Old 06-06-2007, 12:51 PM   #1
Pleasanton , California
F-250 Long or Short Bed
Our little Chevy Tahoe can no longer handle the abuse of our 2007 30' Classic so I am looking at an 07 Ford F-250 Super Duty Diesel Long Bed. I like the fact of having a much larger wheel base, a much larger gas tank and the option of carrying future 4 wheelers. It is only 1.75ft longer than the short bed, but wanted to get some opinions if I am going to have significant issues backing this baby up.
Scott
takeachance is offline   Reply With Quote
Old 06-06-2007, 12:59 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Is it a standard cab, or SuperCab, or CrewCab? Long bed and a standard cab is good, as is club (super) cab and short bed. Long bed and Supercab starts getting really long, and tough to manuever into parking spaces at your local shopping center. I recently traded out long bed supercab F250 in on an F250 long bed standard cab. It is much more manueverable, and I have had no issues with sway towing our 31' with it.
Old 06-06-2007, 01:04 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Short Bed is fine by me
No complaints on my 99 extended cab short bed. The extended cab works great for dogs, grandkids and extra stuff. If you are not aware Ford says not to mount a pickup camper on a short bed.
Old 06-06-2007, 01:06 PM   #4
TIMEMACHINE's Avatar
Huntington Beach , California
Long bed is good choice
Scott
Scott,
I don't think you will be impacted by a long bed in regards to maneuvering, since 2005, Ford improved the front end geometry that improved the ride and turning radius. The extra length can be a problem in short parking spaces, but not usually an issue, only in tight parking lots. The larger fuel tank and the longer wheel base will make a positive difference. Longer range is always a plus when you are pulling a trailer.
If you are going to load the bed, you should be looking at the F350. The F250 and F350 have the same conventional tow rating, but the F350 has a superior carrying capacity which is important if you are carrying ATVs. The price difference is nominal. Stay with the single rear wheels, you dont need a dually and it will make parking in regular spots a true challenge when unhitched.
John
Travel is in my blood, adventure is my passport, aluminum is my favorite construction medium, and therefore, an Airstream was my destiny.
TIMEMACHINE is offline   Reply With Quote
Old 06-06-2007, 01:28 PM   #5
ScottW's Avatar
Hernando , Mississippi
Scott,
I agree with John. there is little $ difference between the F250/F350 and you gain a lot...not to mention better resale value. Ditto on the bed...take the long one. I just went for the F350, crew cab, long bed, 4wd. The turn rate on the new designed front ends is unbelievable!!!..not the usual 40 acres to turn around.(this 4wd actually turns about the same as my '04 model F150, crew cab, short bed!!) Also concur with the single rear wheels vs dually. Enjoy the best TV on the market, IMHO!
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 06-06-2007, 01:47 PM   #6
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
I would also consider the '08 vice the '07 as you get the 6.4 vice 6.0 engine and newer year.
Plus make sure you get the tow command/brake controller package. Makes life real easy!
I recently bought an '08 F250.
Some other options you may consider:
1. Heavy duty alternator or better yet the dual alternator option
2. If you consider the '08, the tailgate option/bed extender
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 06-06-2007, 02:01 PM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I agree the long bed would be best, but I am not sure you'll need a 1 ton. The 3/4 (250) will be way more than you need and have a softer ride for the Airstream which is something to consider.
Old 06-06-2007, 02:07 PM   #8
Originally Posted by TIMEMACHINE
Scott,
If you are going to load the bed, you should be looking at the F350. The F250 and F350 have the same conventional tow rating, but the F350 has a superior carrying capacity which is important if you are carrying ATVs. John
Silvertwinkie,
The recommendation to go with an F350 (1ton) is qualified by the desire to "load the bed." Otherwise I would agree with you that the F250 is sufficient.
John
Old 06-06-2007, 02:10 PM   #9
Aluminut
2004 25' Safari
. , Illinois
Silvertwinkie,
John
My bad, I must have just glossed over that....adding cargo to the bed, a 1 ton might be a better idea. Thanks for pointing that out!
Old 06-06-2007, 05:36 PM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Scott,
I went form a standard cab, long bed F-250 to a extended cab, long bed F-250. No problems. The room behind the seat and being able to put 4X8 sheets of plywood in and close the gate is nice.
Michelle TAC MT-0
Sarah, Snowball
Old 06-06-2007, 05:37 PM   #11
Sean Michael's Avatar
Birmingham , Alabama
I have a 2007 F250 Supercab Short Bed...for me and our 25-foot Airstream, it's just right.
I gotta say, even with this combo I had enough trouble backing into a spot at Disney's Fort Wilderness. Adding another 7 feet (trailer + TV) would be a daunting challenge for some of these tight camping sites.
Sean Michael is offline   Reply With Quote
Old 06-06-2007, 06:20 PM   #12
Dwight's Avatar
1999 34' Excella
Joshua , Texas
fuel...
Look at the fuel tank size and go with the long bed, you will enjoy the ride and fewer fuel stops.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 06-06-2007, 07:34 PM   #13
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Go with the long bed. I just put a 91 gal. fuel tank in the bed this past fall and when it is full it makes the truck ride real smooth. My next one will be a crew cab long box. The longer the better, you can learn to back anything.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 06-06-2007, 10:55 PM   #14
Thanks for everyone's feedback! Terry to answer you question it is a crewcab, need something to haul the kids. Decided to stick with the 07 F-250 Super Duty Extend Cab Long Bed as 4 wheelers are a quite a few years down the road, drove it home this afternoon, can't wait to try it out! Thanks again
Scott
2003 Safari 25' Melvin P. Thorpe 2003 Safari 24 09-15-2007 10:53 AM
Marshall 250 regulator failure nickcrowhurst LP Gas, Piping, Tanks & Regulators 11 04-18-2004 07:08 AM
Skinny +short AS-which ones ? oldvws Our Community 6 01-10-2003 03:58 PM
Electric bed actuator dienst1 General Interior Topics 1 12-16-2002 04:31 AM
