Old 04-27-2016, 08:33 PM   #1
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Fall 2017 - F150 with 10 speed and 411 hp/434 lb ft???
Based on these two articles the Raptor will have the 10 speed and high output ecoboost for 2017. Regular F150's will at least have the 10 speed by year end. I wonder if they will get the high output engine as well or if Ford will reserve them for the Raptor?
An XLT with these specs and over 2000 lbs payload sounds awesome!
http://www.inautonews.com/ford-intro...ode-in-beijing
http://www.autonews.com/article/20160426/OEM01/160429878/ford-to-invest-$1.4-billion-to-build-10-speed-transmissions-for-2017
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 05-04-2016, 12:13 AM   #2
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Looks like regular F150's will be 365 hp and 450 lb ft. Awesome!
https://youtu.be/tkScQN7fxGg
Old 05-04-2016, 01:10 AM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, and the second generation 3.5 L Ecoboost is virtually a completely new /different engine.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 05-04-2016, 02:32 AM   #4
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Yea. Saw that. Interesting that they have direct injection and conventional. I wonder if that's a tacit admission that direct injection is causing buildup issues for them and anyone everyone else using it?
Old 05-04-2016, 08:41 AM   #5
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
It may have to do with the stop/start technology.
kscherzi is offline   Reply With Quote
Old 05-04-2016, 09:31 AM   #6
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Possible. Does the new 3.5 have stop/start? I thought that was limited to the 2.7 but I could be wrong.
Old 05-04-2016, 11:25 AM   #7
kscherzi's Avatar
Images: 24
Yes. Ford says this new engine will. Just as the 2.7 does already. Coupled with the new transmission they are expecting a little better mpg.
Old 05-04-2016, 11:47 AM   #8
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Interesting. Not sure how I feel about that technology...
Old 05-04-2016, 01:09 PM   #9
FCStreamer's Avatar
2014 30' Flying Cloud
I'm constantly turning it off in my wife's car. It is annoying as heck. The silence when the engine turns off is creepy.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-04-2016, 02:03 PM   #10
DKB_SATX's Avatar
Alamo Heights , Texas
Turning on tow/haul disables the auto-start-stop thing. I don't know if sport mode on the transmission disables it or not, but on the 2.7s there's also a button to turn it off. However, you'd have to hit that every time you start the engine. You'd be surprised how quickly you get used to doing such a thing... the traction control on my '01 GTI was so terrible that I used it only when it was wet. It would chop the power for a LONG moment with just a tiny bit of slip, which can be the bad kind of exciting when making a left turn across traffic.
I think the port+direct injection addresses several issues. It improves emissions in some conditions (DI engines tend to have more particulates) and likely helps with buildup on the back side of the valves. I know Toyota uses it on some engines, I don't know what other companies might.
— David
DKB_SATX is online now   Reply With Quote
Old 05-04-2016, 02:17 PM   #11
DKB_SATX's Avatar
The announcement yesterday was that the 2nd gen 3.5EB+10spd will arrive THIS fall for the regular 2017 model F150s. The higher-output Ecoboost in the Raptor may be later availability. I don't think there'll be an option for the Raptor engine in regular F150s but all the 3.5EB trucks are supposed to have the 10-speed for the 2017 model year.
— David
Old 05-07-2016, 01:31 PM   #12
Vintage Kin
Fort Worth , Texas
Impressive. Hate the idea of rebuilding a 10/auto, but it sure ought to put that little motor constantly in the sweet spot.
Old 05-22-2016, 08:45 PM   #13
2011 27 FB International
Vancouver , British Columbia
Occasionally I poke around for info on the 2017 f150s, just found this pdf that shows only a 6 speed transmission Perhaps that will change.
http://www.fleet.ford.com/resources/...17%20F-150.pdf
mixedpuppy is offline   Reply With Quote
Old 05-22-2016, 08:50 PM   #14
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
The 8, 9 and 10 speed transmissions will be replace when broken in some brands. No field rebuilds. That thought reflects the tacit fact that there are few mechanics any more, just part changers.
Old 05-22-2016, 10:09 PM   #15
DKB_SATX's Avatar
My old 4-speed 4R75W from 2007 was treated as "replace with factory rebuilt" as well by the service-policy company. I'd honestly rather have a warranted rebuilt from a shop specializing in transmissions than roll the dice on a local wrenchape who may or may not be good at transmission rebuilds and may or may not have a clean place to put transmissions together.
— David
Old 05-23-2016, 10:09 AM   #16
kscherzi's Avatar
Images: 24
See this from the Ford Media Center.
https://media.ford.com/content/fordm...ter-boost.html
Old 05-23-2016, 10:46 AM   #17
DKB_SATX's Avatar
Adobe Acrobat Reader shows that file as having been created 21 March, so it's probably just that it came out a month before the public announcement of the 10-speed and Gen2 3.5L Ecoboost for the F150. Some guy in fleet marketing didn't have the "need to know" about the future announcement.
— David
1957 Calif. Airstream Overlander. 1/434 Elvis, Rock & Roll & The National Parks eBay Watch Airstreams on eBay 0 05-18-2012 08:50 PM
Oak Mtn St Park (Al)/ lincoln ParishPark (la)...any 411? Beer Snob On The Road... 2 04-29-2012 04:47 PM
1957 Calif. Airstream Overlander. 1/434 Elvis, Rock & Roll & The National Parks eBay Watch Airstreams on eBay 0 03-15-2012 10:10 PM
1957 Airstream Overlander Whale Tail. Orig Calif. Beautiful Body. 1 of 434 Built eBay Watch Airstreams on eBay 0 02-24-2012 08:00 PM
A/S serial # 434 in ATL tod47d Mechanics Corner - Engines, Transmission & More... 0 01-25-2003 08:44 PM
