Old 12-19-2008, 11:59 AM   #1
Augie R.
1960 22' Safari
carlsbad , California
F150 or somethingelse
Hi folks I'm back with another question...So I can't get a answer even from the dealer about my 2001,Chevy S-10, 4cylinder, 2.2 liter engine 5 speed manual transmission, if it can pull my 22' 1960 Airstream. So I went to the dealer my dad got the truck from and they have a 2000,Ford ,F150,automic trans. and since I have two payments left on the Chevy I figured maybe trading in ? Do you guys think this is a good idea?
Thanks for taking time to read this hope to hear from You folks.......
augier is offline   Reply With Quote
Old 12-19-2008, 12:02 PM   #2
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Definitely a step in the right direction.
Do you have specifications on the Ford? Engine size, axle ratio, towing package?
crispyboy is offline   Reply With Quote
Old 12-19-2008, 12:17 PM   #3
Road Ruler's Avatar
Images: 38
F150 or somethingelse..
If you want or need a pick up then just about any one with enough power will tow your small, lightweight Airstream.
You also have an opportunity now to be selective and get a vehicle/tow vehicle that you really want or desire.
That choice could include a wide variety of vehicles like selected SUV's, Mini vans, older or modern sedans, etc.
Take your time and get what you like. Think about long term use, fuel economy, and reliability.
Old 12-19-2008, 01:55 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Just make sure the truck has a tow package. Ford rear ends can go as low as 3.31. The package will keep you above that. Look for the factory hitch and a 7 pin plug. The heavier package will have 2 auxillary coolers in front of the radiator.
I've had very good results with the 5.4 in the Expedition pulling the GT. The 4.6 might be a bit enemic on the grades.
I know you've got some time constraints, but don't jump on the first truck you see. Take the time to fully check out any new vehicle.
Good Luck.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 12-19-2008, 02:49 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
F150 or something else
Greetings Augier!
With the 4-cylinder, I am afraid that you would find the performance in the mountains or even hilly areas to be less than desirable. In 2001, Trailer Life listed the following regarding the trailer tow capacities of your truck:
  • Regular Cab -- 3,200 lbs or Club Cab -- 3,000 lbs
    • Automatic Transmission Required
    • 4.10 Differential Ratio Required
  • Manual Transmission reduced the ratings to:
    • 2,200 lbs -- Regular Cab
    • 2,200 lbs -- Club Cab
I suspect that selecting a more capable tow vehicle will result in a much higher level of satisfaction over time.
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
Old 12-19-2008, 03:05 PM   #6
Augie R.
1960 22' Safari
Hi there thanks for the help.I called the dealer and they said it's a 4.6, 6 cylinder,automatic that's all I could get out of them over the phone. I will check on the ratio & tow package(for the hitch i'll just look under but what about the ratio where is that info? Now if it does not have a tow hitch on it would it be worth getting one ?
Old 12-19-2008, 04:53 PM   #7
dreadydreame's Avatar
1965 26' Overlander
Newport , North Carolina
I don't know if this info will help but, we have a 99 F150 4.6L v8 reg cab 2 wheel drive and we just bought a 65 overlander(26'). We used the truck in getting it home. On the hills it was really killing the truck. We would not pull the airstream with this truck again on any hills. We plan on getting a bigger truck. perhaps if it already had the tow package it would have been better, but we had to get the hitch installed. If you only plan on pulling short local distances it can probably do it. I don't know what the weight difference is in your camper and ours but I would have to encourage you to look for atleast one with a tow package if not a bigger truck.
,Katie & Anthony, 2kids, lots of pets!
dreadydreame is offline   Reply With Quote
Old 12-19-2008, 06:00 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
There is an axle code on the door tag. The odds of that truck having a tow package are slim. I had a 1997 4.2 that did and was told by more than one dealer that it was obviously a special order because there were only a handful listed in the computer. I played hell getting radiators for it, they were an oversized and did not exist in the aftermarket. Ford OEM only $$$
Here is a link on how to decode the door tag.
At bare minimum for towing I would go with the small V-8 and a factory tow package, it makes a huge difference. FWIW I can tow my 1975 on relatively level ground with my wife's F150 4.6 V-8 it has the factory tow package and the trailer is right at the upper end of the towing capacity.
I would double check that engine to the best of my knowledge Ford did not make a 4.6l V-6.
Aaron
WBCCI #XXXX AIR #2495
Old 12-19-2008, 10:08 PM   #9
holland , Michigan
Well, if I were you, slow down and really put some time into what will meet every day use and go in that direction. The 5.4 has an incredible reputation for reliability, and in this market, you are the " decider" as our great leader once said. In all reality it will cost you very little to have a truck with that engine, a 3.73 rear end and the ability to take the little trailer anywhere you want and even move up in the future to a larger streamer. Do not get trapped by any one dealer or truck. Sell your vehicle if possible and offer 500 over edmunds true value trade price on the newer unit. Good luck.
safari 28 is offline   Reply With Quote
Old 12-20-2008, 12:06 AM   #10
Very american 4 a french
brunoffrance's Avatar
1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
heavy rig...
here is my heavy rig...
A/S '71 27', Harley-Davidson Héritage softail anf F150, '97, 4,6l, 4X4...
No problem at all exept the consumption if I drive with the Cruise controm...
I don't know the 5,4l but I don't need more to tow all my toys...
Bruno.
My blog:The american dream in FRANCE:
My pictures in high quality: Pictures on FLICKR:
My videos are on YOU TUBE
My AIRSTREAMLIFE ning
brunoffrance is offline   Reply With Quote
Old 12-27-2008, 11:49 AM   #11
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
2000 F150 4x2 (non-Lighting model) with 4.6 V-6 and automatic is rated at:
5800 #'s with 3.55 axle ratio and requires WD hitch
7200 #'s with 3.73 axle ratio and requires WD hitch
Trailer tow package would include things like- HD flasher, higher amp alternator, (however this would be the same alt if it has A/C) bigger radiator (again this may be the same as if it had A/C) and cooling fan set up that moves more air, and wiring to the rear for trailer hook up.
>>>>>>>>>>>>>>>>Action
Action is online now   Reply With Quote
Old 12-27-2008, 11:54 AM   #12
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The Airstream website does not list any 1959 or 1960 model units built. For 1961 the 22' foot model* has a dry weight of 2900 #'s and a hitch weight of 390 #'s. For 1958 the 22' foot model lists a dry weight of 2730. It does not list a GVWR because that standard was not developed back then. That means the total towed weight with liquids and gear might be closer to 3500 #'s or more.
* in an unmodified condition - many trailers have been modified given the age and exposure to previous owners.
>>>>>>>>>>>>>>>>>>>>>Action
Am I stupid ? Ford F150 wingfooted Tow Vehicles 40 03-11-2011 08:33 PM
2009 f150 Tom-Mc Tow Vehicles 11 06-25-2009 03:16 PM
The F150 as a TV; one guys perspective Boondocker Tow Vehicles 26 02-25-2008 09:57 PM
F150 or F250 Gas J Goertzen Tow Vehicles 28 05-15-2006 06:18 PM
f150 w/ a 4.6 vi 60traveler Tow Vehicles 7 08-11-2003 02:45 PM
