Closed Thread
Old 08-05-2012, 01:02 PM   #211
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Paiceman,
I was referring to the maximum payload package. This a different option than the maximum towing option. You can get both but on a Platinum trim. I also have a Platinum and have several posts on the problem with GAWR rear. I changed from scorpions to 10 ply load range E Michelins. Also installed Timbren rubber suspension enhancements. Overall, the truck tows very well and stops well, but I have to limit the gear I take due to the lousy payload restriction. Difficult to do with kids.
The max payload option would fix this.
[AIR# 55762 TAC# NFL-1
DMT is offline
Old 08-05-2012, 01:24 PM   #212
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by paiceman View Post
We did a lot of research before buying it, thought the 25 was right for us, now are looking at a 30' and from what we are reading and in talking with folks it appears we would be illegal.
Is that according to the recent SAE tow ratings of trucks? You may be able to get suspension parts from the maximum superduper extraspecial package to upgrade the truck you have.
Since most people don't use trucks as trucks, many come with cheap tires. But those OEM tires don't seem enough for the truck unloaded. Wouldn't a full size pickup weigh more than 4,400 lbs.? Cross check on Perelli's website and see what it says there for the same tire. And if you put more air in them, they should have a higher weight rating.
Gene
Gene is offline
Old 08-05-2012, 02:22 PM   #213
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You're on the right track finding better tires, stay with your truck. Why waste your hard-earned money on something you already have. As for payload, some of that is redirected to the trailer by the weight distribution hitch.
Although the 30' is capable of carrying 1500# more than the 25', the actual trailer weight difference is much less, closer to 800#.
doug k
dkottum is offline
Old 08-05-2012, 08:15 PM   #214
2010 27' FB International
Alpharetta , Georgia
I have 6-7000 miles of towing my 2010 27 FB International using the F150 w/Ecoboost. Routinely climb Hog Pen, and Unicoi Gaps outside of Helen. Also towed across the mountains outside of Cherokee NC and Chattanooga TN. Plenty of power. Gas mileage, 9-9.5 mpg around the mountains. Have averaged as high as 13 mpg between Pensacola and Atlanta.
py1950 is offline
Old 08-07-2012, 11:23 AM   #215
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Paiceman
I think your reading your sidwalls incorrectly, your tire capacity is likely 1095 Kilograms or 2400 pounds per tire. If you are anywhere near this much on the rear axle then you need to adjust your hitch to move some weight to the front wheels.
Towing a 25 or a 30 is virtually identical I doubt you could tell the difference if you did not know which one you were towing.
If you want 4wd the 250 is actually quite a bit less stable in an emergency maneuver due to the solid front axle and higher Centre of Gravity. We have many customers towing 30's 31's and 34's with F150's they work very well, I would not trade the ride and handling of the 150.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline
Old 08-07-2012, 12:07 PM   #216
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Thanks, we have the beefed up towing package, but it comes with 20" Pirelle Scorpion tires that have a load rating of only 1097 pounds and this is with the Platinum package? We have it on the window sticker and the invoice where we paid for the max tow package -- HD supplemental radiator, extra tran cooling, pull out tow mirrors etc. But the low rating tires, unless I am reading it wrong on the side wall and the door sticker.
The 20" Pirelli Scorpion ATRs are rated between 2403 lb per tire and 3195 lb per tire on TireRack's website. That said, I don't think I'd choose a 20" wheel for towing duties.
— David
DKB_SATX is online now
Old 08-07-2012, 03:59 PM   #217
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
I run my scorpions at 41-42 psi and they handle just fine. However when they wear down I will replace with a LT or XL tire.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline
Old 08-07-2012, 04:18 PM   #218
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Sticking with the EB, at least for now, tires are 2430 so fell ok there. Little body sway even with 25' so increased bars from 850# to 1,200#, made a difference when we tested a 30' today. Worked great, took it out for 100 miles, averaged 13.8mpg, not too many hills, some stop and go an some interstate, kept it at 60 MPH. We bought the 30' Flying Cloud.
