Old 11-27-2013, 10:36 AM   #1
Hilton head island , South Carolina
F 250 or equivalent
I have decided I need at least a f250 for a 25 or 27 airstream without worrying about counting weight in the truck and trailer.
Do I need to get the max tow package?
What is the ram, gm etc.. equivalent of the f250 for price comparison?
coastal is offline   Reply With Quote
Old 11-27-2013, 10:41 AM   #2
2016 30' Classic
Erie , Colorado
GMC would be the Sierra 2500HD
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 11-27-2013, 10:41 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
250 in a Ford competes with 2500 in the GM and RAM lines.
If you're thinking of one of the diesels, you don't require any sort of "max tow" package in an HD pickup. You may want a tow package because of nice extras like backup cameras and brake controllers, but if you're thinking about a posh trim package on the truck those will probably be included.
David
Old 11-27-2013, 11:00 AM   #4
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
My 2012 Chevy 2500HD has a gas engine is a great tow vehicle. Never any worry about going over weight capacity. Payload is ~3000lbs.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 11-27-2013, 12:02 PM   #5
Severna Park , Maryland
My F250 works great with our 28' Flying Cloud. Got the gas engine because of all the problems I read about with diesel engines in the late model trucks. However, in Airstream Life, Andy Thompson wrote a series of articles that are quite eye-opening and challenges a lot of current thinking one sees on this forum, for example. Not sure what I would have purchased had I read all the articles first.
sailorii is offline   Reply With Quote
Old 11-27-2013, 01:52 PM   #6
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
A Chrysler 300? :-)
That was a fun article!
SteveSueMac is online now   Reply With Quote
Old 11-27-2013, 04:10 PM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Another article mentioned a Porsche Cayenne- if I could I would..,
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-27-2013, 06:35 PM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The flip towing mirrors were an option along with the backup sensors and reverse camera in the tailgate on my 2012 Ram 2500HD with high output Cummins and six speed automatic.
The allowable trailer weight is based upon deducting the current loaded truck weight from the Gross Combined Vehicle weight of 20,000 pounds. Since I currently see no way to get 2,600+ pounds of "stuff inside the trailer, the truck may get as heavy as 10,500 pounds as the axles are reared 5,500 pounds in front and 6,010 pounds in the rear. The Michelin LT265/70R17E tire pressures can be adjusted to support more than the axle ratings.
Old 11-28-2013, 05:04 AM   #9
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Here is what looks to be a nice 05 GMC 2500 in the Forums Classified
Don't know anything about it.
2005 GMC SLT-2 2500HD Sierra Crewcab 4X4
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 11-28-2013, 06:47 AM   #10
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
Originally Posted by SteveSueMac View Post
A Chrysler 300? :-)
Read the article on the Chrysler 300. I am skeptical at best.
I tow a 27 Classic with a 2007 Durango, couldn't imagine towing a 30' Airstream with the Chrysler 300.
The concern for me would be the safety factor and more importantly the difference in weight between the tow vehicle and the trailer.
I must admit in get a bit white knuckled when crossing the huge bridge that bypasses Baltimore. The bridge is 250 above the water, and there are usually cross winds. With the 300, I would be afraid that you could loose control.
Our Durango sits fairly low - is the last year on the frame that tows 8,950 lbs. and 1,750 payload. A HD truck is our future, but not for another several years as the Durango only has 70,000 miles, with about half of the miles being with a trailer in tow (our previous coach was a 25 Safari). The HD truck will be nice for cross country trips.
Tom
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 11-29-2013, 08:06 AM   #11
Somewhere , Georgia
No. All F-250s come from the factory with the hitch, tires, rear axle, transmission, and cooling capacity to tow up to a 12,000 lb. trailer. Also standard on all F-250s are tow mirrors, trailer sway control and hill start assist. XLTs add an integrated trailer brake controller. Lariats add a rear view camera.
D Air Cloud is offline   Reply With Quote
Airstream 250 value? kasey Classic Motorhomes 20 06-03-2016 04:58 PM
Local POR 15 equivalent? rippie Repairing/Replacing Floor &/or Frame 13 11-18-2013 11:23 AM
Couch Replacement - 1990 250 Sonia Classic Motorhomes 15 10-14-2011 10:23 AM
250 MH :: 1990 Airstream 250 barend Airstream Registry Discussions 0 08-19-2011 08:32 AM
Ford 250 4x4 diesel mileage GaRoc Mechanics Corner - Engines, Transmission & More... 3 08-10-2011 07:59 AM
