Closed Thread
Old 10-02-2013, 11:11 PM   #477
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I'm thinking of buying one of those in the future to replace my Lincoln; What is the payload on your truck? See sticker in door jamb. My Lincoln is about 1600 lbs.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline
Old 10-03-2013, 01:09 AM   #478
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Thanks for your thorough description. We're just over the half way mark on a 10k mile trip using our Suburban as a TV. We've come to the conclusion that we need a TV with more power and the EcoBoost in one of our options. I have one question about your experience so far. When you're climbing either steep or very long grades, what's your engine RPM?
Thx for your help,
Paul
As far as I know, this is the oldest I've ever been.
Road Geezer is offline
Old 10-03-2013, 09:14 AM   #479
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by JFScheck View Post
28 footer with slide out - those slide outs are HEAVY - way too much tongue weight for an F-150/1500!!!
To whom is this response directed? The only person to post to the thread about towing his trailer with an Ecoboost F150 in the last 2 weeks has a 25' '06 Safari, no slide (clearly described in text and shown in photos.)
David
DKB_SATX is offline
Old 10-04-2013, 04:29 AM   #480
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Road Geezer
You likely don't "need" more power however you could easily "want" more power. However if you like your Suburban as a vehicle you may be able to substantailly improve your hill climbing with a little driving technique and a different tire size.
What year suburban do you have?
Which engine?
Do you know your axle ratio?
Do you have a 4 or 6 speed transmission?
What size tires do you have?
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline
Old 10-04-2013, 09:43 AM   #481
Denver , Colorado
We just traded an '05 F-250 diesel for a '13 F-150 Ecoboost and just returned from a 500 mile trip from Denver to western Colorado. Going up Mt. Vernon canyon, thru Eisenhower tunnel and Vail pass is a pretty good test for a towing vehicle. Honestly, after a lot of research and discussion with the Ford dealership, I was still nervous about the decision to go with the F-150. After this trip I'm happy to say that our experience was terrific. It's a great vehicle. Going east on Vail pass, which is a real workout, it pulled easily at 65 mph and still had room to go. Engine braking is not as strong as the F-250 and I'll need to learn how to use the tow/haul feature of the F-150. On the relatively flat open road, it's a real pleasure to drive and there's no problem with pulling the trailer. F-150 specs: 4x4 Supercrew, Ecobost V-6, 3.5L engine, 3.55 axle ratio, select shift transmission, trailer brake controller, 7200# GVWR tow package. Airstream specs: '04 25ft. Safari LS. GVWR (empty): 6,300 lbs. Hitch wieght w/o options or variable weight: 750 lbs.
Globeville is offline
Old 10-04-2013, 10:20 AM   #482
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Look at your payload max capacity on the drivers door jamb subtract the tongue weight and hitch weight and that is what you have left for passengers gear and if you weigh more than 150lbs that weight needs to be subtracted also.F150's are great trucks just low on payload capacity and max out very quickly.
Most dealers that sell them have no clue how they should be spec'ed out to tow large travel trailers properly.
Moflash is offline
Old 10-04-2013, 04:32 PM   #483
1988 32' Excella
Robbinsville , New Jersey
That is very true and as evidence of that the dealers often register trucks for the nest thousand pounds over the trucks weight instead of the GVWR. This poor practice often makes it illegal to drive your truck with a passenger in the truck (let alone any cargo) because you would be over the registered max weight of your truck.
Wazbro is offline
Old 10-06-2013, 06:31 AM   #484
Whtesocks
2014 31' Classic
Crane , Missouri
Currently have a 2014 Classic, which I pull with a 2013 F150 ecoboost engine, with the trailer package and the 3.73 differential. The door sticker and books say the maximum combined weight is 17,100 lbs. at my configuration. That being said the power of the engine is impressive and mileage is around 10 to 12 pulling the trailer. I've hit around 19 without the trailer, which includes city driving while unhitched. All my research and current experience pulling the trailer support the F150 is capable of pulling a 31 footer with no problems when properly equipped. I do like the softer ride when unhitched!!!!
