Old 08-18-2019, 08:18 AM   #61
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
I thought hard about getting the diesel but went with the V8 10-Speed. I have loads of downhill engine braking and average about 13 mpg. Also, my F-150 V8 Platinum has 500 pounds more payload capacity than my friendís F-150 Diesel Lariat.
ĒTurn off the truckís anti-sway control.Ē I haven't heard that before. What is the thought behind that?
Randy
Randy and Pat Godfrey
Florida Airstream Club (027)
WBAC# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 08-19-2019, 07:56 AM   #62
2019 26' Flying Cloud
Mary Esther , Florida
Randy
According to my hitch manufacturer, and a couple of other threads I've read, the sway control built into the truck is brake driven, i.e., the truck's computer applies trailer braking effort when it senses sway. If you have a sway control hitch, that might actually cause your sway control to overreact in the opposite direction, which I suppose would trigger an equal but opposite reaction from the Ford's sway control, and you soon might have control issues. You might have a different experience with your hitch, so just be aware and alert.
Sandspur is offline   Reply With Quote
Old 08-19-2019, 09:46 AM   #63
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
I have herd this comment a few times over the years, and also herd from the Ford techs it is not true. Run with your sway control engaged is what I was told by a few "experts". I can tell you with my F150 pulling a 25'AS with a BO hitch with sway control, I had an occasion where I was going 65 and had to swerve radically to avoid a speeding car coming up on my right side. Ended up in the center dirt divider and was able to ease back onto the pavement. The antisway "system" worked as advertised. I run with it on all the time...never concerned.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 08-20-2019, 07:13 AM   #64
2019 25' International
Washington , Washington, D.C.
The sway control feature on my F-150 has worked as advertised. I never turn it off.
PatLee is offline   Reply With Quote
Old 09-06-2019, 07:01 AM   #65
Bradenton , Florida
I bought a 2018 F-150 3.0L Turbo diesel w/ crew cab and 6.5 bed. It is rated for 10400 tow and 2000 load.
I pulled a 21' foot Soveriegn (~5000lbs) and didn't notice it back there. The diesel weighs 400lbs more than other engines, but I don't think the vehicle weight reduction is that significant on a 5000lbs truck. On flat ground it tows 5000 and gets 15.8 mpg at 70mph.
KevinFH is offline   Reply With Quote
Old 09-06-2019, 07:26 AM   #66
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
That is really interesting. I may start looking for a used one. I didnít realize you could get 2,000 lb payload. Is your empty mpg somewhere near 25? Also, how are they holding up in terms of trouble free operation?
Thx
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 09-07-2019, 05:48 AM   #67
Bradenton , Florida
I get in excess of 25 on the flat at 70mph. The non-4x4 versions get 30! My truck has 3.55 gears.
As far as that payload goes, there is only 1200 left after you hitch a 27 or 28' airstream trailer.
Old 09-07-2019, 07:01 AM   #68
GettinAway's Avatar
That’s more than my Tundra. It starts at around 1,400. (If I remember correctly)
Thx
2011 FC 23FB
Old 09-07-2019, 08:38 AM   #69
gypsydad's Avatar
Impressive data; my 28' TW weighs in at 1100lbs, so with my gear (generator, kayaks, camping gear, grill's) I would be at top of payload, and towing 7K loaded...will be interesting to see performance going up/down 8% grades pulling your 23'...still, impressive data on what you posted.
Curious whyt the diesel vs the Ecoboost for the F150? Cost of the diesel is going to be pretty high...I know on my current F250 diesel, it was way cheaper running the F150 EB for all around driving and maintenance. Of course, going up/down 7-9% grades pulling the 28'; the diesel is the way to go for sure!
Old 09-07-2019, 08:55 AM   #70
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Thats an impressive payload for this truck. So just to confirm, the yellow sticker on your door frame indicates 2000 lbs payload? I found it very difficult to find F150s with 1800 payload with a gas engine unless you order one with the max payload option that is available in very limitted configurations. What trim level and tow options do you have?
Frank & Fran
2016 27' FC FB with 400 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 09-09-2019, 11:54 AM   #71
Bradenton , Florida
You are correct, ~1400lbs is the yellow sticker ... it subtracts-out over 400lbs for the engine. But true, too impressive for correct.
On the other hand I have gone over brigdes (say over the Caloosahatchie bridge near FT Myers) and at 70MPH with a 21' 5000lbs trailer in cruise control, the truck crosses the bridge without downshifting.
I drove to Miami from Bradenton on Saturday, no trailer, cruise at 75 and averaged 25.6 when I arrived.
Old 09-10-2019, 01:47 PM   #72
Viera , Florida
So you donít have a payload capacity of 2,000 lbs, only 1,400 lbs. Thatís all you can safely load in the truck: you, the wife, the kids, the dogs, camping stuff and about 80% of the tongue weight. Also, most trailer tires arenít rated for speeds over 65. Stay safe. Impressive mileage numbers though.
Old 09-11-2019, 12:36 PM   #73
gypsydad's Avatar
Thought that payload of 2000# was too good to be true on the new F150 Diesel! By the way, the GY Endurance trailer tires are rated at 87mph.
New 2008 Ford Super Duty Pick Ups TomR Tow Vehicles 27 11-21-2006 12:06 AM
UPS Man rebel beck Off Topic Forum 16 11-20-2006 05:21 PM
West Cheap or Free Hook-ups - MT CTHilmo Boondocking 3 04-09-2006 09:45 AM
aaaaaaRRRRGGGGG! I hate UPS RichardT General Motorhome Topics 36 11-10-2005 03:52 PM
