Old 01-19-2009, 07:03 AM   #1
Herndon , West Virginia
Ford F 150 as a towing vehicle
I plan on buying a Airstream 23 or 25 International. I currently own a Ford F 150 Supercrew with 5.4 engine and towing package. I also have an equalizer hitch. I live in a mountanious area and would appreciate any information or comments from people who own the F 150.
rgentry is offline   Reply With Quote
Old 01-19-2009, 07:47 AM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I have a 2001 SCREW with 96k it tows a 25 Safari fine. I tow in flat land and minor hills. In mountainous areas you will have to slow down and take your time. The newer SCREWS have more power.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 01-19-2009, 08:15 AM   #3
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We have a similarly outfitted F150, but using one depends on several factors.
1. What year is your F150? My understanding that older models don't carry what new ones will.
2. What is the weight of your Airstream? Our 1967 Sovereign weighs in at a whopping 4,650 dry, so not a huge problem for our F150, even here in the Rocky Mountains.
3. Is your F150 a long bed or short? It does make a difference.
Lynn
WBCCI 21043
Old 01-19-2009, 09:14 AM   #4
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Try to keep the GVW of the Airstream below 80% of the GVWR of the truck and you should be OK. Granted, if you are close to the 80% mark, you will not race to the top of the mountains and you will loose some power as you reach higher elevations.
My rule-of-thumb when selecting a diesel to tow our 30' Safari was up to 25', a 1/2 ton is sufficient, 25' and over, I wanted a 3/4 ton. You don't have to go diesel, you could go with an F-250 with the V-10 and have similar towing comfort and capacity. The only difference is that the gas engine will aspirate at elevation and the diesel won't...at least not nearly as soon.
BTW, I also have an Equal-i-zer brand hitch.
Family of Disney Fanatics
WBCCI# 4821
Old 01-19-2009, 09:17 AM   #5
holland , Michigan
Feel free to visit all my past postings regarding our 08 f150 towing nationwide a 28 safari. On the road currently going into Colorado, the damn thing is bullet proof.
safari 28 is offline   Reply With Quote
Old 01-19-2009, 10:14 AM   #6
1972 Travelux Princess 25
Cobourg , Ontario
There has been a lot of discussion on this subject. Your tow vehicle should be fine.
As you live in the mountains a lower gear ratio might be an advantage. A cheap easy way to get lower gearing is to install low profile tires. This not only makes your trailer draw easier, the stiffer tires have the added advantage of reducing side sway.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 01-21-2009, 07:45 AM   #7
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Locust Grove , Virginia
Images: 8
In '04, FOMOCO changed the 5.4 engine from a 2 valve per cylinder design to a 3 valve per cylinder setup. This boosted the HP rating up to 305 with a corresponding increase in torque. If your F-150 is '04 or newer, you won't have any problem. We've got a Safari 27 FBSE (actually 28' long) and have towed across the mountains without issue. The main thing is if you're on secondary roads, be careful of clearances (sides and overhead).
On the interstates, turn your OD off and take your time. As always, on long down grades, don't be shy about using the engine for braking by downshifting. This keeps you from burning out your breaks.
I believe even if you've got the older style motor, you should be ok.
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 01-21-2009, 08:10 AM   #8
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If a Tundra or my '08 Sequoia can tow a 28' no problem I don't see why you would have any problems with an F150. I should be a great TV.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 01-21-2009, 01:26 PM   #9
A properly equipped 150, with their best engine, will tow anything Airstream makes. The key word is "proper".
Anything else is a gross waste of money.
Old 01-21-2009, 01:29 PM   #10
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
I tow a 26' Argosy with the smaller 4.6 V-8 engine in an older '97 F-150. It handles the trailer well.
1997 F-150 4x4 short-bed (factory tow package)
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 01-21-2009, 02:35 PM   #11
I pulled a 30ft Excella (8000lbs) with my 1998 F 150 for six years, from Michigan to the West Coast and to the most southern point in the U.S.; Key West. As we are now "half timing" and because we needed a new truck and since the deals were irresistible we moved up to a F 250, 6.4 diesel. The difference is remarkable. As long as we were towing on the flat lands without head winds the F 150 was super but I recall the pull in and out of Lake Tahoe, CA. We have not experienced that struggle in the Appalacians and when we return out West I think the new tow vehicle will perform much differently
rtaylor537 is offline   Reply With Quote
Old 01-21-2009, 06:57 PM   #12
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
You should buy a chevy but otherwise you are ok equiped I just came home from WI in my chevy 1500 and had no problems and I have a 26ft and it was fulllllllllllllllllll...
shermantic is offline   Reply With Quote
Old 01-21-2009, 07:20 PM   #13
That is an excellent tow vehicle as well.
It's not necessarily what you buy, it'a how do you equip it.
Transmission oil coolers, are always far better than anything any factory installs.
Old 01-21-2009, 09:00 PM   #14
purman's Avatar
1968 28' Ambassador
I'm with Andy on this one. Look at the tow package and see what you are getting, and the gages you are also getting. If you move up to a 3/4 ton you will have more power but less of a ride when not towing the trailer, or even towing it. Now the 1/2 tons come with pretty big engines with lots of torque.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Ford F-250 as a Towing Vehicle nickmeloy Tow Vehicles 78 04-07-2009 02:46 PM
2009 Ford F-150 SilverCabin Tow Vehicles 18 11-27-2008 07:36 AM
Ford 150 Over Drive woodedareas Tow Vehicles 20 07-29-2007 02:42 PM
Ford F-150 As a Tow Vehicle Cstar Tow Vehicles 16 05-02-2004 07:24 AM
Ford E 150 brunoffrance Tow Vehicles 23 10-27-2003 05:55 PM
