Old 09-25-2010, 07:33 AM   #1
Road Ruler's Avatar
Images: 38
Ford F150/3.5 V6 Durability Test
Ford claims the new 3.5 V6 Ecoboost in the F150 can tow over 10,000lbs.
For those concerned about the F-150 EcoBoost V6's durability, Ford has heard your concerns, and plans a demonstration: Running a randomly-selected EcoBoost 3.5 engine in a Baja 1000 entry.
But wait: First, THAT SAME ENGINE will:
- Be used to haul logs in an Oregon logging camp
- Tow a pair of race cars around a track a full throttle for 24 hours
Then it's off to Baja. After the race, they tear the engine apart. We'll all get to see how well Ford has done their homework.
Some details here: Ford to campaign F-150 EcoBoost in Baja 1000 — Autoblog
Some will compare the EcoBoost with Ford's new high powered/high torque 302ci. In the Mustang platform Ford claims it will get 35MPG.
Old 09-25-2010, 08:34 AM   #2
r carl's Avatar
Lin , Ne
Thats a race truck, not a production truck.
We all know what production trucks give us.
Old 09-25-2010, 10:20 AM   #3
Road Ruler's Avatar
Images: 38
From the article..... "Ford will equip the F-150 off-road race truck with the same stock EcoBoost engine that already has experienced 150,000 equivalent miles of dyno testing and other real-world tests as the final step in the durability torture tests"
The test is for the engine.
Being in a race truck increases the demands on the engine/test.
Old 09-25-2010, 11:19 AM   #4
tpi
Trabuco Canyon , California
I certainly see the potential here.
Higher cylinder pressures, compression ratio, and direct injection translate to increased efficiency. Smaller V6 configuration translates to less internal friction compared to V8.
Somehow though, all the testing doesn't seem to weed out all possible curveballs the real world throws.
I like what I see but I won't be an early adopter. I want to see if there are valve deposit issues with the direct injection, thermal issues, or wear issues due to heavier loading.
I hope the engine is a complete success.
tpi is offline   Reply With Quote
Old 09-25-2010, 12:12 PM   #5
r carl's Avatar
Lin , Ne
I hope it has more than 3/8th of an inch of threads for the sparkplugs so it doesnt spit out sparkplugs like their past engines.
Old 09-25-2010, 12:22 PM   #6
Ottawa , ON
Wow, that's the motor they use in the Flex, isn't it?
I can see my next TV for when we get tired of the Freestar...
Old 09-25-2010, 01:46 PM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Unfortunately they only rate the Flex for 5k lb towing. If my Legacy Wagon needs replacing before Ford drops the Flex, I'd want one. As it is, I think I'll keep the Legacy and add a pickup to our lineup for when we have something to tow.
Old 09-25-2010, 05:05 PM   #8
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I second that one. In the middle of Georgia, stuck for a week. $3500 bill.
No more Fords ever for me!!!!
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 09-26-2010, 08:03 AM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
They've got a lot riding on it. The TQ "curve" is impressive. Ought to be fun to use in the usual half-ton that is more commuter than hauler. Anyone seen the maintenance schedule? (As in, change coolant every 5k?)
Old 09-26-2010, 09:43 AM   #10
Ottawa , ON
That's fabulous; the Freestar's tow capacity is only 3,500 lbs, so it may even be a better pull than I get now.
Old 09-26-2010, 01:19 PM   #11
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Trying to make a more reliable and durable product is good and to be commended. Good for Ford! Nonetheless, I'd rather see them put the trucks in the hands of some Nebraska corn farmers who need their trucks to work day in and day out instead of Baja racers. Better yet, a harvest crew who must get the crop in before the weather destroys it, or a logging crew in southern Washington state, who must get to the jobsite before they can start making a living. Those are the people who should be testing the vehicles.
So Long!
Bob Thompson is offline   Reply With Quote
Old 09-26-2010, 06:46 PM   #12
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Are those markets for half-tons at present? Those sound like "natural" HD pickup customers. Not that I don't agree with the premise. The same use can be predicated for our strange little corner of the US: the ranchers, gas field service crews, utility company supervisors, etc (the 4WD business crowd) who are overwhelmingly in 3/4-1T trucks. Maybe with some fleets -- at the county level, or the Port of Corpus Christi -- would we see hard use of half-ton trucks.
In truth NO pickup truck makes sense at the "half-ton" level as they can't really do much work (payload weight or size) compared to the larger trucks. They ought to be ranked as soccer-mom mobiles for Aggies newly graduated and moved to Houston to work at FLUOR or HALLIBURTON. The projected users will haul boats for fishing & skiing and then a brace of ATV's to the deer lease at Thanksgiving. It'll likely be fine for the annual 5k towing crowd. Austinites will brag about solo efficiency. The Dallas crowd will buy 4WD to run to the time-share condo in Ruidoso for snow skiing.
Is there another place on the planet where gasoline engines are still used for "work" vehicles? I think not. No half ton is a work vehicle anymore, or has been since the advent of electronically-controlled diesels.
Am I stupid ? Ford F150 wingfooted Tow Vehicles 40 03-11-2011 08:33 PM
1997 Airstream B190 Ford F150 RV Camper eBay Watch Airstreams on eBay 0 07-07-2010 06:00 PM
Ford F150 with 7300 Max. Trailer Wt. ?'s RavenDog Tow Vehicles 35 11-24-2009 09:08 PM
1969 Airstream 8x31 International w/ 1975 Ford F150 eBay Watch Airstreams on eBay 0 06-20-2009 09:10 PM
Towing questions: 1967 Safari with 1994 Ford F150 Billm67 Tow Vehicles 9 06-05-2006 11:01 AM
