Old 04-19-2013, 09:11 AM   #239
Dallas Center , Iowa
I have been following some posts. I just purchased an AS 25 Classic. Stated dry weight is 6140, tongue weight is 870 dry, GVWR 8000. Hoping to pull this with my EcoBoost with a 3.55 rear axle, does not have Max Tow. F150 rated for 9600 towing and GVRW of 7200. Comments?
Earthcreeper is offline   Reply With Quote
Old 04-19-2013, 09:30 AM   #240
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The only things Max Tow brings to the party (vs. the Tow Package) besides the 3.73 rear diff are the integrated brake controller (which is available as a stand-alone option with the regular tow package, I believe) and the extending mirrors. You'd probably notice a little difference pulling steep grades with the 3.73 vs. your 3.55, but in flatter terrain I wouldn't expect it to matter much.
David
Old 04-19-2013, 09:34 AM   #241
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Check the axle weight ratings of the EB, tag should be on the driver door jamb.
Payload may be the limiting factor not performance ability.
As Gene stated in a previous post factory weights are mostly fiction.
I also have a 25 Classic, this is the loaded tongue weight.
The Classic's are rather plump.
PFC
RLC
Step aside Starbucks, this is a job for alcohol.
Old 04-19-2013, 09:36 AM   #242
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Earthcreeper, I have found a good weight distribution hitch able to transfer sufficient weight is a good starting point. We tried a couple of hitches but settled on a Propride with 14,000 bars does the trick on our 2012 1/2 ton Dodge Ram, as well as completely stable towing.
doug k
Old 04-19-2013, 09:48 AM   #243
I have looked into the Propride however, my payload is so limiting that the added 195 pounds to the hitch weight is too much so I need to keep that much lighter if possible. Without the Max Tow package my upside on pay load is stated in the door jamb as 2156 and that is with the P rated tires. I have replaced to tires to E rated for safety. Still researching the weight distribution hitches. Of course the new Anderson is likely the lightest weight I just have not been able to get comfortable with the idea of torquing the chains and such. Sort of going between the grunion Draw TITE or Reese hitch with 1000 pound bars as a minimum.
Old 04-19-2013, 10:11 AM   #244
dkottum's Avatar
Weight distribution is an underlying theme of this thread because it so important to the capability of the truck. As is stability. Many of us have learned (I have used and tossed the Equal-I-Zer and Andersen) nothing does it as well as the Propride/Hensley design.
Although it is heavy, the differential to another hitch is less significant, and much of this is distributed among axles. It is also expensive, but would have been $1,000 cheaper if I hadn't bought two other less capable hitches first.
doug k
Old 04-19-2013, 10:31 AM   #245
Thumbs up
doug k
X2
We use the Hensley and are well pleased.
PFC
RLC
Old 04-20-2013, 07:00 AM   #246
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We had an Ecoboost, 2011 ordered and we thought set up to tow a 25'. In fact it did, towed great, but then a friend suggested I check the tires - not even close to being able to take the tongue, loaded truck and passengers. We then purchased a 30' new AS, obviously situation less acceptable. Sold truck to neighbor for what I paid for it and purchased a F250 Diesel, it too can tow the 30' actually very easily - it's tires are E rated and can take what we have in the truck and tongue weight.
When doing all the research the dealership has NO idea, Ford headquarters is very limited in their knowledge, tires shops are not much better, at least around here. So, I made the decisions after much research. Your truck can tow the trailer, the payload may be sufficient, but the tires are probably not.
I suggest anyone out for a new tow vehicle start with the tires.
Respect
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-20-2013, 07:36 AM   #247
dkottum's Avatar
Respect
Bud
When I wasn't happy with the P-rated tires on my 1/2 ton truck, I didn't buy a new truck, I bought new tires (XL).
doug k
Old 04-20-2013, 10:26 AM   #248
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Bob - are you placing the scale under the jack stand? If you place it under the base of the Hensley, you should get a different number. My 25FB weighs 900# at the hitch and 1200# at the jack stand.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is online now   Reply With Quote
Old 04-20-2013, 10:41 AM   #249
Mo,
I used the plate from my floor jack under the Hensley with a section of wood between the bars. It wasn't directly under the ball, about 3" back, not perfect but as close as I could get...safely.
As close as I can figure it was about 100# off.
The AS was fully loaded for 'dock'n though, full FW, LPG and all provisions.
Remember the Classic is a little plumper than the average AS.
PFC
RLC
Old 04-22-2013, 09:23 PM   #250
JFScheck's Avatar
Rockville , Maryland
Images: 33
Adding my Weather Tech mudflaps this weekend after I get my ARE topper installed. Sure is a pretty truck, even when dirty...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-22-2013, 10:06 PM   #251
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Toys, toys, there is no end to it . . . . .
Old 04-22-2013, 10:38 PM   #252
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Lots of reviewing going on about the Eco Boost. I guess the jury is still out. Some are getting outstanding fuel milage and others are not. Still undecided myself. I just would hate to have to get a big diesel for everyday use.
graysailor is offline   Reply With Quote
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
Can a Ford Flex tow an Airstream Nigel Tow Vehicles 204 12-01-2013 06:47 PM
Questions - Ordering 2011 F150 Ecoboost KerryFO Tow Vehicles 46 11-03-2011 05:32 PM
ordering our next TV - 2011 F150 EcoBoost jm2 Tow Vehicles 20 03-31-2011 05:29 PM
Ford hitch 2.5" to 2" adapter hhendrix Hitches, Couplers & Balls 15 03-28-2011 08:32 PM
