Closed Thread
Old 05-23-2013, 01:33 PM   #407
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If anyone is interested I proved (at least to me) today that a F150 Super Crew Ecoboost can easily haul 3000 lbs of washed gravel in the bed. Not saying it was done safely but it can be done. I am glad I only had go about 5 miles with the load at low speed. It had a very sloppy feeling in the front end and showed lots of compression of the rear springs and noticeable squashed tires. Engine felt good and I could really feel the low end torque do its thing. I donít plan on repeating this foolishness but nice to know it can be done if ever needed. This may be old hat to some but for me this was a first at hauling such a dead weight load in the bed.
MICHAEL
AWCHIEF is offline
Old 05-23-2013, 02:11 PM   #408
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by slowmover View Post
I note that most all tend to drive pickups the same as they drive cars despite important differences in outcomes. .
You can't be serious. Really
Not giving very much credit to the rest of us.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline
Old 05-23-2013, 02:15 PM   #409
Jim Clark's Avatar
Thanks for doing that, now I don't have to.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 05-23-2013, 02:33 PM   #410
AWCHIEF's Avatar
Images: 33
Jim, I certainly would not recommend anyone try this stunt at home without adult supervision.
MICHAEL
AWCHIEF is offline
Old 05-23-2013, 03:39 PM   #411
JFScheck's Avatar
Rockville , Maryland
Images: 33
Yep, no problems with torque or horsepower, but I bet you the suspension was "crying" like crazy along with the brakes...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline
Old 05-23-2013, 05:00 PM   #412
Jim Clark's Avatar
That is the issue, the only adult in my life is my wife.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 05-23-2013, 05:03 PM   #413
AWCHIEF's Avatar
Images: 33
The suspension was definitely not happy. Hopefully it has a short memory and will forgive me.
MICHAEL
AWCHIEF is offline
Old 05-23-2013, 05:06 PM   #414
SteveH's Avatar
Common Sense , Texas
I've carried loads like that in 1/2 tons several times at slow speed and all survived. Not really recommended, however.
Regards,
Steve
SteveH is offline
Old 05-23-2013, 05:11 PM   #415
AWCHIEF's Avatar
Images: 33
From personal Experience I can safely concur, definitely not recommended.
MICHAEL
AWCHIEF is offline
Old 05-23-2013, 05:39 PM   #416
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
Originally Posted by kscherzi View Post
I now drive a 2003 Expedition. I get 15 mpg unloaded average. Towing closer to 10 mpg, but its all leather, has 1,600 lbs payload and independent rear suspension. I think the eco boost F-150 is a wonderful improvement, but its fat so payload suffers on the nicer models. I'm waiting on the 2015 for its claimed 700 lb diet. Hopefully most of that gain is plowed back into payload. That would make the truck closer to perfect.
2012 F150 Ecoboost SuperCrew with Max Tow / HD Payload, Lariat (leather, etc)
Payload: 2150 lbs
Fuel stats from last trip:
12.5 l/100km (18.8 mpg) solo - with family of 4 on board + cargo,
19.2 l/100km (12.2 mpg) towing (30' Safari)
14300 lbs total combined weight (CAT Scales)
The only thing I don't like is the mileage for short distances. Until the truck warms, it's very expensive to run. As my daily commute is short - this is not the most economical vehicle for the job.
MaxTow is offline
Old 05-23-2013, 10:59 PM   #417
2005 19' Safari
GLENDALE , AZ
Just an opinion from someone who has absolutely no experience with Ford pickups:
Personally, I'd be concerned about overloading the tires. You might want to check the load rating and do the math to see if 3,000 pounds of gravel in the bed may have damaged the sidewall cords. If they were overloaded, I'd worry about the tires failing in the summer heat (especially a concern if you are towing at the time).
I hope I am wrong...
Phoenix is offline
Old 05-24-2013, 01:49 PM   #418
AirChief's Avatar
2012 19' International
Salem , Oregon
I guess I will pile on to the subject. 2011 F150 EB 4x4 Offroad, SuperCrew with Max tow. Pulls great and I have gotten anywhere from 12 to 13.5 mpg. However, I do pull a 19' so total weight is only 4500 fully loaded. Only problem I can see now hindsight 20/20 is the total payload for this configuration truck is 1800 lbs. Add gas, 4 people and 550 hitch weight if the trailer is fully loaded and you have less than 300 lbs of capability in the bed. Now that being said, the truck is "rated" at that level for 100% safety and capability and everything is rated higher then what is can actually do for safety purposes. I'm not recommending hauling 3000lbs of rock but the truck can do more than rated but it is always best to stay in the safety zone - that's why they are created, stay in the safety zone to significantly mitigate and likely eliminate the risk.
AirChief is offline
Old 05-24-2013, 02:18 PM   #419
SteveH's Avatar
Exactly why I could not get a 1/2 ton to work for us with the 30'er, a Propride hitch (1140 lbs total tongue), camper shell, and all the "stuff" we carry. Even checked on the capacities of the larger 1/2 ton SUV's, and no dice.
However, I did not check on the mini vans....they seem to handle the weight OK up in Canada.
Regards,
Steve
SteveH is offline
Old 05-24-2013, 02:46 PM   #420
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Half ton trucks that have not half ton capacity, but one ton or 3/4 ton. This is one case where they don't inflate the name and call a truck with one ton capacity a two ton.
My truck can tow a space shuttle.
Gene
Gene
Gene is offline
Closed Thread
ecoboost, f-150
Newb hitch question Wryknow Hitches, Couplers & Balls 16 10-09-2013 04:25 PM
Passenger van as tow vehicle? DanielB Tow Vehicles 51 05-30-2011 11:02 PM
Ford hitch 2.5" to 2" adapter hhendrix Hitches, Couplers & Balls 15 03-28-2011 08:32 PM
TV Questions - 1980 Ford F100 jmdotter Tow Vehicles 7 02-05-2011 01:48 PM
2011 Ford Super Duty Diesel, Don't trust the fuel calculator hhendrix Tow Vehicles 19 01-13-2011 09:18 PM
