Old 05-22-2016, 09:24 PM   #1
Mcwey's Avatar
2008 30' Classic
Fort Collins , Colorado
Ford Eco6
Anyone out there pulling a Airstream 30' Classic with the Eco 6.
We use it to pull out 25' Classic and it is a dream. We are about
to move to a 30' and not sure if the extra 1000 lbs will make a difference?
Mcwey is offline   Reply With Quote
Old 05-23-2016, 10:40 AM   #2
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
That depends on how your F-150 is equipped. Rear end ratio is most important and the 3.73 is the better than the 3.55 along with the HD springs, etc. You might consider adding a set of Firestone air bags to the rear springs that will aid in leveling once you are hooked up. Power wise you should have no problems unless you have a really high rear end ratio and that will only affect you in the mountains.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 05-23-2016, 10:59 AM   #3
Missouri Valley , Iowa
Mcwey, We are towing an '02 30' Classic w / slide. Empty weight about 8,400# and loaded around 9,000#. We towed many miles with our '10 F150 and the 5.4L engine. We updated to a '15 F150 with the 3.5 Ecoboost, 3.31 rear end and 6 spd tranny. There is NO comparison in the performance of these two engines. The Eco is far and above the 5.4 !!! In areas requiring a downshift the Eco is usually a gear higher and 1,000 rpm less than the 5.4.
Dan
Farmer Dan is offline   Reply With Quote
Old 05-23-2016, 11:00 AM   #4
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We did when we went from 25' to 30' and we (I) was not satisfied with the handling of the F150 nor it's braking ability so we traded to an F250. Then sold everything, and a year later bought a new 30' AS and an F350. The F250 is more than enough and did great, got the F350 just because, bought at same price as they were going to charge me for an F250, because I asked.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 05-23-2016, 12:10 PM   #5
Mcwey's Avatar
2008 30' Classic
Thanks so much for the feedback! I do have the tow package
so I should be good!
Thanks again.
Monty
Old 06-01-2016, 10:34 AM   #6
2012 25' FB Eddie Bauer
2009 19' International
Aptos , California
What kind of gas mileage do you folks get with those Eco6's pulling 30"ers (or whatever)?
brad1 is offline   Reply With Quote
Old 06-02-2016, 12:16 PM   #7
Brad, I get 8.5 - 9.5 mpg towing my 30' Classic which weighs about 9,000# with full water. I tow mostly on 4-lane roads and run faster than most folks do. On interstates I will tow at 72-73 mph and get the mpg I mentioned. It will tow with much better performance than my previous '10 F150 with the 5.4L engine. BTW, my mileage with the 5.4 was similar.
Dan
Old 06-02-2016, 12:37 PM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Goodyear 15" Marathon ST tires are speed limited per the data on the side wall of the tire to 65 mph.
Those that have converted to the Michelin 15" or 16" tires do not have a speed restriction on the sidewall of the tire.
Old 06-02-2016, 01:48 PM   #9
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
teach me, please
So, what are my risks, when I glance down and see that I am exceeding 65 by 5-7 mph? I like to run at 65-68 mph, however, this does happen unintentionally as well as intentionally, like when needing to pass a slow vehicle. I guess that I've always assumed that a fudge factor would be built in for these types of scenarios.
Susan
duncans is offline   Reply With Quote
Old 06-04-2016, 08:55 AM   #10
switz's Avatar
2014 31' Classic
Images: 8
Faster speeds = hotter tires. Hotter tires litter the road sides.....
Old 07-17-2016, 11:04 AM   #11
2016 30' Classic
Houston , Texas
I appreciate your questions as I was in the exact same place approximately one year ago as I needed to order a TV in preparation for a to be order a 2016 AS Classic. I went with a 2015 Ford F150 EcoBoost 3.5L V-6 importantly with a 3.55 rear axel ratio. My research at the time indicated that this particular engine / axle ratio had a maximum towing capacity of 12,000 lbs. I also ordered the max tow package, the 36 gallon gas tank and the power telescoping mirrors (similar to that seen on F250s). So far, so good. Good luck with your decision.
dhroberts is offline   Reply With Quote
Old 07-17-2016, 05:37 PM   #12
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
We're not pulling a 30', but have a 2014 F150 Ecoboost with 3.73 rear end and HD tow package pulling a 28'. Added the Firestone airbags in the rear and that allowed the truck to be levelled out after hitching. We travelled about 100,000 km with this combo in the last 1.5 years and it has been flawless. We have covered everything from high mountain passes to both coasts and the central plains.
In another year or so I will look really hard at a new F150 once again.....
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Towing With a 1974 Ford F100 melprice Tow Vehicles 18 04-01-2014 06:34 PM
1989 370 Ford 460 Overheating ViewRVs Mechanics Corner - Engines, Transmission & More... 14 07-05-2004 03:46 PM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 08:33 AM
Airstream Puller - with Ford TD FrankR Tow Vehicles 0 05-16-2002 10:45 PM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
