Old 07-07-2010, 07:32 AM   #1
beerrun'r's Avatar
2013 25' Flying Cloud
ARTHUR , Illinois
F150 suspension v. Tacoma
As a basis for comparison, I've towed this 19' Bambi with the '06 Tacoma 2x, crew for about 28,000 miles.
Now I'm towing with a new '10 F150, 2x, s-crew and now after just 1500 miles of some pretty nice roads (with the exception of Indiana!) there are things wildly moving around and self-destructing in my trailer that never happened before! Ever!
I'm using the same weight transfer hitch.
Same running speeds......set cruise on 57 and let'er eat.
Anyone else encountered anything like this?
I'm going to assume that the move from a compact PU to a stiffer, full fledged 1/2 T. rear suspension is at the root of the problem.
I'm seriously thinking about removing the overload leaf and trying that!
beerrun'r is offline   Reply With Quote
Old 07-07-2010, 07:41 AM   #2
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
Load bars on your hitch may be too stiff for the heavier truck.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 07-07-2010, 10:28 AM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Hi Beerrun'r,
Before you do anything to your leaf springs, try adjusting your WD hitch. You may have your hitch set too stiff. What make/model of hitch do you own? I had to make some serious adjustments to my Equal-i-zer hitch last week in preparation for my F-150s first tow of my Sovereign. My old tow vehicle was a 03 Excursion that had a very stiff suspension compared to my F-150. The Excursion beat the hell out of my Sovereign causing several rivets in the front to shear off. I love the softer suspension of the F-150 but I had to take that into account when setting up my Equal-i-zer hitch. I suspect your problem is associated with your hitch rather than your truck's suspension.
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
mello mike is offline   Reply With Quote
Old 07-07-2010, 11:55 AM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Yep that tacoma is a much softer ride. Just like the others have said you need to change your WD to take into account the stiffer suspension.
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
purman is offline   Reply With Quote
Old 07-07-2010, 07:00 PM   #5
beerrun'r's Avatar
ARTHUR , Illinois
OK. I'll try that.
It's 350 miles from here in Nashville back to EC IL on Saturday. I'll see what happens. Thanx
Tacoma 4 cyl. Towing boutdoors Tow Vehicles 49 02-21-2010 07:58 AM
2008 Tacoma Burddawg Tow Vehicles 9 05-30-2009 09:19 PM
Anyone Else Tow with 96-04-V6 Tacoma? Red Rover Tow Vehicles 5 02-10-2008 08:30 AM
Toyota Tacoma Tv? Red Rover All Argosy Trailers 16 01-18-2008 05:10 PM
changed from Liberty to Tacoma.. safari05-25 Tow Vehicles 10 07-18-2006 09:56 PM
