Old 04-02-2009, 06:14 PM   #1
2007 25' Safari SS SE
Camarillo , California
F150 (max 7000 tow rating) pulling Safari 25?
We're newbies considering a Sarfari 25 (weight rating 7,000 / 7,300 lbs) - our 2008 F150 (5.4 liter V8 with tow package) is rated for a max of 8,000 lbs.
This is over the 80% rule of thumb (87-91%), but I'm wondering if the fact that it's an Airstream ameliorates the downside.
Comments?
Thanks.
Eckhart is offline   Reply With Quote
Old 04-02-2009, 06:40 PM   #2
SteveH's Avatar
Common Sense , Texas
We're pulling a 25' Excella, '01, with an '07 GMC 1500 (tow rating 7800 lbs) 5.3 Liter engine, with no problems. However, I will say I would not want to tow anything bigger with the truck.
Old 04-02-2009, 07:04 PM   #3
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
I tow a 28' International weighing 7,300 lbs with a 2008, 5.7L, V8 Tundra that has a towing capacity of 10,000 lbs.
While I am happy with how the Tundra tows the 7,300 lbs I sure wouldn't want to tow 10,000 lbs.
SRW
TEXAS66
SRW is offline   Reply With Quote
Old 04-02-2009, 07:17 PM   #4
1986 31' Sovereign
Miami , Florida
I have towed my 31' Sovereign (max gross 8300#, actual weight with our normal load 7700#) 30,000 miles over the past three years with a 2004 Nissan Titan.
While my Titan is rated by Nissan to pull 9500#, it isn't all that different in weight or power from your Ford.
Personally, IMHO, you should be fine. Drive defensively, keep the tv and trailer running gear well maintained, go easy.
mike
Old 04-02-2009, 08:42 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome to Wally World..
Your truck will tow it,
Make sure you have a properly set up WD hitch and quality brake controller.
Is it the optimum?, no. Is it the worst? not likely. You won't know what your comfortable with til you try what you have. The Stream will outlast the truck so the oportunity to up-grade is down the road. With the proper set-up you may be slow but you can be safe.
What's important?......get Stream'n
My sex life is like a Ferrari...
I don't have a Ferrari. 😘
Its a crooked piece of time that we live in.
John Prine
"Tahawus"
Old 04-02-2009, 08:46 PM   #6
2003 25' Safari
Eden Prairie , Minnesota
I tow my 2003 Safari 25 with GVWR of 6300 with a 2005 F150 rated to tow 9000. Perhaps your truck has a different axle ratio. I do recommend a trans temp gauge and possibly extra trans cooler fan. I think your trailer is about the same as mine, but with heavier duty torsion axles... so you could load it a bit lighter.
Dan
dmac is offline   Reply With Quote
Old 04-02-2009, 09:09 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
First off, welcome to the Forums. We're glad to have you with us.
We have a 2005 25FB (7300#). We used to tow with a 2005 Chevrolet Tahoe (1/2 ton) with the 5.3 liter V-8. It towed OK, but did not exactly inspire confidence. Our 3/4 ton Suburban does a much better job.
SuEllyn & Brian McCabe
Old 04-03-2009, 04:19 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Comments?
Thanks.
Yes it can be done, and done safely. Just watch what gets loaded into the trailer (I had to put a scales at the door on ours)
FWIW we tow(ed) ours for about a year with our 2003 F150 4.6l V8 with factory tow package. Tranny cooler and temp gauge are almost a necessity. We towed on relatively flat ground and stayed out of the deep mountains. Our 1975 31' has similar weight characteristics to your 25'.
Aaron
WBCCI #XXXX AIR #2495
Old 04-03-2009, 06:37 AM   #9
TinLoaf's Avatar
2006 25' Safari SS SE
Trenton , Illinois
Images: 22
I just towed my 25 foot Safari through the hills of the Ozarks to Branson, MO. The F-150 5.4 handled the load admirably. I was able to hold 60 mph up the grades in 3rd (OD off) with the torque converter unlocking only on the largest hills. That put the RPM no higher than 3,000.
I've pulled I-90 all the way to Seattle with an Excursion diesel. I haven't had the the F-150 in the mountains yet, but after it's performance yesterday in Branson I'm confident it will tow the mountain grades near Butte, MT and the Idaho border in 2nd at 4,000 rpm. It won't be the beautiful experience it was with the diesel, but it will be good.
So in summary, you're set up is a great match in my opinion. In fact I enjoy towing with the F-150 much more than with the Excusion because the steering and control is so much better. Get out and enjoy it. Just be sure to turn off the overdrive.
Also, I'm using an Equal-i-zer weight distribution/sway control hitch.
Steve
Steve
TinLoaf is offline   Reply With Quote
Old 04-03-2009, 07:22 AM   #10
Zugbug's Avatar
Volcano , California
I tow a 23' Safari with my 2006 F-150 rated to tow 9600. Performs extemely well I climb into the Seirra Nevadas a couple of times a year no problems at all.
Zugbug
2006 23' Safari
2006 F-150
Zugbug is offline   Reply With Quote
F150 for a tow vehicle? Wilburstream Tow Vehicles 34 04-02-2009 07:31 PM
What's your tow vehicle's rating? John Community Polls 112 01-12-2009 11:13 AM
Can I tow with 6 cyl F150 automatic? Aluminumb Tow Vehicles 8 09-04-2007 01:07 PM
Which to tow with? Windstar or F150 dmbcdn Tow Vehicles 20 11-11-2003 03:03 PM
What Is Your Tow Rating Fun-Lovin Repairing/Replacing Floor &/or Frame 8 09-29-2003 02:22 PM
