Old 02-16-2010, 01:38 PM   #1
Ottawa , ON
Exclamation Fire danger in older Ford vehicles
Note: I had a quick look on the forums, and didnt see mention of this issue, but the January Consumers Reports has an article on it. Looks like Toyota isn't alone in having large problems. 16 MILLION vehicles being recalled!? Wowsa!
[Edit: I must be going blind, there already was a thread on this. However, the info I posted here was in the January 2010 issue of CR, and so may contain different model information]
__________________________________________________ _____________________________________________
The National Highway Traffic Safety Administration has added another 4.5 million Ford vehicles to the list of those previously recalled for a fire hazard.
This recall notice brings to about 16 million the number covered under a campaign to fix Ford vehicles. They all had a faulty cruise control deactivation switch, manufactured by Texas Instruments, that could leak hydraulic fluid, overheat, and cause a fire.
"These hazardous cruise control switches pose a safety risk even while the cruise control is not in use and vehicles are turned off or unattended," Transportation Secretary Ray LaHood said.
The latest recall
The following are part of the new safety campaign:
  • 1995-2003 Ford Windstars.
  • 2000-2003 Ford Excursion diesels.
  • 1993-1997 and 1999-2003 Ford F-Super Duty diesels.
  • 1992-2003 Ford Econolines.
  • 1995-2002 Ford Explorers and Mercury Mountaineers.
  • 1995-1997 and 2001-2003 Ford Rangers.
  • 1994 Ford F53 motor homes.
NHTSA says these warning signs could mean a problem is imminent: cruise control systems that stop working or can't be activated, brake lights that stop working, brake lights and ABS warning lights illuminating on the dashboard, or not being able to get a vehicle out of park.
The agency says that owners of recalled Ford vehicles should immediately make appointments with their dealers and not park their vehicles in garages or near homes until repairs are made.
Old 02-22-2010, 05:05 AM   #2
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
Ford didn't sweep this one under the rug and brag about how much money they saved doing so. Yes, it's big, but I'm betting the supplier bore the brunt of the cost--it didn't take the Ford tech long to swap it out in our F250.
IMO, CR publishing this older recall now may be an image damage recovery effort.
Maurice
Old 02-22-2010, 05:46 AM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
This has been a rolling recall. I had the unit in my 1997 F150 replaced in 2006. At that time they had all ready been replacing Crown Vic units and several other models. It looks like it has simply continued to expand.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 02-22-2010, 07:21 AM   #4
_
many threads on this going back 5-6 years...
here are 2 with details and gory pix and so on...
including WHO made the offending parts and WHY this stuff happened.
http://www.airforums.com/forums/f463...all-17027.html
http://www.airforums.com/forums/f463...all-34811.html
cheers
2air'
Old 02-22-2010, 07:29 AM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I haven't taken our 2000 F150 in because it doesn't have cruise control. Probably the one wise purchase decision we made in a while.
Lynn
WBCCI 21043
Old 02-22-2010, 09:39 AM   #6
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Ok Even my 94 F150 has the recall. I have not as of yet taken it in,but I have unhooked the plug from the switch on the master cylinder. My 2001 F350 is also in the recall.I have them both unhooked. The reason for this is this wiring is HOT all the time and this switch can overheat and catch fire even with the igniton off. There have been other vehicles and even homes destroyed because of this malfunction.
GITTER DONE
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
ford recall
FIRE! Electrical Short and Slide-Out Controller Fire rjd Electronics & Connectivity 10 07-24-2009 07:47 AM
Double door danger from the microwave nickcrowhurst Stoves, Ovens & Microwaves 8 03-04-2009 05:56 AM
FiRe, FiRe, FIRE, in the AiRsTrEaM!!!! TheBigRedTruck On The Road... 41 12-13-2008 10:29 PM
tow vehicles.... safari05-25 Tow Vehicles 9 11-06-2005 12:43 PM
Tow vehicles Inland RV Center, In Tow Vehicles 40 08-11-2005 08:49 PM
