops and oil pressure drops to zero, the bearings do not get scored.
Since these are small turbo blades, they could be spinning over 200,000 rpm under full load. Both of our 6" turbos would spool up to 80,000 rpm on the Continental V12 M-60 tank engine.
In a new vehicle with good insulation, the turbine whine will not be very noticeable. Get a lot of miles and age and the noise will become apparent as the sound and heat insulation breaks down over time.
Old 09-28-2014, 08:28 AM   #131
1994 30' Excella
Mississauga , Ontario
These turbos are also cooled by a water jacket that has been designed to allow coolant to circulate by convection after the engine is shut off. Therefore you should not have the same problem with coking that is possible with others. Having the water jacket should keep the turbos temp lower to start with and would remove excess heat very quickly. If you pull off the highway to buy gas, I would think the temp is already way down in the turbos.
I change my oil at about 12,000 km and use regular Ford oil, not synthetic.
Now have 140,000 km on the clock and no issues.
Al
Al and Jean
TAC ON-3
Old 09-28-2014, 08:41 AM   #132
switz's Avatar
2014 31' Classic
Images: 8
A little spool down time is far cheaper that the replacement cost of an out of warranty turbo charger and in this model's case, two turbo chargers.
Old 09-28-2014, 06:25 PM   #133
danjoe91's Avatar
1985 32' Excella
Valley Village , California
Images: 16
We just returned from our trip from Los Angeles to Zion, North Rim Grand Canyon, Williams Arizona and back. I averaged with my 2012 ecoboost-max tow package-10.4 mpg. I drove 1,320 miles, used 126 gallons of fuel. I was averaging 11.5 for all of the trip until I left Williams for home yesterday. The head winds on I-40 from Kingman, AZ through Barstow, CA were unbelievable! If any of you have done that drive, you know that is a long tow through nothingness. We did encounter one big rig that was blown over. I think my mileage would have done better if conditions were more favorable. All in all, the ecoboost with tow package is my new favorite set up! The only 'problem' I had was driving too fast...uphill!
danjoe91 is offline   Reply With Quote
Old 09-29-2014, 11:27 AM   #134
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
"nothingness" is right...it's not a place I would want to breakdown...what was your average speed? I usually tow at 65-68mph...occasionally at 70 when straight and "nothingness" is all there is...my 2012 is 4X4, but I still don't average quite as good as your reporting...
Old 09-29-2014, 11:37 AM   #135
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Check this link out:
Can the new 2015 Ford F-150 2.7-liter really tow?
Our Airstream-owning engineer puts EcoBoost to the test.
kscherzi is offline   Reply With Quote
Old 09-29-2014, 11:52 AM   #136
danjoe91's Avatar
1985 32' Excella
Images: 16
My truck is also a 4X4 157" wheelbase, and I set the cruise at 70, until I hit Calif. where the max trailer towing speed limit is 55- so I went around 62. I stayed around 1,800 rpm's.
Old 09-29-2014, 12:17 PM   #137
1981 31' Excella II
New Market , Alabama
Seems like Ford has a 2.7L Ecoboost F150 version now.
https://autos.yahoo.com/news/2015-fo...160000186.html
Perry
Old 09-29-2014, 03:03 PM   #138
kscherzi's Avatar
Images: 24
The 2015 "Build and "Price" tool is online. I managed to build a well equipped ecoboost 2015 Lariat SuperCab for $53,400.
Along with power heated/cooled driver passenger seats, leather, navigation, etc, the build included the max trailer tow package $795, technology package (back-up camera) $905, extended range fuel tank (33 gallons) $195, side steps $325, power trailer tow mirrors $165, adaptive cruise control system $1,250.
It also appears that 3.55 is the highest final drive, didn't see a 3.73 option. Looks like horsepower/torque on the 3.5 ecoboost is unchanged.
Old 09-29-2014, 09:27 PM   #139
N/A , N/A
Review of 2015 F150 with 2.7 Liter ecoboost engine by Consumer Reports. Tom Mutchler test tows an Airstream. Pretty positive review.
rostam is offline   Reply With Quote
Old 09-29-2014, 11:45 PM   #140
TinCan
graysailor's Avatar
2016 30' Classic
I believe that at this time you can only build a F250 Super Duty also the 3.73 rear ends should be available. You can go to a dealer an order a 2015 and they have all the up to date info.
TinCan
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
2015 Ford Expedition with Eco-Boost Roadtech Tow Vehicles 16 02-24-2014 04:43 PM
