Old 07-24-2019, 06:35 AM   #21
turk123's Avatar
2019 30' Classic
Canfield , Ohio
This is kind of an experiment, but I am adding an Add-a-leaf to my 2017 ford F-250 Platinum diesel to increase the payload margin. I have no plans to go beyond the "sticker" on the door (2086 lb.) but my thinking is a more stable ride with my 30' Classic.
I have another thread talking more about this and the predicament I am in with payload. That said, the F-350 would have been a better choice for me. The added leaf will allow 1100 lbs. more payload (not legally as the sticker still stands as the limit) and should give me the same stability that the F-350 has. The F-350 essentially is a 250 with an added leaf. My Ford dealer said they would install my third party leaf for under $200. They have no problem with this.
I am also going to add a Suilastic shock for the rear leaf springs. My concern is the more "stiffer" ride and removing some of this stiffness transferred to the trailer. I have also added a rear stabilizer bar (ford) to the 250.
I would say if you are thinking about a 250 diesel, make sure your trim level gives you enough payload. I added an A.R.E. cap (200 lbs.) and a Bedslide (190). Add the propride hitch, trailer, Thule and roof rack, people, big dog, cooler, grill, bikes, tools, rug, and your payload is used up. The 350 gives you a good 1000 lbs. of margin.
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
turk123 is online now   Reply With Quote
Old 07-24-2019, 07:10 AM   #22
2018 27' Flying Cloud
Panama City beach , Florida
I was in the same situation. I decided that the 350 is the way to go for the additional payload. There is no real difference in ride quality, I previously owned a 250 so I have experience here. My payload sticker says 3393, it’s a loaded Lariat. I have more options than my friends Platinum! It tows extremely well.
Jason W.
USAF retired!
2018 FC 27FB queen
2019 F350 CC SRW 6.7 Short Bed
Eagle Keeper is offline   Reply With Quote
Old 07-24-2019, 08:06 AM   #23
Half a Rivet Short
Carlisle , Pennsylvania
Originally Posted by mikeinca View Post
To the point, it's been said a few times that "you can't have too much truck" but is that really true? The comment made in the other thread was that a TV that's too stiffly sprung for the task can beat up the trailer resulting in stuff like popped rivets, cabinets flying open while travelling, additional stress on the frame, etc. I know that those kinds of problems can occur with a poorly matched hitch but it seems reasonable that they could also be associated with a poorly matched tow vehicle.
Thoughts?
Hi
Given the way an AS hooks up to the TV, there *is* flex between the two. It's not a 5th wheel. In order for the truck to to crazy stuff *to* the trailer you would need a pretty stiff linkage. With a heavier truck, there is less need for a lot of WD on your hitch. That means a *softer* linkage rather than a stiffer one (at least with most systems).
uncle_bob is online now   Reply With Quote
Old 07-25-2019, 02:06 PM   #24
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Interested in your ride review when you get this all done...I am looking at the Bilstines on mine, but dealer told me this past week, he wouldn't change till the Rancho's need replacement...he said mine are fine while I was in for service. 60K now on my 2017 F250...Not sure if I will go for the topper or not for our Alaska trip next spring...lots of plus's for having a topper; more room for secure storage and kayaks on top, etc...if I go that route, I likely could also use the extra spring to be safe...
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 07-25-2019, 03:53 PM   #25
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
I know your post was directed at turk123 but just thought I'd chime in on the Bilstein series 4600 shocks. My 2017 F250 suspension felt under-controlled on rough roads even when unladen and I had some porpoising when towing; not bad but noticeable. I replaced the front and rear OEM shocks with the Bilsteins even though my truck only had 10K miles on it.
I'm extremely happy with the result. The ride is more composed on rough pavement and on our recent 3000 mile trip after the upgrade I didn't experience porpoising even once. Definitely an upgrade over stock.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin (sold)
2020 25' Globetrotter Twin (here!)
2017 F250 4x4 6.7 max tow Platinum
mikeinca is offline   Reply With Quote
Old 07-25-2019, 06:07 PM   #26
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I did the same thing. If you want to wait for the Rancho's (actual ford with Rancho's label) to go bad before you install new shocks, you won't wait too long. Mine were gone at 25,000 miles. Bilsteins all around. Billstein now makes a shock for the rear on 2017 and up F-250/350's with no modifications.
Ride is definitely improved. Don't forget the steering damping shock. Mine was leaking and caused a death wobble!!!
Old 07-26-2019, 10:45 AM   #27
gypsydad's Avatar
Tell me more about the "death wobble"! Not sure I knew about that?
Old 07-26-2019, 10:47 AM   #28
gypsydad's Avatar
Thanks for the input! Guess I should order on Amazon and get these going then!
Old 07-26-2019, 09:58 PM   #29
turk123's Avatar
2019 30' Classic
Canfield , Ohio
The stabilizer shock went bad and was leaking. A death wobble is when your front steering shakes back and forth as your front wheels are caught in a back and forth oscillation! It is scary and you have to slow down and pull over!
