Old 10-15-2012, 06:21 AM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
F250 vs F150 price
After researching and shopping for the last two month I am now at the decision point on a new vehicle.
I am looking at both vehicles and wondering which would be a better purchase.
Because of the discounts the F 250 diesel cost is not significantly more expensive then a special order F150 Lariet with ecobooster, max tow and HD. They are within 2000 of each which way should I go?
urnmor is offline   Reply With Quote
Old 10-15-2012, 07:28 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I tow a 25' with a 2500 diesel and love it. I would get the diesel. But I do not mind driving a truck.
Old 10-15-2012, 07:29 AM   #3
1981 31' Excella II
New Market , Alabama
If you are going to tow a lot in the mountains the Diesel will probably be the way to go. Maintenance will be higher on the Diesel and the higher price of fuel for the Diesel offsets and fuel saving you will get. It takes a lot of towing to justify the long term expense in terms of fuel savings with a diesel. The Ecoboost may actually get as good miliage as the Diesel. The Diesel won't slow down on hills and won't require reving the engine to get power out of it. A gas engine is made to rev and doing so won't hurt it. Both trucks are nice but how are you planning to use them? I see the F-150 as a daily driver that gets 20MPG that you can tow the trailer with on the weekends. I see the F-250 as more of a full time Tow Vehicle. The F-250 will last longer if all you do is tow 100k miles a year. If you tow 10k miles a year the F-150 is fine. That is my opinion.
Perry
Old 10-15-2012, 07:39 AM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by perryg114 View Post
What engine is in the F250?
Perry
Originally Posted by urnmor View Post
Because of the discounts the F 250 diesel ...
Diesel.
Vaughan
Old 10-15-2012, 07:41 AM   #5
1981 31' Excella II
Yeah I caught that bit of info later and edited my post.
Perry
Old 10-15-2012, 07:51 AM   #6
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I'd get the diesel.
I'd like the bigger brakes and suspension and while you pay .50 cents +/- per gallon you'll get another 5mpg ( at least I did.)
I have no experience with the eco boost so I don't know what it is like to tow with one. With my F250 I never once had the sensation of the trailer pushing or driving the truck.
If the truck will also be your daily driver I gotta admit the eco boost looks really good.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 10-15-2012, 08:11 AM   #7
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
I agree with the above EXCEPT that since both engines are turbo driven, both will do well in the mountains with your 25er. However, if you travel with more than two adults and tend to carry a LOT of gear, then you may be better off with the 250 based upon the GCVW. If not then the Ecoboost is a pleasure to drive and tow with.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 10-15-2012, 08:13 AM   #8
1997 34' Limited
Sarasota , Florida
My Purchase was a USED 2000 Ford F250 diesel, 7.3, in 2005. at the time we were towing a 30' across country. We later had a 34' and the fuel mileage dropped about 2mpg. Overall mileage towing ranged from 13 to 17mpg with some tankfuls as high as 19mpg. Mods: computer chip, larger intake and exhaust, all synthetic fluids. I have done as high as 25mpg hwy, NOT towing, but I like the truck and will keep it as my only vehicle, though not towing cross country anymore. (73 yrs old)
sahope8 is offline   Reply With Quote
Old 10-15-2012, 09:41 AM   #9
reinergirl's Avatar
Hollis , New Hampshire
The Ecoboost has a known engine problem involving water condensation from the intercooler getting into the engine causing violent shuddering and loss of power. There is plenty of info out there on the Ford forum and elsewhere. Last I heard, Ford didn't have a solution. I was considering this truck as my next vehicle, now not so much....
reinergirl is offline   Reply With Quote
Old 10-15-2012, 09:46 AM   #10
1983 34' Excella
1967 24' Tradewind
Images: 32
Perry
Yes, and you did a great job of summing up the pluses and minuses.
Vaughan
Old 10-15-2012, 10:16 AM   #11
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
The Ford issue I have been checking on myself. Basically it is all about driving in the rain for the most part. What happens is in a downpour, if the driver accelerates more aggressively the turbo sucks in some water, which, quickly turns to vapor but nonetheless causes sputtering and the check engine light to come on. They are testing a type of wind deflector to counteract the direct water issue and will be adding it to ecoboosts for customers.
I agree with the first post response. It depends on what you are going to do with the tow vehicle other times. My plan is to have one vehicle eventually. If that is your case then I would go with the ecoboost gas engine. I have a diesel car and like it; however, the diesel fuel is more expensive and a 250 is not a good a ride as the 150 for everyday and, it costs more. Either one will pull your AS. The only other difference is how much payload capacity you will need. The 2012 F-150 Supercrew 145" ecoboost 4x4 HDP payload is 2310lbs. minus your 835lb (or so) tongue weight and that leaves around 1470 lbs for stuff minus hitch weight. Also, look at the tow mileage info thread. It looks like most Airsteram owners on here who have gassers are getting around 12mpg while most diesel owners are getting about 14mpg. Of course there are some stating they have gotten 14 with their gas and 16 with their diesel but overall that is what it looks like. Also remember that diesel fuel costs 12-15% more than gas so in $$$ terms, consider that it must get 1.5 to 2 mpg better to break even just on fuel costs. There are other factors between diesel and gas but consider your other than towing needs.
Old 10-15-2012, 10:18 AM   #12
Wayward's Avatar
Cary , North Carolina
After towing a 25' with a 6.2L F250 with the new 6 speed for a couple of years now, I think it remains an often overlooked TV.
I do not miss our 3/4 ton diesel. The 6.2 motor combined with superb engine/tranny controller provides ample power and torque. Mountain towing is a pleasure with well placed upshifts, downshifts and torque converter lockup. Our XLT model was $27K.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-15-2012, 11:32 AM   #13
SteveH's Avatar
Common Sense , Texas
Just my opinion, but for $2K difference, I wouldn't even consider the EB 150.
I tow with a Diesel, and would not go back to gas.
Old 10-15-2012, 01:19 PM   #14
urnmor's Avatar
Berlin , Maryland
Thanks for the great responses. One point regarding fuel and price. Ford states to use premium fuel when towing with the ecobooster. Around here the price of diesel and premium run pretty mcuh the same with diesel currently being a little less expensive. So I have made fuel a wash in the equation because once I use premium I doubt that I would go back to regular.
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
F150 Ecoboost or F250 6.2L for 1968? Randy Gates 1965 - 1969 Globetrotter 25 06-16-2013 12:49 PM
Questions about towing a 25FB with a F-150 barrettjl Towing, Tow Vehicles & Hitches 32 03-13-2012 11:13 PM
1965 Globetrotter Advice on Selling Price guest234 Trailer Values 6 11-13-2011 08:33 AM
ordering our next TV - 2011 F150 EcoBoost jm2 Tow Vehicles 20 03-31-2011 05:29 PM
