Old 02-21-2009, 08:17 PM   #1
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
F250 question
Hi fellow F250 owners
I just had my 2008 F250 (diesel) 10,000 mile service done.
Driving from MV to LA I got this message dash
"cleaning exhaust filter".
I can't find this message anywhere in the owner's manual.
Any ideas before I call the service department on Monday?
Dennis
millvalleyca is offline   Reply With Quote
Old 02-21-2009, 08:43 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Cleaning Exhaust Filter? - Diesel Forum - The Diesel Stop.com
Old 02-21-2009, 09:12 PM   #3
2005 28' Safari
Mono City , California
Dennis
I am sure you know that your 2008 F250 is equipted with an exhaust system that has a DOC(diesel oxidation catalyst) and DPF(diesel particulate filter). The message is most likely indicating that the system is in a regeneration cycle, burning off the collected PM(particlate matter) collected in the DPF. Has the vehicle lost any power? If so the filter(DPF) maybe plugged with ash and other exhaust by-products. I am sure your vehicle still has low mileage and the PDF should not be plugged yet, unless you are having engine problems or if you are using the wrong engine oil. Check your owners manuaql for the correct oil classification, most use CJ4 oil. When you had it serviced did the service facility use the correct oil?
Good Luck
Tom
TBSarfari28 is offline   Reply With Quote
Old 02-21-2009, 09:58 PM   #4
Thanks Tom and Terry
So it's a "self clean" function"!
No lost of power...drove 1,000 miles and it performed great.
I assume they used the corect oil....Ford dealer where I bought the truck....
Dennis
Old 02-22-2009, 03:46 AM   #5
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Ford has (or very recently had, if it is still not in effect) a customer satisfaction program (something like a non-mandatory recall) to do a reflash on the 6.4's. You should have gotten a letter in the mail about this program. Your dealer may have done this reflash when you had your 10,000 mile service done.
This reflash results in the "cleaning exhaust filter" message during the period when your DPF is regenerating. Before this reflash, the message may not have shown during regen, or it may have been shown only briefly, depending on what Job number your truck was during the model year. (My 2008 F450 is Job #3, and this message on my truck was shown very briefly during regen.)
The regen occurs automatically whenever your DPF filter needs cleaning. Ford also says that when regen is occurring, you should continue to drive your truck at a minimum speed of (as I recall) 35mph, and it may take approx 20 minutes. Prior to this most recent reflash, I think Ford said you could shut down your engine during regen, and then restart it later.
Consult your dealer, or Ford for more specifics.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 02-22-2009, 03:56 AM   #6
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
When mine regenerated I had no idea what was going on. Lots of smoke blew out the exhaust for a couple of minutes.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 02-22-2009, 09:15 AM   #7
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Dennis
Dennis,
I would not worry. I got a check engine light around 40,000 miles. The truck was running fine. It seems it is programmed into the computer to trigger the light to re-program the computer once the engine is broken in.
Michelle TAC MT-0
Sarah, Snowball
Old 02-22-2009, 09:42 AM   #8
Dennis,
Be sure to go to the Ford Enthusiasts Forum. If you submit your VIN number some industrious soul will get you a print out (emailed to you) of all the information about your truck; service records, customer satisfaction bulletins and so on.
You will also note all the threads on the 6.4.
I have a 2008 F 250 and when the DFP (Cleaning Exhaust) is working there is white smoke emitted. Gets on the front of the Airstream but blows off like white ash in a fireplace. It will regenerate as frequently as needed depending on your driving habits.
rtaylor537 is offline   Reply With Quote
Old 02-22-2009, 10:40 AM   #9
DFord79's Avatar
Yakima , Washington
To put it in simple terms Ford now wants you to know when its cleaning the exaust filters. You do not have to alter your driving hadbits when in regen mode.
IMPORTANT: Use high quality brand name (Chevron, shell, Texaco etc. NOT JOE BLOW CUTRATE DIESEL) diesel at a station or that has volume sales AND the same for oil in the crankcase.
Reflashes are common in todays car/truck world and mostly are to improve performance. My 1994 thunderbird just got a reflash and the motor has NEVER run better and the transmission shifts better than when it was new.
Transmission fluids are very very very,,, did I say very specialized. Each manufacturer has a special fluid for, in some cases, each transmission they make. BE VERY CAFEFULL what you use when draining the tranny for a refill.
DFord79 is offline   Reply With Quote
F250 or F350? Craftsman On The Road... 43 02-10-2018 04:27 PM
F250 5.4 Brad Hunt Tow Vehicles 10 10-03-2007 08:21 AM
looking at a '97 F250 PSD Boondocker Tow Vehicles 36 09-14-2007 09:25 PM
2008 F250 dpandorf Tow Vehicles 17 04-22-2007 10:42 AM
F250 and 30 Classic wayneh Tow Vehicles 31 04-15-2006 06:34 AM