Old 07-26-2019, 11:22 PM   #30
mikeinca's Avatar
Haven't had an issue with mine yet. Hopefully they replaced it for you under warranty and didn't try to say it was a "wear item".
Old 07-27-2019, 06:01 AM   #31
turk123's Avatar
2019 30' Classic
Canfield , Ohio
They did.
Old 07-27-2019, 06:16 AM   #32
r carl's Avatar
Lin , Ne
Old 07-28-2019, 04:46 PM   #33
DewTheDew's Avatar
2017 27' Flying Cloud
Frederick , Maryland
Something was brought up briefly in another recent thread and since my questions about it wouldn't have exactly been on topic I didn't want to hijack that discussion. This thread seems like a better place to get some responses from the forum.
Obviously it depends greatly on individual requirements, but I'm just wondering if the question of F250 versus F350 is really so completely cut and dried. For example, after accounting for all of the fixed payload requirements like tongue weight, hitch, and passengers my 2017 F250 high trim level diesel with max tow has 550 lbs or so of spare payload capacity. Since I typically carry a couple of hundred pounds of gear in the bed of the truck, this leaves me a significant payload margin. Given that all the other attributes of the F250 are more than up to the task of towing my 30' Classic what would be the advantage of a one ton truck in a situation like mine? And isn't it possible that I'm doing my trailer a favor by not towing with a more stiffly sprung TV than I need? Or not.
Thoughts?
My view (in addition to the other comments) is basically that you can always soften the ride with something like an air hitch but you cannot easily add capability if you want to add payload above what is stock. Maybe next year you decide you want a Quad bike or add a couple of kayaks and bikes. Or you add a topper. Or you get a generator as you decide to boondock. But then again, I am a fan of flexibility. My current situation calls for an F150 (which is adequate but after two years I already feel the need for more payload) but in a few years we will get either a 3/4 or 1 ton.
DewTheDew is offline   Reply With Quote
Old 07-28-2019, 06:46 PM   #34
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
I put 30K miles on our 2015 Ram/Cummins 2500 and had the opportunity to trade it in on a 2018 Ram/Cummins 3500. I've now put 7K miles towing on the 3500. I can't tell any difference in the ride between the two of them.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 07-28-2019, 07:35 PM   #35
mikeinca's Avatar
Good points about flexibility. In my case, I have all the gear I can foreseeably need for boondocking or whatever and I have ample payload capacity left over with a 3/4 ton. But if there is truly no penalty to be paid for getting the 1 ton, then one would be silly not to consider it.
I won't be in the market for a new truck for quite while but when the time comes I'll just have to do some critical comparison testing between a 1 ton and 3/4 ton for myself. My problem is that I know that per the specs the F350 has more springs and they are higher rate than the F250. From my experience with suspension tuning I'm having a hard time with the idea that Ford could somehow have greatly increased payload with a stiffer suspension on two trucks that are otherwise identical design-wise, yet not affect ride quality at all. Seems like magic!
Anyway, I appreciate the subjective opinions on the subject. Maybe I'll try a 1 ton and discover it's not as noticeably different as it would seem on paper.
Old 07-28-2019, 08:10 PM   #36
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Next year . . . F-350 or f-450? I actually looked at a 450 the other day. The biggest plus of the 450 is the wide front end and incredible turning radius. Worth the price of admission!
https://youtu.be/jGuEJEyvDtY
Old 08-18-2019, 01:41 PM   #37
sparkymark's Avatar
2012 25' FB Eddie Bauer
laguna beach , California
2018 F350, always go with bigger payload. Love mine!Click image for larger version
sparkymark is offline   Reply With Quote
Old 08-23-2019, 06:29 PM   #38
DewTheDew's Avatar
Originally Posted by sparkymark View Post
2018 F350, always go with bigger payload. Love mine!Attachment 349803
Love the blacked out chrome!
Old 08-30-2019, 07:32 AM   #39
Dike , IA
My 2018 6.2 Lariat rides pretty good with my tires at 55 front, 60 rear. My TW is 1100 lbs, and according to the Michelin weight charts, that pressure is still way more capacity than the tires need. The payload on the gasser is 3116. Pulling an AS or almost any TT, not sure why anyone would need more than that. My TT is 8400 lbs and it accelerates up hills. Sure it uses 4th gear at nearly 4k rpm, but that's where the torque is And how they work. Nothing wrong with it. I wouldnt have any issue with 10k on the hitch of my 250 and would probably go to 12k if it was a 5vr. All without the diesel penalties. If I had a 12k and up 5ver, it would be a diesel f350 for sure.
ISUboy is offline   Reply With Quote
250 meets 250 meets 250... "made for Germany" in Germany split window Classic Motorhomes 27 11-29-2016 11:44 AM
Any TV off road type tires? 2016 F-250. 250 vs 350? 6.7 Diesel or 6.2 Gas? Need help! Danattherock Tow Vehicles 53 07-19-2015 01:21 AM
250 MH :: 1990 Airstream 250 barend Airstream Registry Discussions 0 08-19-2011 08:32 AM
