07-02-2009, 07:54 AM
#21
Chief Chili Cook
2010 30' Flying Cloud
Bakersfield
Originally Posted by Road Ruler
Many of us on the forum here tow with cars and find it a great experience. In many cases with a professional set up they will be one of the best handling an safest tow vehicles money can buy.
The idea that a professionally setup car makes for a safer tow vehicle than, oh, say, a 1/2 ton or 3/4 ton crew cab long bed truck, or an SUV doesn't seem likely. Can a car be a safe tow vehicle, sure, up to a limit. Safest money can buy, no way.
The problem with using a car in this decade is that there are very few capable of, and fewer still of those professionals out there that can, setup a car properly for towing. A quick read of this thread might lead someone to believe they can just bolt some hitch to a unibody car, load the kids, hitch the trailer and go for it. http://www.airforums.com/forums/f44/...ign-38897.html
I'll bet the reason Hensley chose to use cars in that video was to show that less capable vehicles will tow better with their hitch.
I understand "everyone towed with cars" then. That's what they had. Let's please proceed carefully with advocating cars as tow vehicles for 31' trailers.
07-02-2009, 08:28 AM
#22
Retired.
, At Large
"Everyone towed with cars then" because "everyone had cars then". My grandfather told me to always use the right tool for the job. If all you have is a hammer, you'll treat everything like a nail.
07-02-2009, 08:42 AM
#23
Chief Chili Cook
Bakersfield
Yup, and those cars were massive body on frame vehicles build like the 1/2 ton trucks of today, plus a lower center of gravity. I don' think any one makes that kind of car anymore. In Wally's caravan photos, I see lots of trucks being used.
07-02-2009, 10:17 AM
#24
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I, too, would highly recommend a Suburban 2500 or the like. There are plenty of good used ones out there at a decent price.
Vintage automobiles as tow vehicles present a whole new set of potential problems. I own 4 vintage automobiles presently, so I know of what I speak. They need constant attention, and you better be able to do it yourself because there are very few shops out there that can work on them.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
07-02-2009, 11:18 AM
#25
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
And let us not forget all of the welded-on receiver hitch failures, and sway episode rollovers that happened with all those wonderful tow cars as well.
A modern setup is much more reliable and safer.
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
07-02-2009, 11:22 AM
#26
1992 34' Limited
Grand Island
, Nebraska
Since you mention not wanting to go with "an insanely expensive new truck" I think those who have recommended a Suburban are giving you the best advice. However, not all Suburbans will do the job you want. Check out the gear ratios and make sure you get a 3.73. A large engine will be more satisfactory even though you'll use more fuel. If it doesn't have a tow package be sure to have an auxiliary transmission cooler installed before doing any serious travel. On my last GM truck I had one installed even though it had a tow package and I never had any transmission troubles.
The soft market for SUVs makes it a good time to consider one. I have a friend who tried last fall to sell his extremely clean 3/4 ton with a 454 engine (I think it was a '96). He couldn't get $3000 for it so he gave it to his daughter and son-in-law. It would have made a great TV.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
07-02-2009, 11:37 AM
#27
2008 16' Safari
Destrehan
, Louisiana
The key factor is the frame of the car and it's engine size. You need a body on frame car or truck. Most cars today are uni-body. (the body and frame are one) A 1970's full size car with a heavy frame and big block engine would do fine. You have to use a load leveler hitch to do this.
OK, now the down side. An early 70's Cadillac with a 454 engine will only get about 9 mpg. Towing is worse. There is also the problems of keeping a vintage car on the road and running.
A better choice is a modern truck or SUV with the towing package. They get much better gas milage and parts are available. With a 31 foot trailer, you are still going to need a load leveler hitch.
My wife drives a Mercury Grand Marquis. You would think that would tow a big trailer but you would be wrong. The transmission is electronicaly controlled and is not profiled for towing heavy loads. There is no oil cooler. The engine is only 4.6L. If this car was offered with a tow package and a 7L engine it would be fine.
07-02-2009, 12:51 PM
#28
1977 27' Overlander
Trotwood
, Ohio
I have to vote with the majority here. Although I have a 1ton Crew 8ft bed Diesel it was not the original intent to pull our airstream,rather any trailer I want to pulled with a small dozer or backhoe. Be it has ended up being our # 1 mode of Transport getting 14 around town and 20 on the highway and about 16 /17 towing.
