Old 08-04-2007, 08:50 PM   #15
2003 25' Safari
spokane , Washington
ford exploder fire
and this is what it looks like when the fire gets going....
Name:	The Ford Exploder 014.jpg
wasafari is offline   Reply With Quote
Old 08-04-2007, 08:50 PM   #16
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally Posted by 2cowpokes
We were fortunate that the fire occurred during the daytime and we took quick action to prevent collateral damage to the A/S and nearby barn.
Others were not so lucky as there have been fatalities when the fires happened to vehicles in garages attached to homes.
Yea, I heard about those, but I am glad that all turned out well (in a matter of speaking) in your case, compared to what could have happened.
Old 08-04-2007, 08:51 PM   #17
Aluminut
2004 25' Safari
. , Illinois
That your truck?
Old 08-04-2007, 08:56 PM   #18
2003 25' Safari
nope, the DW's daily driver. It was at the dealer for some warranty work on the tranny when it sort of got hot......
Old 08-04-2007, 08:59 PM   #19
Aluminut
2004 25' Safari
. , Illinois
Puts a whole new meaning to a cooked trans! Shoulda had a better trans cooler!
Old 08-04-2007, 09:14 PM   #20
2003 25' Safari
if you look closely the trans cooler, radiator and ac condenser all melted. The fire was not transmission related, started suspiciously near the master cylinder.....
Old 08-04-2007, 10:03 PM   #21
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
To defend and condemn Ford
Hi, the problem is the criuse control "de-activation switch" [mounted on the master cylinder] that develops an internal leak, short, then fire. The first recall was to replace this switch and wire connector. [the original problem]The second recall was to replace the connector with one with an inline fuse. This is to protect the vehicle in the case that the switch leaks, causes high resistance, and then blows the fuse, thus preventing fire.
If you have fear of this happening to you, the best and easiest thing to do is to unplug the de-activation switch on the master cylinder. I personally, for the life of me, don't understand why Ford has to have power to this at all times; You only need power to this when in use.
And finally, as a Ford dealer employee, I / we have no information on what the third recall will entail. My guess is that Ford will fix the remaining vehicles with a fused connector / pigtail.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-04-2007, 10:29 PM   #22
_
Read all the details in our post #42 on the previous thread about the defective cruise-control switch recall
which is exactly why yet another thread on this issue wasn't needed.
http://www.airforums.com/forums/f463...all-17027.html
this string of posts should just be tacked on to the thread stef started last summer....
that would be the most useful thing for those that NEED to know about the recall details.
cheers
2air'
Old 08-05-2007, 07:00 AM   #23
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by Stefrobrts
Using the cruise control doesn't cause the fire. As I understand it there is a pressure switch on the master cylinder that turns off the cruise control when the brakes are pressed. Stepping on the brakes increases the fluid pressure against a thin diaphragm in the switch. If that diaphragm ruptures, brake fluid will contact the electrical connection in the switch, causing a short, which causes the fire. The wiring in the switch is 'hot' all the time, even when the ignition is off. That is why it can happen even while the car is parked (and it has happened to cars parked in the garage, causing damage to the garage and house as well).
Happened to my neighbor, he was luck and caught it before it burned down the warehouse the truck was parked in. Totaled the truck, he now has a brand new Toyota in his driveway. I have two fires waiting to happen parked in my driveway.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-05-2007, 10:47 AM   #24
tpi
Trabuco Canyon , California
What value fuse do you think appropriate? Something which will accept the normal loads of the circuit but will blow before it will get too hot. 2 amp?
tpi is offline   Reply With Quote
Old 08-05-2007, 11:20 AM   #25
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
cheers
2air'
OMG The thread police caught me. This was a new turn of recalls that Ford finally admitted was and still is a big issue with these vehicles. I felt it was important enough to warrent it's own thread. If the MODS feel it should be combined then have at it. Just wanted to keep those interested up to date on the latest developments.
Now - back on topic. I went out to look at mine - 2002 F250 - that according to all the published data is not in the recall lists, and it is the same exact model sensor on the recall vehicles. It is now disconnected and awaiting a look by the dealer.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-15-2007, 05:35 PM   #26
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Another news item on this subject....
Ford recalling millions of vehicles because of faulty switches - CNN.com
New BAD news.....
Old 08-16-2007, 07:04 AM   #27
Aluminut
2004 25' Safari
. , Illinois
Here was the story that I read a while back (that CNN now posted recently) about the man that lost his wife where he claimed the truck started the fire:
http://www.cnn.com/2007/US/08/15/ford.recall/index.html
Old 08-16-2007, 08:47 AM   #28
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Originally Posted by Silvertwinkie
Though I'm not a Ford fan, I sure hope this doens't put them over the edge. Things are bad all around the domestic camps nowadays, but Ford, unlike GM and Diamler/Chrysler feels the pain easier than the other two, though that is not saying all that much.
You wonder how much red ink one company can endure?
As much red ink as we will buy for them. Ford Mfg has been a loser for a loooong time. The saving grace for Ford is their financing, Ford Motor Credit Corp is the breadwinner.
Having been involved in a lawsuit with Ford, professional witnesses and public information stock figures, demonstrates that Ford MFG is losing money everyday in a huge way. But FMMC is making 2.2 million dollars EVERY day.
I think my opinion of Ford is also public information on this thread. No fires in my driveway EVER!
smily is offline   Reply With Quote
1989 370 Ford 460 Overheating ViewRVs Mechanics Corner - Engines, Transmission & More... 14 07-05-2004 03:46 PM
Ultrasonic Pest Control Cracker Our Community 5 04-19-2004 12:50 PM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 08:33 AM
Control Panel indicators smily Electrical - Systems, Generators, Batteries & Solar 3 07-26-2002 03:55 PM
Cruise Control Servo Diaphram zamboni Airstream Motorhome Forums 5 06-26-2002 09:14 PM
