Closed Thread
Old 05-16-2014, 07:47 AM   #589
2003 28' Classic
Ladysmith , Wisconsin
Name:	ImageUploadedByAirstream Forums1400248048.866663.jpg
JacobMerridy is offline
Old 05-16-2014, 07:53 AM   #590
2003 28' Classic
Ford F150 3.5L Eco Boost
If you zoom in the hitch, two bolts are below the an available space, the local shop raised this up one notch.
Old 05-16-2014, 07:55 AM   #591
2003 28' Classic
Do you mean, the away bar adjustment at the trailer side needs adjustment also ?
Old 05-16-2014, 08:28 AM   #592
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
How many washers are you using in the hitch head? I would recommend 5 to start with. The distance between the center of the ball and the center of the L brackets should be 32 inches.
The picture looks like it might be a bit short.
subfan1 is offline
Old 05-16-2014, 09:47 AM   #593
3202 Ellie
boliversr's Avatar
1975 Argosy 24
milan , Michigan
The 6.0 diesel is junk and ford won't stand behind it I had a 2007 and put 260 thousand miles on it and lots of cash 3 sets injectors,fuel mod card ipr valve just to mention a few every time the engine light came on I knew there $2000.00 dollars or more. when running right it was great but never ran right for long. If you got 100 k you are luckly get rid of it
boliversr is offline
Old 05-16-2014, 11:32 AM   #594
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I agree with this; Mine were too close at first too. Moving the brackets farther back gives your spring bars more leverage and flexibility.
I also recommend that you install your "L" clip pins with the loop in the front instead of the open end in front. And you should install your spring bar socket pins with the clips to the inside. The reason that I say this is that, while going in a forward motion, a bush or any other object hitting these clips could knock them out. I ran over something on the freeway once and found one of the clips was missing.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline
Old 05-16-2014, 11:33 AM   #595
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Wow that is a load on a 1/2 ton pickup!
Moflash is offline
Old 05-16-2014, 12:22 PM   #596
Nashville , Tennessee
How would you spend that $$6000-$$8000???
Originally Posted by dayner View Post
The used Ford Excursion with a 6.0 makes a great if not one of the best tow vehicles hands down. However the 6.0 must be made bulletproof which is quite easy & common today, but it'll cost you probably around six to eight thousand dollars it have a shop do it. The bulletproof engine will last probably on the order of a half million miles.
How would you spend that money???
rlandis is offline
Old 05-16-2014, 03:32 PM   #597
2010 28' Flying Cloud
Slidell , Louisiana
The 6.0 needs either EGR delete or aftermarket metal cooler, coolant filter, and either oil cooler change but preferably and air cooled external oil cooler conversion. If an early model head bolt studs, & if the turbo is already trashed an aftermarket turbo. Just go to the Web & search "bullet proof 6.0" or same on YouTube & you will find lots of info & folks to address the 6.0 issues and you will soon learn 6.0 is the same delendable diesel engine in almost all International powered school busses, but with a lot of problematic emission stuff poorly engineer by Ford/Navistar and hurriedly tacked onto it. Turn it back into a clean International school bus engine and it will run very strong forever. Ford/Navistar just demonstrated that there is a right way and a wrong way, although also a cheap way, to do everything as exemplified by their poor conversion of the 6.0...., and that unending litigation between Ford and Navistar simply left the consumers out in the cold
Sent from my HTC6525LVW using Airstream Forums mobile app
dayner is offline
Old 05-16-2014, 03:46 PM   #598
1994 30' Excella
Mississauga , Ontario
You guys sure don't seem to know what a 3.5liter ecoboost is by your discussion.
Al
Al and Jean
TAC ON-3
BigAl is offline
Old 05-16-2014, 04:41 PM   #599
Moflash's Avatar
213 cubic inch v6 with two small diameter turbos.
Its not that the little engine doesnt have enough power to pull a larger trailer.I does
Sadly the suspension on the truck was not designed for the weight of the large trailer,cargo and occupants pictured here.
Moflash is offline
Old 05-16-2014, 07:16 PM   #600
r carl's Avatar
Lin , Ne
Down payment on an ecoboost pickup.
r carl is offline
Old 05-16-2014, 07:21 PM   #601
2003 28' Classic
I'm keeping my F-150 Eco boost to tow my 28' Classic with 800 pounds of truck load. It's pushing it, let see who we are doing down the line.
Old 05-19-2014, 08:05 PM   #602
Kevin245's Avatar
From a Ford F150 to a arguing the merits of a Chrysler 300 and a series of "what if" scenarios. Needless to say we are not sure why things can't seem to stay on topic when it comes to tow vehicle threads, but we've cleared out a fair amount of the argumentative material and this thread is closed until further notice.
The Site Team
Eleanor Roosevelt
Kevin245 is offline
Closed Thread
ecoboost, f-150
Newb hitch question Wryknow Hitches, Couplers & Balls 16 10-09-2013 04:25 PM
Passenger van as tow vehicle? DanielB Tow Vehicles 51 05-30-2011 11:02 PM
Ford hitch 2.5" to 2" adapter hhendrix Hitches, Couplers & Balls 15 03-28-2011 08:32 PM
TV Questions - 1980 Ford F100 jmdotter Tow Vehicles 7 02-05-2011 01:48 PM
2011 Ford Super Duty Diesel, Don't trust the fuel calculator hhendrix Tow Vehicles 19 01-13-2011 09:18 PM
