Old 04-26-2013, 09:37 PM   #281
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by JFScheck View Post
Hey, F-150 and 1500 owners - open the door jam and read your max payload capacity. On my F-150 EcoBoost it was 1209lbs. So much for Fords tow guide and it's use. Expensive lesson.
That being said, if you can live with the max capacity, the 2013 F-150 Crew Cab with the new Sony Synch Nav/Stereo, ride, handling, seats and that wonderful EcoBoost engine are great!
Yea - expensive lesson indeed, and that's all I'm gonna say....
The max payload capacity of the F150 SuperCrew Ecoboost is 2400-2600 lb (depending on 4WD/2WD.) Clearly that's not the configuration you purchased. Spending that kind of money, one should tell the salesworm what one needs, not let it sell you something.
David
Old 04-26-2013, 09:37 PM   #282
richinny's Avatar
2011 34' Classic
john, the full story is available. the guides are out there to calculate the final numbers. my estimated weight was only 50 lbs. under the delivered weight (5450 empty) i do envy your heated and cooked seats though.
Ricky
Old 04-26-2013, 10:09 PM   #283
DKB_SATX's Avatar
1976 Argosy 28
I missed the edit window. I want to be clear about my somewhat tart response. I'm not a fan of most car salespeople. Any of them who sells someone a truck as a towing rig because it's "on the lot" rather than helping them find the right one for their needs should be selling something else. Unless you're buying a vehicle from a salesperson you actually know and trust, you should assume they are NOT your friend and do your research before writing your check.
David
Old 04-26-2013, 10:23 PM   #284
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
So - let's be gratuitous and say your max payload is 1330lbs...
Subtract 840 for tongue
490 pounds
Subtract 200 for topper
290 pounds
One driver with clothes on 210 pounds
80 pounds till max
And one passenger with clothes 130 pounds
BOOM - 50 pounds over max capacity....
Your Max capacity can be found on drivers side door jam - bet ya it's more like 1209lbs...
And that's assuming you have both axels used under their max capacity and you are not exceeding you OEM rims or tires...
Max payload includes a 150lbs credit for the driver and a full tank of gas, so you are still under capacity by 100lbs.
kscherzi is offline   Reply With Quote
Old 04-26-2013, 10:27 PM   #285
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I have a little dealer experience....
Find a dealer with a LOT of white on the lot...
Usually indicates they have a good commercial business. The staff usually has more knowledge on all things truck...bring the Service Mgr/Adviser into the discussion.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-26-2013, 11:10 PM   #286
Sunset Beach , California
Originally Posted by Jim Clark View Post
Rion, if you can find a link to the referenced post it would be helpful to review. The tongue weight of the FC 25 FB is 837 and the 25 SS is 835, I towed a 25 SS with my EB and was never close to overloaded. I tow a 28 and still not overloaded. The 28 is has a Tongue weight of 976 mine Sherline scale tell me mine is at 840 with a Hensley in place. I keep my tanks M/T most of the time. I have not made it to a Cat Scale, I think that I need to do check out the trailer at a Cat Scale to be sure I am not living in a dream world.
Jim,
I'll see if I can find that post. It might take a while though. However, all this talk about the capability of the F150EB to handle a 25' AS may become a mute point when the 2015s come out. Apparently, Ford is going to increase the power of the EB engine with EBv2, but at the same time switch to a unibody design if this article is to be believed with a tow rating of only 7,500 lbs. Yikes!
Ford F-150 Going Unibody For 2015 - Truck Trend News
Cheers,
Rion
GinMame (Rion & Nobuko DuVall)
AIR# 58703
TAC CA-24
GinMame is offline   Reply With Quote
Old 04-26-2013, 11:34 PM   #287
DKB_SATX's Avatar
1976 Argosy 28
Originally Posted by GinMame View Post
Jim,
Cheers,
Rion
Do take note of the date that story was "published." It pays to take things announced on 1 April with a grain of salt.
David
Old 04-26-2013, 11:50 PM   #288
Originally Posted by Gene View Post
Rion,
I've never weighed the tongue. To figure out what we could do with this setup, I used a bunch of guesses and weighed many items on a bathroom scale when we bought the trailer.