dmnichols is offline
Old 10-06-2013, 07:11 PM   #485
Road Geezer
Originally Posted by Andrew T View Post
Hi Road Geezer You likely don't "need" more power however you could easily "want" more power. However if you like your Suburban as a vehicle you may be able to substantailly improve your hill climbing with a little driving technique and a different tire size. What year suburban do you have? Which engine? Do you know your axle ratio? Do you have a 4 or 6 speed transmission? What size tires do you have? Andrew T
Hi Andrew, pls excuse the delay in my reply. We're on a long trip currently in MI heading north the Mackinac Island, and I haven't mastered the iPhone Forums ap yet.
I have a 2001 1500 Sub with a 5.3 ltr engine. It's a 4 speed tranny with 3.73 rear end. The tires are stock; I think 17 ". Odometer is around 145k.
Appreciate your advice.
Old 10-06-2013, 08:26 PM   #486
Dallas Center , Iowa
I have owned 2 Ford F150 EcoBoosts. 2011 & 2013. If I were to do it again and planning on towing any camper at all I would for sure have: MAX Tow, 3.73 rear end & E rated tires. This gets you the highest payload which is the real weak link so to speak in this combined tow challenge of the various F150 EB models. The motor and transmission clearly have enough power on all F150 models. It is more about the payload which includes passenger safety when towing so we do not overload our equipment. So far, I am unimpressed with the Navigation My Touch product. For me it lacks responsiveness and intuitive design. By the way, the marketing about the great gas mileage is over stated so I resolve to have resonable gas mileage with great comfort and stellar towing capability in it's class. Happy camping.
Earthcreeper is offline
Old 10-07-2013, 01:00 AM   #487
Evergreen , Colorado
As a two time owner Earth I'm assuming you are aware of the HD Payload package? You mention the HD Tow pack, but that is completely different than the HD Payload pack.
Nightwatch is offline
Old 10-07-2013, 08:14 AM   #488
DKB_SATX's Avatar
1976 Argosy 28
He described the configuration of the truck that makes up the HD Payload package since he specified the E-rated tires. The only one that comes with factory-installed E-rated tires is HD Payload, 17" E-rated tires on 7-lug rims. The only small drawback is the long wheelbase that's also required to get HD Payload.
David
DKB_SATX is offline
Old 10-07-2013, 12:57 PM   #489
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Squirrely F150
When towing, with my 2013 F150 twin turbo, we get pushed around when ever a tractor trailer rig passes us. We also can feel it whenever a large sedan passes us going the same direction.
I am not saying that the effect is unsafe I am saying it is very annoying and unexpected.
We previously had a Tundra and while there was a small amount of "squirrellyness" when a truck passed it was never to the degree happening with the F150.
The F150 has passenger tires, but so did the Tundra and we are using the same Hensley set up to keep the F150 level when the Airstream is hitched.
I am wondering if anyone else is having a similar problem.
TEXAS66
SRW is offline
Old 10-07-2013, 02:18 PM   #490
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I have a Hensely as well , when the dealer moved the hitch from our previous trailer he set it up incorrectly. If you have not checked the setup of the hitch yourself I suggest you verify that it is done correctly. You can contact Hensley and they may have some advice, it is more likely the Hitch setup than the truck. Speak to them about the drop bar you are using.
BTW I have never had any "squirrellyness" with either F-150 I have towed with once I got the Hensley dialed in. I would be interested what the solution is.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline
Closed Thread
ecoboost, f-150
Newb hitch question Wryknow Hitches, Couplers & Balls 16 10-09-2013 05:25 PM
Passenger van as tow vehicle? DanielB Tow Vehicles 51 05-31-2011 12:02 AM
Ford hitch 2.5" to 2" adapter hhendrix Hitches, Couplers & Balls 15 03-28-2011 09:32 PM
TV Questions - 1980 Ford F100 jmdotter Tow Vehicles 7 02-05-2011 02:48 PM
2011 Ford Super Duty Diesel, Don't trust the fuel calculator hhendrix Tow Vehicles 19 01-13-2011 10:18 PM