Thanks again for the input, much appreciated.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
paiceman is offline
Old 08-10-2012, 07:09 AM   #219
SteveH's Avatar
Common Sense , Texas
A Question For Newer F150 Drivers
There was a comment in a newer type hitch thread where the towing vehicle, a newer Ford F150 aparently went into sway control mode using the vehicle's brakes and throttle controlled by it's onboard computer. This was a result of the truck and Airstream being passed by a big truck in combination with cross winds.
My question to you F150 Ecoboost drivers is, is this something that happens frquently, or even periodically?
If this has happened to you, please tell us under what road conditions, speed, and what type of hitch you are using.
Steve
SteveH is offline
Old 08-11-2012, 06:44 AM   #220
paiceman's Avatar
Steve, although I've never experienced that type of sway, under advice of Ford and several AS dealers I turn the truck sway control OFF when towing the AS and let any sway be controlled by the hitch assembly. As everyone I've been passed and I've passed numerous tractor trailers and never had a serious sway issue
SAFE TRAVELS
Bud
paiceman is offline
Old 08-11-2012, 07:16 AM   #221
dkottum's Avatar
Hmmm, did Ford or the several Airstream dealers give you a reason for turning the sway control OFF when towing? Is this good universal advice? What do they know that the Ford, Chrysler, GM, Toyota, etc engineers don't know?
What brand of hitch are you using?
doug k
dkottum is offline
Old 08-11-2012, 07:23 AM   #222
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
paiceman, Not saying right or wrong, but that advice conflicts with what I was told by the Technical Advisor at my local Ford dealership. She said that the Ford sway control system when using the Ford brake control is fully intergrated and shoud be used when towing, that is what it is designed to do. On site at the time was her conterpart from Ford, he agreed. They knew I was using an Andersen WD system. Hopefully I will never have to test what is correct. But it adds to the piece of mind of towing with my Ford to know that the system is there and seems to work when the conditions require it.
MICHAEL
AWCHIEF is offline
Old 08-11-2012, 07:36 AM   #223
LaBigDogs's Avatar
2011 25' FB International
Carencro , Louisiana
SteveH .... It has never happen to me in 8,000 miles of towing... only once when I was on the freeway in a steep bank, I was veered off into the shoulder and it was level (a large angle from the roadway) and the sway control kicked in for about 2 sec... and all was ok.. It did it's job and worked flawless..... 2011 4X4 EcoBoost 3.55 - Have my new 2013 4X4 EcoBoost 3.73 with the new power fold/telescoping mirrors on Order... I love this truck....
LaBigDogs is offline
Old 08-11-2012, 08:06 AM   #224
DKB_SATX's Avatar
1976 Argosy 28
I note that you're going from a 3.55 in the '11 to a 3.73 in the '13. Would you care to tell me more about that? I have a 3.55 in my '07 5.4l and I've thought more than once that the 3.73 probably wouldn't have been significantly thirstier, and would likely let the truck keep the torque converter locked longer and still maintain speeds on moderate slopes.
With the torque-monster Ecoboost, I thought I'd probably be OK with 3.55. It may still be true, my '75 trailer is probably quite a bit lighter than your modern one, but I'm curious about your experience and your move to the 3.73 axle to go along with your new telescoping mirrors.
— David
Closed Thread
ecoboost, f-150
Newb hitch question Wryknow Hitches, Couplers & Balls 16 10-09-2013 04:25 PM
Passenger van as tow vehicle? DanielB Tow Vehicles 51 05-30-2011 11:02 PM
Ford hitch 2.5" to 2" adapter hhendrix Hitches, Couplers & Balls 15 03-28-2011 08:32 PM
TV Questions - 1980 Ford F100 jmdotter Tow Vehicles 7 02-05-2011 01:48 PM
2011 Ford Super Duty Diesel, Don't trust the fuel calculator hhendrix Tow Vehicles 19 01-13-2011 09:18 PM