I took whatever Airstream said was the tongue weight, added for spare tire and propane and then some more because Airstream underreports some times. I figured out just about how much we would take in the trailer, weighing clothes, food, etc., and then adding several hundred pounds to see we would come up pretty far below gross wt. for the trailer. A history of backpacking helps you think light when traveling.
I figured the payload by taking the Toyota numbers, subtracting options (tonneau, running boards), our weight and weights of stuff we take and tongue wt. adjusted for wt. distributing hitch. We came very close to payload.
Everything looked fine. This was more than 5 years ago, so I can't remember all the figuring, but I was satisfied. There are no scales within 50 or more miles of where we live (I lookedthe last one closed years ago), and by the time we are on the road, I want to get somewhere and not look for a scale. So I've relied on the estimates, guesses, and things weighed. My experience with 6 Toyotas is they are overbuilt, so being right up against payload doesn't bother me. If you get within payload and use a weight distributing hitch properly, you should be fine on the axles.
I know many say you have to go to a scale, but there's plenty of information available (some by weighing what you take) and you can figure it without leaving your house. Put as much weight as possible between the truck axles and balance from right to left in both vehicles.
Gene
Gene,
Thanks for the information. Your experience seem to echo what other Tundra owners have told me about the capabilities of the truck. At least until about 2016 when Toyota unveils their unibody version with a V6 turbo diesel or hybrid power train.
Cheers,
Rion
AIR# 58703
TAC CA-24
Old 04-27-2013, 12:01 AM   #289
True, but it makes sense. Truck makers need to get their CAFE ratings up and for their part, I'm sure that they would love to force buyers that need to tow into oil burning 3/4 ton trucks as it would increase profits over the life of the vehicles. I know that there have been rumors about Chevy going unibody on the nextgen after the 2014 models and perhaps bringing a V6 Duramax to the game. If one considers the 2014 remake of the Tundra, Toyota isn't changing very much, but I'm sure that if I were a fly on the wall of one of their design center's conference rooms that I would hear the word unibody tossed around along with smaller engines as a way to increase fuel economy.
What is going to happen, who knows, and for me that is the fun part. Fortunately, I like the F250 Powerstroke and 2500HD Duramax. Unibody or not, I'm not going to lose a lot of sleep over it.
Cheers,
Rion
AIR# 58703
TAC CA-24
Old 04-27-2013, 01:54 AM   #290
JFScheck's Avatar
Rockville , Maryland
Images: 33
Does not - read the Ford owners manual - they are very clear about this - even with pictures of a trailers tongue, peeps (include driver) and cargo and two very clear examples, all using the drivers weight in calculations. That max capacity number as found in the door jam only includes full tank of gas...
Also - for F-150's - max useable load varies from vehicle to vehicle but none exceeded 1330 pounds on the lot, that includes a truck with heavy duty towing package which does nothing for weight capacity.
Unless you have max payload, then You are most likely over weight in any manufacturers F-150 or 1500...
I just lost over three thousand dollars the hard way learning this lesson (oh yea, and 800 bucks on a ARE topper that was ordered and I paid restocking fee) in my one week of ownership. Just glad I didn't even attempt to hook up my new 27FB. My fault as I used the Ford towing guide and their posted weights via axle capacity, GVWR, etc.
Only till I read that one page in the owners manual and found that sticker in the door jam with those examples (really Ford - four men and golf clubs using a F-150 to go golfing?) that it struck me what the actual truth was, as painful and embarrassing as it was and posting this is. Talking to some legal friends of mine who are GC at an insurance company (good sized) - you have any accident and you are a pound over your max capacity you will be held legally neglect by "Johnny Law" as well as will not not have your claim processed.
I know no one wants to hear this - but I'm just trying to help pass along the facts and am glad for once I read the owners manual.
Still hard to believe - my TDI Touareg had more max payload then any 2013 F-150 in the DC area.
Boy, the lesson's I continue to learn about Airstreams and towing just when I thought I was ahead of the curve - and so smug about it...