We have friends with a Ford E250 Van that does very well with thier 31 fter. So I think a BURB or 3/4 ton van of any description would do what you want.
The market on New and Used trucks and vans of this size is very soft rite now and its a buyers market.
GOOD LUCK
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
07-02-2009, 01:02 PM
#29
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison
, Michigan
We pull one your size with a Surburban....it's a great way to go!
07-02-2009, 01:29 PM
#30
Worldturners
1976 31' Sovereign
San Antonio
Our price point
Originally Posted by Maryw164
What's your price point? We can help keep an eye out for good deals.
Mary
Well, our price point . . . I didn't initially say, because it's embarrassingly low, but since you asked . . .
We are searching on ebay and craigslist for one $10,000 or under. We got out of debt, and we don't want to get back in, so we're planning to sell our current vehicles and only take out a small loan, if we have to, that we can pay back quickly.
Terry & Natasha Turner
'76, 31' Sovereign International Land Yacht
Remodel Madness
07-02-2009, 01:44 PM
#31
Worldturners
1976 31' Sovereign
San Antonio
Wow, that's a freaky thread. I have come to the conclusion that one should REALLY know what they are doing if they're looking for a CAR with which to tow! I am not that knowledgeable, and I'm not embarrassed to admit it!
- Natasha
Remodel Madness
07-02-2009, 01:52 PM
#32
1977 27' Overlander
1963 19' Globetrotter
Naples
If I ever get my GT finished,I plan to tow with my 66 GTO,I figure station wagon springs,and WD hitch it should be just fine.Dave
07-02-2009, 02:24 PM
#33
1977 31' Excella 500
Berkeley Springs
, West Virginia
Get a late 90's 3/4 ton Suburban 4x4 with the 8.1L V8 and towing package. I would bet most of the big block Suburbans like that came with that engine. It's just the newer iteration of the 454; 8.1 is a 496. It's a good engine.
A friend of mine bought a 2003 Suburban with the 8.1, 4x4, towing package, used with very low miles, for $13K. That was two years ago. You could probably pick that vehicle up right now for $10K. With three kids, I'd want the third row seat.
As for the Ford's with the V-10 gas engines; if you do buy one, make sure it's after 2003. Before that, the Triton engines had a defect (the roof of the combustion chamber was only threaded for about half its depth, so there were only about seven threads holding the spark plugs in) where they would spit spark plugs out of the head taking the threads and the coil pack with them. Ford wouldn't stand behind it either. I had a 2001, it blew the plug out of the head at 36,348 miles and I had a 7 year 100,000 mile powertrain warranty that the dealer sold me. Ford wouldn't cover the repair. I heard they fixed the design flaw in 2003. But anyway, don't buy one older than a 2004.
I repaired it myself and traded it off for a Dodge with the Cummins turbodiesel. I've been a happy camper ever since.
- Jim
07-02-2009, 02:52 PM
#34
Chief Chili Cook
Bakersfield
- Natasha
Natasha, get a vehicle that came with a towing package with a Class IV hitch. It's towing capacity will be documented in the manual (or online). Never exceed a vehicles stated towing capacity. Go camping.
07-02-2009, 03:03 PM
#35
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison
, Michigan
I agree with the the 3rd row seat. With 3 kids, and a friend once in awhile, it's the only way to go. It probably won't cost you any more on a used one. There is still all kinds of storage space behind the 3rd seat.
07-02-2009, 04:29 PM
#36
Iwannagocamping
Rineyville
, Kentucky
10 months ago when gas was just on the back of $4 a gallon, we picked up a 2004 Expedition, Eddie Bauer, 5.4 V8 with heavy duty towing package, 50k miles, for $15,000 cash, in anticipation of getting a TT, which turned out to be a ragged '79 Sovereign International, 700 miles from home. JUST got back from Kansas, pulled like a dream, got 10.5 mpg on the nose. Had cruise set around 62, never balked at a thing. Now we start rehab of the the AS, now known as "Toto"... I might look for an '05 if I was looking right now, they have a little more power and get a little better mileage.
07-02-2009, 05:27 PM
#37
I understand there are a few stationwagons that can handle a large TT, but you have to check the ratings always!
