Old 09-23-2015, 06:05 PM   #43
KYAirstream's Avatar
Northeastern , Kentucky
Originally Posted by slowmover View Post
One can easily have "too much truck" as in as bad as trucks are already, 4WD and off-road tread tires only make things worse. Weight becomes a detriment somewhere past 4000-lbs.
For a truck, when the adhesion of the contact patch is lost at the Drive Axle, so generally is the combined rig once at speed. The truck becomes the reason for the rollover. It goes over where a sedan spins out.
A VPP hitch should be an automatic purchase. Those who've never used one can be safely ignored as to the benefit. Whatever relieves the stress against the Drive Axle tires is all to the good. There is no adequate substitute when the rig is this size.
Slowmover - can you (or anyone) elaborate on the above? Also, what does VPP stand for?
KYAirstream is offline   Reply With Quote
Old 09-24-2015, 09:46 AM   #44
1971 31' Sovereign
Christine , North Dakota
VPP -- Virtual Pivot Point (I had to google this)
Pro Pride Hitch FAQ
Their propaganda is directed toward their own 3P hitch, but I'm certain that other manufacturers like Hensley have similar verbiage.
How is the ProPride 3P trailer sway control hitch different from other sway control hitches?
Conventional trailer sway control hitches apply some type of friction force to damp trailer sway. When a force is applied to the trailer it will attempt to pivot at the hitch ball. Any hitch that allows the trailer to pivot on the ball will allow the trailer to sway. Many hitches have friction forces integrated into the hitch design to damp that sway force.
The 3P works by projecting a virtual pivot point(tm) to near the rear axle of the tow vehicle. With Pivot Point Projection(tm), or 3P, technology incorporated in the main hitch head, the trailer's effective pivot point is no longer at the hitch ball when a force acts upon the towed trailer. The forward effective pivot point of the trailer shortens the lever arm distance between the pivot point of the trailer and the rear axle of the tow vehicle. Shortening that distance has a dramatic effect on the stability of both the trailer and the tow vehicle when the trailer is acted upon by an outside force. Many people who tow fifth wheel trailers or gooseneck trailers are familar with the stability that a forward pivot point provides.
phlegm is offline   Reply With Quote
Old 09-24-2015, 07:42 PM   #45
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
F250/350 questions
Old 09-28-2015, 04:23 PM   #46
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Pro Pride Hitch FAQ
Phlegm.. yeah.. probably 'propaganda'... but, the thing just works!
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-29-2015, 12:27 PM   #47
1971 31' Sovereign
All sales advertisements in some way shape or form are propaganda.. "buy ours because it is better than others and here is why...."
The propaganda part comes from manufacturer specific terminology and a general lack of standardization. Leaves a lot of leeway for copywriters to say anything they like.
That is not to say the product isn't effective.
Airstream Classic 350 LE Motor Home 1992 Orig. Owner SAirstream Classic 350 LE Motor eBay Watch Airstreams on eBay 0 11-28-2010 10:00 PM
'08 F250/350 vs 2500/3500 diesel 4x4(?) crew cab Roamin Cat Tow Vehicles 31 03-21-2008 06:03 AM
F250 tow vehicle or flatbed? Cheryl Tow Vehicles 19 08-23-2007 01:58 PM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