Anyways - enough beating this dead horse, done with this thread...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-27-2013, 06:31 AM   #291
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Mine states" The combined weight of occupants and cargo should never exceed 708 kg 0r 1561 lbs." I have the standard tow package and 3.55 rear end. I would like to see a bit more but I am within safety limits. DC dealers are really ordering the really base trucks. Mine is a 2011. Mine is a trimmed out Lariat package and is 2011. I originally pulled a 25 now a 28, I don't load the truck or the trailer heavy, but if you carry a lot of toys or have a large family I see how you could run into a issue.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 04-27-2013, 07:38 AM   #292
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Door Sticker Ecoboost, VW and F150
VW and Touareg
Extremely hard to believe. The stats on a 2013 TDI payload are hard to find but are rated at 1155 lbs. maximum with a towing capacity of 7700 lbs. maximum. My trailer, unloaded with full LP has a tongue weight of 960 lbs. as per CAT scales. That would leave 195 lbs for me and stuff in the Touareg. Many sources do not list the payload rating as it is an SUV; however, the cargo capacity is the same. I am somewhat OCD (obsessive compulsive) in my shopping behavior. I have trouble parting with money if I am not sure of getting the best I can afford. At the time, I owned a 2010 VW TDI Sportwagen I looked at the Touareg for a TV. It is a beautiful and capable vehicle but has a shorter wheelbase and light payload like most SUV offerings that are not full sized.
Here is a payload rating source:
Specifications - 2013 Volkswagen Touareg TDI Lux - Yahoo! Autos
Ford, towing and in general
The Ford towing guide is a good source but any buyer has to confirm that the F150 they are buying has certain packages that meet the need. They make a slew of them. First off, a towing package should be a requirement for any Airstream tow vehicle shopper- no question. Study the marone sticker. If buying used, pull it down from the Ford website online for free. The codes tell which axle diameter the truck has, rear, packages, etc. That is the way to verify the truck and match it to the towing guide data. My truck door sticker is as shown in the posted pic. I have a regular payload truck with tow pkg BUT the data indicates that my truck had a build upgrade from 6800 to 6900 lbs. GVW for whatever reason. It has few options. My towing capacity is 8100 lbs. These are specific to my truck- current model style 4.6L 3V 3.55 rear. There are many configurations that go well beyond my ratings. There are some areas of confusion within any particular data like, for example, the 4.6 liter engine. Ford made TWO DIFFERENT iterations of that engine and they are quite different. Often people confuse my engine with the low powered 4.6 liter base engine and wonder how I can tow yet the larger 5.4 liter of the same vintage was only 28 hp more and 70 ft lbs better in torque than my engine. The 4.6L base? 72hp less and 98 ft lbs lower. In reality, the biggest difference is tow capacity and how fast you can go up a hill but, that is why they make gears!
Ecoboost
The ecoboost is a great example of meeting a goal- big engine power from a smaller engine with slight crusing speed mpg improvement. The 4.6 3V SFE achieved nearly the same mileage as the base eco but lacked the big engine grunt as a smaller engine and lower torque and 3.15 rear. The eco primary gain of power without penalty was achieved. They also seem to be able to be driven at a faster speed at better mpg than the 4.6L 3V. Do they require premium fuel while towing? Some say yes. I also heard that the next iteration of the F150 will be focused on mpg. The scary word is that it was reported that a spokesperson stated that most people are not concerned with heavy towing or payloads. My thought is that they will not go less than what Chevy will release this year in their new model capabilities. You are right though as all manufacturers will start pushing the tow crowd to bigger trucks towing over 7500 or so pounds.
Old 04-27-2013, 08:07 AM   #293
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
My Ecoboost with max tow has weight capacity of 1755lbs.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 04-27-2013, 09:35 AM   #294
1994 30' Excella
Mississauga , Ontario
My F150 supercab with 8 foot box and HD payload package and Max tow has a payload capacity of 2740 or 2760 lb. Can't remember the exact amount.
If you don't believe me say so and I'll go outside and check.
Al
Al and Jean
TAC ON-3
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
Can a Ford Flex tow an Airstream Nigel Tow Vehicles 204 12-01-2013 06:47 PM
Questions - Ordering 2011 F150 Ecoboost KerryFO Tow Vehicles 46 11-03-2011 05:32 PM
ordering our next TV - 2011 F150 EcoBoost jm2 Tow Vehicles 20 03-31-2011 05:29 PM
Ford hitch 2.5" to 2" adapter hhendrix Hitches, Couplers & Balls 15 03-28-2011 08:32 PM