As you can see, there are about twice as many TV opinions as there are Airforums members. A lot of people won't tow with anything but the biggest vehicles out there. It probably is overkill in some circumstances. I see you have a 31' AS, so you are limited in what is available as far as size and power that will safely handle your trailer. Have you considered a full size van? You can get the weight and power you need and still have a good all-around vehicle for everyday driving. It also allows for plenty of seating, additional storage, and possibly another bed, if you get a van-conversion.
Good luck,
Rich
07-04-2009, 11:42 AM
#38
1999 27' Safari
Kent
, Ohio
I'm hitting craigslist and ebay for a TV. Right now we do not have one, and we will need to move our AS soon. We're planning to sell our two current vehicles.
Having the typical female attention span for all things mechanical , could anyone spell it out to me in easy, plain English: are there any family vehicles out there - modern or classic - that could pull (without damage to either) our 31' Sovereign?
We need a vehicle that seats five. We're trying to pass up the hopelessly ugly 20-year-old rusted, cracked trucks (don't want to shame the Airstream name) and the over-the-top insanely expensive new trucks . Is there an all-purpose vehicle out there?
- Natasha
Older Suburbans, crew cabs, station wagons? all good tow vehicles. Find one in the back of the Blue Berret, from an older couple not towing anymore, Local club meets? I stumble on nice older vehicles all the time, with fuel prices so high. DO these Airstream proud pull with American, you dont want to be stuck on the side of the road with a rice burning turd, with smoke bellowing out from under the hood. Then Billy Bob shows up with a tow truck chewing an spitting chew, about your grand mistake, thats on his hook.
07-24-2009, 08:36 PM
#39
Usually Sleepy
East Haven
, Connecticut
You could look to a 1995 Buick Roadmaster Wagon or Chevy Caprice Wagon. Big Body on Frame vehicles. Make sure set up with the factory tow package. I have great luck towing with mine. It's a long low suburban that rides like a Cadillac.
Skip
07-24-2009, 09:05 PM
#40
Vintage Kin
Fort Worth
No, they weren't body-on-frame; the majority of other-than-casual travelers were using UNIBODY Dodge, Chrysler & Plymouth and one reason they did is that the unibody is/was STRONGER than ANY body-on-frame car. Imperials were banned from demolition derby decades ago because they were indestructible.
And -- of any of the Big Three automaker cars -- the wheelbases ranged from 116" to 130" and weighed up to, or past, 4,000-lbs.
The current Dodge Charger/Chrysler 300 weighs 4,000-lbs, has a 120" wheelbase and is essentially a reworked Mercedes with fully independent suspension, 4-whl disc brakes and engine/transmission controls that any of us would have sold a relative in order to have back then.
Besides, for those who wanted trucks there were plenty of them out there, including Suburban & International.
Those old cars didn't all have giant engines either. Nor did everyone tow at 55 mph even with the "smaller" motors.
Wallys caravans were overseas adventures, were they not? Lots of dirt roads and slow travel where a truck makes more sense.
Airstreams were lightweight, with independent suspension, and DESIGNED to be towed behind a car. Keep the weight down on an older pre-1980 model and there is no reason it can't be done. And better than with a pickup truck which is the LEAST roadworthy vehicle possible. They're handy for the fulltimer carrying too much junk, but they steer, brake and handle terribly.
There is no perfect tow vehicle. No matter the brand of the next aluminum trailer I buy it will have disc brakes fitted and the best possible hitch . . just maybe that will keep my current 7,500-lb truck out of the ditch in those worst situations.
If Chrysler ever releases the 300 in the US with the powerful diesel engine it sells in Europe then that will be the best all-around tow vehicle available for one of these aero trailers (except for those who insist on carrying a snowmobile and Harley everywhere they go).
For a non-fulltimer a car makes perfect sense (as that person may see it), and who cares how much faster it wears? The original owner of few American cars or trucks keeps them long enough for that to matter. It was then, and now, part of the trade-off.
Growing up, we somehow all survived trips across the US and Canada in 4-door sedans and wagons. And they were easy to live with the the other 90% of miles traveled annually. 8-years, 100,000 miles or so and off to another car.
I'll grant that conventional thinking recommends other than a car. I'd look at an independently-suspended FORD Expedition and find the info that makes it a better tow vehicle (wide wheels and lower profile tires with adequate capacity, better shocks, anti-roll bars with poly bushings, BILSTEIN or KONI shocks, etc.). Andy Thomson of CAN AM RV has written extensively on the subject, here, other forums and in online magazines.
