Old 05-24-2013, 01:20 PM   #337
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by ROBERT CROSS View Post
"averages around 12mpg towing and 25 mpg when not."
A 50% reduction when towing seems a little excessive.
I certainly don't get 25mpg when not towing, but only lose 2-4 when.
Bob, I have to think that is because the computes can retune the engine so dramatically, the Variable-geometry turbochargers give you a lot of flexibility. You can cut down the displacement but when you need the power you have to pour on the fuel. The big trick is developing the torque at low rpm. If all you are going to do is tow with the truck the Ecoboost is not the truck for you. If you use the truck as a daily drive and a weekend tow vehicle then it may be a good option.
Variable-geometry turbocharger - Wikipedia, the free encyclopedia
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 05-24-2013, 01:20 PM   #338
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Some people use the mileage numbers from the truck computer and some divide gallons into miles when we get gas. Truck computers have a reputation (confirmed in our SUV's and trucks) to overstate mileage. If I take the computer's word for it, I get one to two mpg better than simple math tells me, but I still have to buy gas in reality world.
Gene
Gene
Old 05-24-2013, 01:23 PM   #339
LaBigDogs's Avatar
2015 27' FB International
2011 25' FB International
Carencro , Louisiana
On my 2nd EcoBoost 1st 2011 now 2013. Will purchase the 2nd gen in 2015. This engine Rocks.... It's like the ultimate driving machine yes it like my x5 BMW. All wheel drive sure footed and smooth quite clean burning sheer power and monster torque! The best Truck I have ever owned.
"Ferdara" Mark and Michael Broussard-Hubbard
Aluminum pulling Aluminum 2018 F-150 4X4 Platinum, 3.5L V-6, 10 speed trans, 6.5 bed, Max Tow 3.55 Elec Locking axle, Roadmaster Active Suspension ~ 2015 Airstream Custom Ordered 27fb International Serenity - Lafayette Louisiana
WBCCI 11100
LaBigDogs is offline   Reply With Quote
Old 05-24-2013, 01:32 PM   #340
Jim Clark's Avatar
Gene
You are taking a leap of faith on what those gas pumps are telling you, if you don't trust the truck manufactures numbers why would you trust the gas pumps? Time to break out the certified gallon gas containers and get down to business. BTW My mileage is just what I was told so I have no I idea what you are talkng about, and yes I can do simple math. Sounds like the issue is with your computer.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 05-24-2013, 01:49 PM   #341
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
On the DIC, most can be calibrated. If properly set, tire height, gear ratio, they will usually be within .5mpg.
If you've changed tire size that kaputs it good 'til it's re-cal'd.
Boob
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 05-24-2013, 02:04 PM   #342
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I certainly don't get 25mpg when not towing, but only lose 2-4 when. 17%
25 mpg seems to be an above-average number for the truck, but the bigger disparity between towing and dead-heading for the DI turbo engine comes from the fact that unloaded on level ground you should be able to run with some manifold vacuum... then you're close to the numbers you could get with a normally-aspirated V6, because you're only using 50 hp or so to overcome aero drag and some rolling resistance.
Traveling similar average speeds but with a heavy foot or in variable-speed traffic with lots of acceleration back to highway speed will net MUCH lower fuel mileage because you'll be under boost much more of the time.
Towing a heavy trailer (even an aerodynamic one like our Airstreams) is going to keep you in the boost a lot to give you that feeling of having plenty of power, but TANSTAAFL.
David
Old 05-24-2013, 02:53 PM   #343
Master of Universe
Gene's Avatar
The gas pumps are checked by every state periodically, so they should be pretty accurate. Certainly more accurate than the gas gauge which moves fast near full and empty and slowly in the middle. It would seem the computer is using the same inputs to get the averages.
I never said you can't do simple math, but it appears you are looking for a way to be offended.
Gene
Gene
Old 05-24-2013, 03:04 PM   #344
dznf0g's Avatar
Oswego , Illinois
The computed mileage onboard does not use the fuel gauge. It uses the injector pulse width of the metered fuel. It is dead nuts accurate on the per gallon side of the equation. As Robert Cross said...on the miles side of the equation, there could be variance as tire wears down or if tires rolling radius or gearing has been changed without a recal.
-Rich-
Old 05-24-2013, 03:12 PM   #345
Master of Universe
Gene's Avatar
My odometer reads a little high—about 2.5 % for a long time, but less than 1% now that the tires are getting close to worn out. That's not enough to account for a 1-2 mpg difference. Other vehicles had the same variance. There seems to be no good reason these things shouldn't be accurate with all the computer whizbang stuff, so I can't explain it except the manufacturer wants me to think I'm getting better mileage than I am.
Gene
Gene
Old 05-24-2013, 03:57 PM   #346
Jim Clark's Avatar
Gene
Gene, I am not offended, I just don't think you conclusions are valid. You have been beating this same drum about the computer read outs being incorrect for as long as I can remember and you are stating your odometer is off. Those of who own these trucks aren't seeing what you claim.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 05-24-2013, 04:10 PM   #347
Lost in America
mojo's Avatar
2004 19' International CCD
Oak Creek , Arizona
Must be a problem unique with those Toyotas.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 05-24-2013, 04:12 PM   #348
dznf0g's Avatar
Oswego , Illinois
My odometer reads a little highabout 2.5 % for a long time, but less than 1% now that the tires are getting close to worn out. That's not enough to account for a 1-2 mpg difference. Other vehicles had the same variance. There seems to be no good reason these things shouldn't be accurate with all the computer whizbang stuff, so I can't explain it except the manufacturer wants me to think I'm getting better mileage than I am.
Gene
Maybe they do that over in T land, but not over here in C & G land. I wll say that you would have to do your pump math over many tankfuls to be accurate. A single tank fill at different pumps with different shutoff tolerances can result in as much as a gallon difference in "full". I don't buy into the state cert conspiracy theory.
-Rich-
Old 05-24-2013, 04:13 PM   #349
Jim Clark's Avatar
I think you may be on to something.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 05-24-2013, 04:16 PM   #350
JFScheck's Avatar
Rockville , Maryland
Images: 33
Originally Posted by dznf0g View Post
The computed mileage uses the injector pulse width of the metered fuel and is nuts accurate on the per gallon side of the equation.
Exactly!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
Can a Ford Flex tow an Airstream Nigel Tow Vehicles 204 12-01-2013 06:47 PM
Questions - Ordering 2011 F150 Ecoboost KerryFO Tow Vehicles 46 11-03-2011 05:32 PM
ordering our next TV - 2011 F150 EcoBoost jm2 Tow Vehicles 20 03-31-2011 05:29 PM
Ford hitch 2.5" to 2" adapter hhendrix Hitches, Couplers & Balls 15 03-28-2011 08:32 PM
