Old 09-10-2019, 07:20 PM   #1
DewTheDew's Avatar
2017 27' Flying Cloud
Frederick , Maryland
First weigh of truck and AS
My first visit to the CAT scales! The app made it easy. Looking for some opinions (I know there is no one here with opinions, right??) and thoughts on these numbers.
Vehicles: F150 with 7000 GVWR, front axle is 3525lb capacity, rear axle is 3800lb capacity. AS has 7600lb GVWR.
Conditions: 1 1/2 propane tanks, full water tank (39 gal) plus full water heater, nearly full gas tank on the truck. I was not in the truck but my wife was. I purposely loaded the truck up as I now that is my "weak spot" and with me in I'm probably over the weight.
First image is all hitched in towing condition, second is with the WD bars (Equalizer) removed, the third is the truck by itself (F/R) and the AS by itself.
Looks like I am about on the limit with my truck. Looks like I could perhaps transfer a bit more weight to the front? Would that be worth it or is the adjustment going to be more coarse than what I might want (perhaps 100lbs is what I'd want). Seems like the hitch is set up okay now, though, with nearly all the weight returning to the front.
I'm not sure how to read this but I think the hitch weight would be 940lbs (7040 trailer weight by itself, 6100 when hitched with no WD). The geometry is off, though, so I'm not sure.
Anyway, any comments or thoughts? Other than "should have bought a F250" :-) Thanks!
DewTheDew is offline   Reply With Quote
Old 09-10-2019, 08:26 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
It looks good to me. How does it drive? My experience is that you can transfer too much weight back to the front. So I would leave it just like that unless there is a problem. Good job.
Bill M. is online now   Reply With Quote
Old 09-10-2019, 08:37 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I think you are good.
Tow enough to get a feel for it, then fine tune as necessary.
ps:
My quick check each time I hook up the trailer is to measure the height of the front fenders above the center of the wheel spindle. My goal is to return enough weight to the tow vehicle's front axle to get the fenders down to that unloaded position. I do this so that the truck will have the same front axle weight as when unloaded and hopefully steer similarly.
ps2:
What is the axel weight of your truck's front axle when not hitched to the trailer? That would be the weight I think you should try to return to.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 09-10-2019, 09:51 PM   #4
Jim J's Avatar
2014 30' Flying Cloud
Austin , jhjohnstone
Images: 90
Slightly over GVWR
If truck GVWR ia 7000 lb and you are at 6940 before you get in the truck, you will probably be over the GVWR by about 100 lb once you get in.
I think your weight distribution is going to be OK once you are in the truck.
Move some stuff from the bed of the truck to the trailer or just leave it home to get your truck weight under its GVWR.
Jim J is offline   Reply With Quote
Old 09-11-2019, 03:22 AM   #5
Baltimore , Maryland
Too much weight removed from the rear axle of the truck.
Profxd is offline   Reply With Quote
Old 09-11-2019, 04:26 AM   #6
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
looks as good as it can get, you face the same problem we did, our F150 did a wonderful job and felt very stable and secure, but we were right against the rear axle rating and need to be able to load more
rbs is offline   Reply With Quote
Old 09-11-2019, 08:24 AM   #7
2020 Classic 33 on order
Box Elder , South Dakota
Dew how about the weights for just the truck? Also check your owner's manual or trailer guide for how much to restore to the front axle. A blanket statement of restoring to the unloaded truck weight is not correct. Example my last GM/GMC says 50%. Others are 100%. Get the facts for your particular truck.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 09-11-2019, 08:43 AM   #8
California , MD
Also consider the placement of your Grey/Black tanks. If in front of the axles, they will add to the load on the truck.
cru-in is offline   Reply With Quote
Old 09-11-2019, 08:44 AM   #9
California , MD
If I understand your numbers, they show your WD is transferring about 120 pounds to the trailer axles.
Old 09-11-2019, 09:26 AM   #10
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
It looks good on first review, but I have a question...
Generally, the "truck only" pass is just that... the truck all by itself with just two weights -- the steer and drive axles -- with the trailer reading zero. From that, the gross weight of the trailer can be calculated by subtracting the truck only weight from either of the other two passes.
For clarity, was your third pass done by driving onto the scales then unhitching the trailer and calling for the weight? Can we assume that the jack of the trailer was on the trailer scale pad along with the four tires? Was the Equal-I-zer attached to the truck for that third pass, or sitting on the trailer scale pad?
GammaDog is offline   Reply With Quote
Old 09-11-2019, 10:05 AM   #11
Happy Camper
nipperguy's Avatar
2018 30' Classic
Flat Rock , North Carolina
Send a message via AIM to nipperguy
Agree with others—about as good as you’ll get with that truck. Although you could potentially move some cargo from your truck to the Airstream.
nipperguy is offline   Reply With Quote
Old 09-11-2019, 04:34 PM   #12
DewTheDew's Avatar
Yes; for the third pass the trailer was completely on one of the pads with the front leg down. The truck was by itself; front axle on one pad and back axle on the second.
I did the following to do the three weights: first one I just pulled on and made sure the front axle, rear axle and two AS axles were each on a different pad. For the second sheet I just pulled off the WD hitch bars (so the truck was sagging in the back). Then, since it was already hooked up, I just backed the truck up until the trailer was all the way on the back pad, put the leg down and unhitched, then pulled the truck forward again.
Old 09-11-2019, 04:35 PM   #13
DewTheDew's Avatar
Oh, and the bars were off to the side of the scale and the big ball hitch was on the truck for the last sheet.
Old 09-11-2019, 04:39 PM   #14
DewTheDew's Avatar
ps:
ps2:
Thank you for the comments. I did do the height measurement last spring just to make sure I was in the right ballpark and I was (the hitch was set up by Colonial in NJ and they have a solid reputation).
The bottom (third) sheet was the truck unhitched; 60 pounds heavier than the top (first) sheet where I had the truck hitched with the WD set. So hitching the AS with the WD hitch means the front is 60 lbs lighter than the truck by itself.
I will say that certainly when the fresh water tank isn't full everything handles wonderfully. With the water tank full it still steers and stops well but I notice a little more porpoising.
First time CAT Scale Weigh desertpilot Towing, Tow Vehicles & Hitches 4 07-08-2018 06:43 PM
Why weigh our vehicles - first topic TONGUE WEIGHT A W Warn Towing, Tow Vehicles & Hitches 25 09-21-2015 08:42 PM
How much does a '76 - 31ft Sovereign REALLY weigh? 72Blazerod 1974 - 1979 Sovereign 11 05-16-2006 01:13 AM
OK- what does your A/S weigh & what's your tow vehicle John Our Community 17 03-19-2003 10:38 AM
Truck Weigh Stations, Safety Lanes & Mandatory PullOvers hex Towing, Tow Vehicles & Hitches 2 11-23-2002 10:29 PM
