Old 11-19-2008, 01:33 PM   #1
sigv's Avatar
1963 24' Tradewind
Pittsford , New York
Ford e250/e350 Vans - anybody have one - what are your impressions
I am thinking of purchasing a 2008 Ford e350 12 Passanger Van. Does anybody have one of these?
What kind of mileage do you get?
How does it tow?
How do you like it?
sigv is offline   Reply With Quote
Old 11-19-2008, 04:30 PM   #2
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I have been around them. I have owned 2 vans, Chevy and Ford. They where both Half tons. The Ford was by far a better Tow vehicle. The Chevy got better MPG.
My Advice, Either rent one from enterprise ( they keep them instock for Airport transportation) or Call a local limo/airport transportation co. Ask them what you want to know.
The older Fords where great for towing but didnt get good MPG. That was the old push rod engine. The new engines are alot different.
mustang is offline   Reply With Quote
Old 11-19-2008, 04:31 PM   #3
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Consider an E450 dually mini motorhome if you can find one inexpensively. They're a superior tow vehicle.
Roger
Old 11-19-2008, 05:03 PM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by 85MH325 View Post
Consider an E450 dually mini motorhome if you can find one inexpensively. They're a superior tow vehicle.Roger
Heah,.....but
Roger is quite correct, but there are a couple of downsides. For whatever reason most of the Ford MiniMoHo's have the V-10 gasoline engine - but, the gasser only option minimizes the 7.3/6.0/6.4 diesel problems and debates.
A real problem (for my uses, anyway) is that anything over the length of a "shortie" full size van is a real bugger to handle and back the trailer into a typical State Park site.
The 450 is a bit of a different animal since it is a much more robust vehicle, but the different trailer handling characteristics between a 150 short and extended van (due to the distance from the axle to the hitch) is very real and very severe - so, if you go the conventional e-250/350 approach, stick with the 9 passenger (non extended) version.
I currently use a 3/4 ton shortie Dodge van as my tow vehicle, but, should an opportunity come along for an upgrade, I would seriously look at options. I have owned a 1 ton extended Dodge in the past - what a rough ride! I currently use a 1/2 ton Ford shortie van as my daily driver - great ride and handles well. I have towed the 31 foot Sovereign with the Ford from time to time, and the 3/4 ton Dodge, even though all of the specifications and sizes are VERY similar to the Ford, does a much better job overall.
I do have to add that the Dodge ride, unloaded, is a bit harsh, but settles down nicely once loaded for travel with the Reese weight distribution system adjusted properly.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-19-2008, 05:47 PM   #5
1994 30' Excella
Mississauga , Ontario
The e350 has a longer(18 inches) overhang at the hitch point. They make the body longer not the wheelbase. They always advise to keep the rear overhang as short as possible.
Also the 350 has heavy duty suspension and that might make for a harsh ride.
I tow a 31 footer with a e 150 with a 5.4 gasser.
Works fine. When I get a new one it will be the same but I will get the 3.73 rear end ratio not the 3.55 that this one has.
Al
Old 11-19-2008, 07:16 PM   #6
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
BigAl is right on the extended body. Stick with the 10 passenger, the overhang on the 12 passenger will crush the front side trailer segment and will limit your turning radius, and require more weight distribution.
Michael
ArtStream is offline   Reply With Quote
Old 11-19-2008, 11:02 PM   #7
2008 28' International CCD
Renton , Washington
I have one
We bought a 2006 350 last year specifically to tow the airstream. Got 11mpg on the last trip over 600mi round trip with the 5.4l engine. Ours is the shorter 12pass model, most people remove the rear seat for space. Love it.
holmestk is offline   Reply With Quote
Old 11-20-2008, 03:00 AM   #8
sigv's Avatar
1963 24' Tradewind
What is inexpensive?
Roger
What would be a good cost for this in your opinion?
Old 11-20-2008, 03:03 AM   #9
sigv's Avatar
1963 24' Tradewind
Clarification
Holmes,
Does yours have the extended overhang? I think the shorter van is a 9 passenger? Do you have a picture (trying to figure out if the extended - ie 12 seater - is a-ok for towing).
Thanks!
Old 11-20-2008, 03:05 AM   #10
sigv's Avatar
1963 24' Tradewind
Crush?
Michael
Michael,
Thanks for the response - can you clarify about how that will crush the front segment? Isnt the hitch still off the rear bumper (no matter ho far that is from the rear wheels?)
-Sig
Old 11-20-2008, 06:05 AM   #11
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
I have a 2003 Sportsmobile RB. It works great for towing a 29' AS. 5.4 engine gets us over the highest passes with little strain. Gas: about 10 mpg.
Eagle & Bear is offline   Reply With Quote
Old 11-20-2008, 08:44 AM   #12
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Originally Posted by sigv View Post
Michael,
-Sig
Sig,
It has to do with the limited turning radius caused by the larger overhang and the pivot point (which are the rear wheels) I know, I have an e-350 and I can not make the same turn or have the same turning angle that other vehicles with less of an overhang.
Old 11-20-2008, 08:49 PM   #13
Renton , Washington
Holmes,
Thanks!
We have the shorter, and it is a 12 passenger. The longer one is a 15 passenger-- at least for 06 models like ours. Hard to tell since many people take out the last row, ours lives permanently in the garage and can "only" carry 9 people with seatbelts with the seat removed. FYI, we bought a lease return with 20K miles they can be good deals with the remainder of the 30K warranty to check things out. Make sure to get the rear heat and A/C.
The only colors we ever see in the regular 350 are blue/maroon/white/silver.
Old 11-22-2008, 08:43 AM   #14
sigv's Avatar
1963 24' Tradewind
How much room in the back
Thanks for the info. With the last row removed - how much space is there? ALso - what Kind of mileage are you getting (owing and not towing)?
-Sig
ford, van, e-350
Class B-190 Vans - engine size joysjoy600 Sprinter and B-van Forum 19 08-27-2015 01:22 PM
New VW Touareg initial impressions..... Silvertwinkie Tow Vehicles 126 04-10-2014 11:09 PM
First impressions... bobfowler Base Camp 3 11-18-2006 05:44 PM
GM recalling 155k Vans, Pickups and SUVs Silvertwinkie Off Topic Forum 0 02-10-2005 11:43 AM
Extended Vans till Tow Vehicles 20 01-30-2005 08:07 AM
