Old 06-28-2008, 12:28 PM   #1
Jephellis's Avatar
1959 18' "Footer"
Carbondale , Colorado
Images: 48
FJ Cruiser wiring
Hi there,
Anyone out there towing with an FJ Cruiser? I'm pulling my Airstream with a 4-wire hook up, bought the converter (I think that's what it's called) which plugs in down to the left of my clutch pedal. I did not attached the bracket of the converter to the floor panel as the directions instructed (I could not fit my hands and tool down there!) it's just dangling but plugged in correctly, don't know if that's a problem. I then plugged the actual 4-wire connection at the rear. I have re-wired the trailer and made certain that the brake lights, the blinkers, and running lights work properly on the traler's end and they do.
For some reason there is a touchy connection coming from my vehicle, my right blinker and brake do not work unless I wiggle the connection at the rear anmd sometimes it doesn't at all. I also wonder if the converter connection is a problem. I did spray electrical cleaner on each connection as well.
I'd much rather get around to the fun stuff like restoring the interior, re-building cabinets etc...
Any thoughts?
Thanks y'all
Jeph
Jephellis is offline   Reply With Quote
1952 Cruiser - please help! mccannrd Member Introductions 9 10-24-2007 12:54 AM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 07:11 AM
'52 Cruiser Cruiser 1950 - 1958 Cruiser 4 10-26-2003 06:10 PM
Did I just buy a '57 Cruiser?? Rog0525 Our Community 16 05-06-2003 10:05 PM
'52 Cruiser Cruiser 1950 - 1958 Cruiser 3 09-07-2002 08:27 PM
