Old 05-11-2015, 09:54 AM   #57
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by SCOTTinNJ View Post
My understanding of the circa 2012 F-150 system is that it won't kick in until after you've already sh*t your pants due to the amount of sway.
Gee SCOTT- guess you've never owned an F150??
Old 05-11-2015, 04:01 PM   #58
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I do have a 2012 f-150. Never had a violent sway issue. I do tow with sway control on. Either the system is seamless or its never kicked in.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 05-11-2015, 05:01 PM   #59
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
It's my understanding that the built-in sway control on 2011 on up Ford trucks works by applying the brake with more or less power to one side of the vehicle to correct a sway condition when detected. This is a passive system and will only engage when swaying already has started.
If this was happening, then your anti-sway hitch is not doing its job and your trailer is already wagging the dog. I don't see how Fords anti-sway is going to compromise the hitch.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 05-12-2015, 09:51 AM   #60
gypsydad's Avatar
Sway controll...who do you believe??
I guess it boils down to "each his own"; who do you want to believe....the Ford dealer says "disengage truck anti-sway" control when using anti-sway hitch; the hitch manufacturer BlueOx, says same...(called them again this morning to verify) I hope I am doing the right thing; and hope you are too! If you feel safe with it on...go for it!
Old 05-12-2015, 12:08 PM   #61
jcl
Vancouver , British Columbia
I haven't towed with an F150 with this system, but I have had electronic trailer stability control on two vehicles that I have towed with. It never activated, even towing on snow covered roads. I was able to activate the vehicle stability control, and traction control, but I never got deep enough in trouble to get the vehicle to activate the trailer stability control mode.
Personally, I would never turn it off. There were early reports with the F150 that it caused a fuel consumption increase. If so, that would suggest that the vehicle brakes were being used to bring the combination back under control. The solution is to slow down, or improve trailer towing dynamics via hitch setup and load distribution, not to turn off the system, IMO. Different model years activated above different speeds, but that is where the 45 mph mentioned above comes from.
I think that the Ford dealer referenced above likely knows little about weight distributing hitches, and that the hitch supplier knows little about the Ford electronic system.
Ford themselves say not to turn it off. The F150 manual notes that there may be times when you want to turn it off (ie climbing a short steep hill with limited traction and wanting to maintain high speed to get up the hill) but that all other times, it should be on. I don't know if they have changed the recommendation more recently, but from an F150 manual that is a few years old:
Originally Posted by Ford F150 owner's manual
WARNING:
Turning off trailer sway control increases the risk of loss of vehicle control, serious injury, or death. Ford does not recommend disabling this feature except in situations where speed reduction may be detrimental (e.g., hill climbing), the driver has significant trailer towing experience, and can control trailer sway and maintain safe operation.
If there is a technical paper or documentation of why the systems fight each other, it would be great to see it.
Jeff
jcl is online now   Reply With Quote
Old 05-12-2015, 02:23 PM   #62
gypsydad's Avatar
"If there is a technical paper or documentation of why the systems fight each other, it would be great to see it. "
Jeff
Indeed! I have been researching several threads today and no conclusive reason not to use both, from what I have read....perhaps the earlier comment about use before you "S...t your pants" is correct?
Old 05-12-2015, 02:25 PM   #63
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I feel vindicated!
F150 Ecoboost Owners With Problems LFM Tow Vehicles 45 01-29-2016 10:16 PM
Question for owners of late model Ram 2500 6.7 Cummins Diesel Owners SteveH Tow Vehicles 110 03-09-2015 12:43 AM
2000 F150 -- Enough truck? Kinder Tow Vehicles 6 01-20-2006 03:55 PM
Which to tow with? Windstar or F150 dmbcdn Tow Vehicles 20 11-11-2003 03:03 PM
f150 w/ a 4.6 vi 60traveler Tow Vehicles 7 08-11-2003 02:45 PM
