Old 07-24-2009, 11:32 PM   #43
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Now I suppose I'm a bit biased having 8 children, but if I had known how useful the Ford E-350 15 pax van was 12 years ago, I'd have skipped the Ford Aerostar altogether.
We own a 2001 E-350 with a 7.3 Powerstroke but had a 1999 gas burner before that. The gas did okay with our 27' Overlander (before we upgraded to the "Strato-Bunkhouse Sovereign-sleeps 10) but stuggled a bit on grades. The PSD, with a 4" exhaust and mild performance chip, tows like a CSX train.
I am a huge fan of the E-350 because it is heavy duty, seats can be easily removed and used for cargo, and they are CHEAP used because no one but churches, daycares, and full sized families want them. Did I mention the huge 4-wheel disc brakes?
You can easily find one within your budget and they work well if you plan to enlarge your family. They can seem intimidating at first but my wife really prefers it because of the height advantage (she is only 5'2").
You just want to avoid pulling too many Gs on the corners in them. We've had an E-350 since 2001 with no incidents.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 07-27-2009, 08:27 AM   #44
connorsa's Avatar
Profile:  1999 34' Excella
Durango , Colorado
Yeah, this is my perfect thread! Just purchased a 1999 34' Excella. What is the best car type TV for her? A Surburban? A 2500 3/4 would work? Can I buy an older one if I find a good one? I just really don't want a truck.
Thanks!
connorsa is offline   Reply With Quote
Old 07-28-2009, 07:46 AM   #45
SARGE/AF's Avatar
Profile:  1976 31' Sovereign
Greeneville , Tennessee
3/4 Ton TV
Thanks!
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXX
Connorsa,
Any 3/4 ton whether it is a pickup, suburban, excursion, would work, If you find an older one in good condition or make one into good condition would work too, good part you can always find parts and fix yourself, drawback is depending on how old you are talking when you get back into the 70,80's you are going to be looking at a large engine like the 460,450, Etc and they are very poor on fuel, where if you get into the mid 90's and even up into the 2000's you will do a little better. But given the weight of the 34 especially after you add your stuff you would be much better with a diesel, plenty of torque, better fuel milage, lasts longer (500,000 miles compaired to 200,000 miles). As far as a pickup vs a suburban/excursion this will mostly depend on you, how many passengers, what you want to haul inside. On the work truck issue you can find trucks that are no different than most cars as far as interior.
I had pickups reg, extended, crew cabs, 6 1/2 & 8 FT beds, the bed is very handy as far as for bicycles, go carts, etc, the suburban on the other can do pretty much same as a pickup but you have more passenger room.
I currently have a 1976 Soviergn 31 FT, 07 GMC 1500 Ext Cab & 2005 Ford Excursion, I have found myself driving the Excursion all the time because of its multi use and passenger availability. There is 5 people, my wife, me, 3 grandchildren with a 4th that will be joining us next year. With it having the 6.0 Diesel I get decent fuel milage which is better than the GMC. Towing with the Excursion is a dream, with the 6.0 I have the torque to pull with and it rarely goes into passing gear because of the torque which saves on fuel, ware & tare on the vehicle itself. I have had a 34 footer attached to the excursion and it is like the trailer is not even there.
One thing I learned and did not know until I was looking into a suburban is on the Chev/GMC suburban is to watch for the LT or SL model, these are a light 1/2 ton or just a dailey driver and not made for towing, LT & SL stand for light truck.
The Excursion is Ford and is the same as a F250 except for the body from the front doors back, so parts from a matching F250 will fit it.
Sarge
SARGE/AF is offline   Reply With Quote
Old 07-28-2009, 10:26 AM   #46
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
Send a message via Yahoo to till
FWIW I tow with a 1991 Caprice wagon.
If you go with an older full size car (i.e. 1970's) you will run into repair issues. Not many places understand old American iron any more. Most mechanics these days don't know what to do with out a computer. :P
In your shoes, I would go with a Suburban.
Tedd Ill
AIR#3788
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 07-28-2009, 10:36 AM   #47
1972 Travelux Princess 25
Profile:  Cobourg , Ontario
Conorsa a 3/4 ton Suburban, Excursion or equivalent pickup truck should be perfect for you.
There is nothing wrong with buying a used tow vehicle as long as it is in good shape. Towing will stress the engine, cooling system, and brakes but if the vehicle is in good shape it won't matter.
Would suggest you add a transmission cooler and if necessary, new tires. If you do buy new tires it is a good idea to go to a lower profile tire. In other words the same size as the stock tire in width but smaller diameter. This has the effect of lowering your gear ratio and also reducing side sway.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 08-06-2009, 08:23 AM   #48
Profile:  2009 27' FB Flying Cloud
Fulltimer, so...wherever road takes us! , On the road!
Newbie here...and saw a Dodge Magnum SRT8 (6.1L Hemi engine) towing a 30ft. Am purchasing a 27fb. Need experienced opinions...will this work? I will be a full time live aboard. Single lady with 2 small dogs.
MissDaisy is offline   Reply With Quote
Old 08-06-2009, 08:37 AM   #49
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Sarge
With the exception of the rear spring stack which is "wiggly", especially with a 34' tri-axle. A set of Bilstein shocks, radius rods and a Helwig body anti-sway bar on the rear axle turns the Excursion into a monster tow machine. I did find after four years with my Excursion/tri-axle combo that a little longer wheelbase truck would have made me feel a little more secure towing.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
1994 Airstream B190 & 2006 Bigfoot 25B25RQ
Old 10-30-2009, 01:13 AM   #50
Profile:  1979 31' Sovereign
Seattle , Washington
I have a Buick Rivera, super charged, I am thinking about using as a tow vehichle. I would appreciate some thoughts before I put $$$ into the hitch. It's a beautivul car, looks a little like a Jag and runs like a top, but I don't know if it is heavy enough to do the job.
Sovereign42 is offline   Reply With Quote
Old 10-30-2009, 08:17 AM   #51
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
What does it say the tow rating for the car is in your owner's manual?
(No Longer at Inland RV)
Old 10-31-2009, 02:43 AM   #52
I did some research today and learned the Buick Riviera willl only handle 1000 lbs. That is far short of what I need.
Old 10-31-2009, 08:24 AM   #53
Profile:  2007 31' Classic
holland , Pennsylvania
only towing mods i made with my x,were timbrens and bilstiens.had the factory sway bars from the factory.no problem at all handling any trailer you want to hitch to it.with the airstream i use a hensley and the whole tow is effortless.many years ago i towed a 26 sob with a late 70s impala station wagon with a 350 v8.had to put heavier springs on the rear because i kept botttoming out.after that i have always towed with 1/2 or 3/4 ton trucks.with a 31 i beleive a 3/4 ton truck will make your travels much more pleasureable.
xonvldz is offline   Reply With Quote
family tow vehicle
car seats dickmonster General Motorhome Topics 12 01-02-2008 02:13 PM
Car Will Not Fit On Car Dolly! Chaplain Kent General Motorhome Topics 7 11-08-2006 05:46 PM
Charging with your car. Killo1 Electrical - Systems, Generators, Batteries & Solar 9 07-20-2006 08:12 AM
Can I pull a 31' Airstream with my '97 Tahoe? 72Blazerod Tow Vehicles 8 02-26-2006 05:43 AM
Car Ballooons 59toaster Off Topic Forum 6 02-04-2005 02:15 AM
