Old 03-28-2015, 01:41 AM   #43
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We cut off the 2012 Dodge 2500HD factory hitch (some reports of weld failures in the round weld joint to the frame) rated 1200 pounds and replaced it with a Curt 15049 rated 2,550 pounds tongue weight with no caveats) and a 17,000 pound trailer. Our Classic does not put the hitch close to either of those two limits.
Another advantage is that the Curt receiver opening was substantially lower and the complete Kelderman air bag suspension installation lowered the truck to level all the time with no sagging when connected, the ProPride adjustable hitch worked so the trail is only 1/4" low at the front.
Also added the Curt front hitch, just in case.
Old 03-29-2015, 10:11 AM   #44
gpt
2014 25' FB Flying Cloud
sequim , Washington
Originally Posted by Ampman View Post
gpt,
Trailer tongue weight hitch rating on the Ford F250 unit is 1250 lbs. with Weight Distribution and only 600 lbs. with out Weight Distribution.
ok, now i have some greater understanding of the limits. it was interesting for me to learn that using the 'sleeve' on the class V hitch reduces the weight capacity by 1/2 to the 1250#s you mentioned. i would also believe this weight reduction will also have something to do with what your hitch ball and assembly are rated at. i am not very worried about this, however, as nothing i have comes close to that limit.
gpt is offline   Reply With Quote
Old 03-29-2015, 03:35 PM   #45
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I probably read it wrong. I read a 2 1/2" square tube receiver bolted to a heavy duty pick up is capable of towing 17,000 pounds and can handle 1700 pounds tongue weight with weigh distribution.
Golly, I've seen a lot of skid steer and back hoes on heavy duty flat bed trailers being pulled by 3/4 ton pick ups with no weight distribution at all. I wouldn't think those folks worry about their receivers falling off.
David
Old 03-29-2015, 04:37 PM   #46
Storm Master
Ampman's Avatar
2005 25' Classic
The label on the factory hitch clearly states the limits. As a commercially licensed driver I know that it is the drivers responsibility to correctly load their rigs within the nameplate limits. The labeling probably gets the liability off of the manufacturer and solely on the operator. If the receiver hitches were able to actually be rated to what the truck can handle then the aftermarket hitch companies like Curt, Titan and others wouldn't be in business. Weak link on the trucks in my opinion. That's why I changed mine out.
Ampman is offline   Reply With Quote
Old 03-29-2015, 07:13 PM   #47
sparkymark's Avatar
2012 25' FB Eddie Bauer
laguna beach , California
Name:	ImageUploadedByAirstream Forums1427677834.107423.jpg
ID:	235150go with the 350, much more stable for towing especially with long wheelbase. Diesel has more power than you'll ever need and the descent control works well on steep grades...
Ford F-350 crew cab 4X4 diesel, 25' Jack Bauer edition AS
sparkymark is offline   Reply With Quote
Old 03-30-2015, 12:43 PM   #48
gpt
sequim , Washington
did some 6% and an 8% downhill this past week. i learned that by leaving the truck in cruise, it will downshift to try and maintain the speed you set. no need to have it in 'tow/haul' mode for this to work. pretty nifty feature.
Old 03-30-2015, 01:07 PM   #49
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks Ampman, you are right. I read my label on my receiver and was quite surprised at the derated loads when using a reducer sleeve. I can now see why you upgraded if you're towing heavy loads.
David
Old 03-30-2015, 04:21 PM   #50
Storm Master
Ampman's Avatar
2005 25' Classic
Crazy ain't it. Guess they figure no one ever reads the labels. But if it were to fail the entire responsibility is on the driver if the tongue weight exceeded the label rating. Down side is you can't even give the old receiver hitch away because nobody wants them. Going straight to the steel scrap yard. Safe travels.
2011 Ford F-250 Diesel Lariat 2WD 4 Door Crew Cab SWB AL Cap 31,000 Miles 64aggie Airstream Classifieds 0 09-12-2014 09:20 AM
2001 Ford F-250 Diesel 77Ambassador Airstream Classifieds 0 09-26-2013 04:46 AM
Ford 250 4x4 diesel mileage GaRoc Mechanics Corner - Engines, Transmission & More... 3 08-10-2011 07:59 AM
Ford 250 4x4 diesel westernviews Tow Vehicles 43 04-07-2007 06:10 AM
