Old 05-13-2011, 07:27 PM   #1
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
F-150 torque converter lock-up woes...
Hi all,
My F150 FX4 (5.4L) 83K miles has a transmission problem. It's the common "torque converter lock-up" problem - a shudder like driving over rumble strips or rough road as the torque converter shudders into lock-up at 45-50 mph.
I have dropped the pan and replaced the fluid and filter - it's not possible to replace the fluid in the torque converter as it doesn't have a drain plug (none after 2004 do) - so I repeated that process three times. This way I have swapped out 87.5% of the fluid.
There is no unusual debris in the pan - nothing on the magnet, with 1000 miles between each of these changes.
This hasn't resolved the problem at all.
If I accelerate harder (to force unlocking) or if I hold the accelerator and activate the brake, there is no vibration, so therefore it is strictly a torque lockup issue and not a transmission or driveshaft-balance issue.
I'm not looking forward to dropping the tranny to replace the torque converter, but it's a big, heavy job and I'm not up to it right now.
Does anyone know the 4R75E transmission well enough to tell me a chain of what else to look at? I have searched F150 forums with little new advice beyond "change the fluid, or change the converter"...
Stuck!
TX-16
Dave Park is offline   Reply With Quote
Old 05-13-2011, 08:01 PM   #2
RBolton's Avatar
Belington , West Virginia
If it's a "common" problem then there should be a "common" solution. I don't know much about Fords but usually in this day and age the first thing to check for is a software update. Your Ford dealer should be able to tell you if there is one that addresses this problem.
There are different schools of thought on changing the fluid versus exchanging the fluid. A fluid exchange usually replaces close to 99% of the fluid and will sometimes correct issues like this. But chances are your three changes were enough.
RBolton is offline   Reply With Quote
Old 05-13-2011, 09:55 PM   #3
1989 32' Excella
Limestone , Alabama
The only luck I have ever had resolving torque converter shudder is a fluid flush where the transmission cooler lines are hooked to a machine that has a large fluid reservoir that allows all of the fluid to be exchanged with the transmission at operating temperature and engine running.
Doing a drain and drop of the pan just won't get all of the contamination out of the fluid. Doing it 3 times is better but still for a 4R75E with a 13.9 qt capacity and assuming 7 quarts with a drain and drop of pan and 3 cycles, the transmission still has over 12% old fluid remains in the system.
Best wishes in resolving as the shudder is an aggravating condition.
Steve
war eagle is offline   Reply With Quote
Old 05-13-2011, 10:45 PM   #4
Dave Park's Avatar
2005 22' Safari
Aggravating is an understatement. I feel I cannot tow with this truck. I have driven it so little recently because of this. I have always taken care of the fluids and used name brand full synthetics, and the transmission gets a 25k change and filter.
The shudder seems to have been caused by a transmission additive "Lucas Oil's Automatic Transmission Fluid Conditioner" which was added without my consent. I follow the adage that you don't treat the fluid, you replace it. The shudder started within days of that "service"...
I understand there is some kind of sensor or relay that operates the clutch. Does anyone know if it is accessible without dropping the whole transmission, or if I should just bench the transmission, replace the torque converter, the relay/controller/whatever and/or the sensor? Or is there some other way the converter determines when to lock up and activates? I've seen the drawings or videos about the principles of its operation, but they gloss over the specifics of how it locks up in a 4R75 family transmission...
TX-16
Old 05-13-2011, 11:04 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, while I was still working at the Ford dealer this concern was fixed like this: (1.) Instead of doing a trans service at 30,000 miles, Ford reduced it to 21,000 miles. (2.) Replace all of the fluid and filter. (3.) Drive for at least 500 miles. [not towing] (4.) If shudder stopped, you're OK. If not, replace torque converter.
Just changing the fluid is not enough; You have to put some miles on it.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-14-2011, 12:41 AM   #6
Dave Park's Avatar
2005 22' Safari
Okay.
Should I disconnect the battery to force the computers to retrain?
TX-16
Old 05-15-2011, 01:51 PM   #7
1989 32' Excella
Limestone , Alabama
Dave - I think disconnecting the battery is worth a try to retrain the adaptive controls for the transmission. Whether you disconnect the battery or not, Bob is right - you need to drive the truck and see if the shudder doesn't improve. At the Ford Truck Enthusiast forum, there is a retired Ford Transmission Engineer (Mark K.) who is a wealth of knowledge and may be able to help with the details of the electronic and hydraulic control systems - you might post a question in the correct forum area and see what he has to offer.
Steve
Old 05-16-2011, 03:33 AM   #8
Dave Park's Avatar
2005 22' Safari
I've driven the truck 250 miles since then. There was an immediate slight improvement in the behavior - it happens across a smaller speed/rev range and feels a bit less severe - but in 250 miles of driving the behavior hasn't changed any further.
I haven't forced the computer to retrain yet. It has also been suggested that I replace the filter again now the flush/cleaning process is almost complete - since the new filter will have trapped all the gunk loosened by the detergents in all that new Mercon V.
Tomorrow. I will also be checking the MAF sensor and check/clean the EGR valve.
I'll keep you all posted.
TX-16
Old 05-19-2011, 01:23 PM   #9
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
You might also consider adding a Transgo tugger Shift kit to the tranny and also consider a Superchip programmer. The shift kit is around $100 and the programmer is around $300, both will dramatically improve your shifting and should eliminate your shudder. The $400 expense is alot less than the $1500 for a new converter and $2500+ for a new tranny. I have both on my wife's 2007 Lincoln LT(a glorified F-150) and it tows like a champ. For additional safety I also added a Summit Racing external tranny filter for another $40. One can't be too careful when it comes to tranny's.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 05-19-2011, 02:47 PM   #10
withidl's Avatar
2002 31' Classic
Houston , Texas
Dave, I was a Lubrication Engineer with Texaco Lubricants Co some years back so I have some very good knowledge in this matter.
The clutch packs and bands in an auto box are EXTREMELY sensitive to any modifications of the transmissionís fluid friction characteristics. Transmissions are designed to operate with hydraulic oils/fluids formulated to VERY specific friction characteristics, i.e. even though the oil lubricates and cools the transmission, it also has friction additives which affect the rate and smoothness at which the clutches and bands are applied. Even a VERY slight change in these friction characteristics will cause what you are experiencing.
The "Lucas Oil's Automatic Transmission Fluid Conditioner" which was added without (your) consent IS the problem. What has happened is the Lucas additives have contaminated / changed the oils friction characteristics and have probably impregnated the clutch and band materiel.
Your only real recourse is to do a very COMPLETE flush and filter change of the transmission; drive the vehicle a few hundred miles and if that doesnít mitigate the problem do a 2nd COMPLETE flush and filter change. As the Lucas additives are diluted the problem will probably gradually abate.
withidl is offline   Reply With Quote
Old 05-19-2011, 02:50 PM   #11
68Safari22
1968 22' Safari
edmond , Oklahoma
I have a 96 Merc Grand Marquis and these cars are notorius for torque converter shudder. I had the fluid changed and all was okay for maybe 5000 miles and then it started again. I found that O'Reilly's sells a product especially for shudder. It is called Lubegard - Dr Tranny Instant Shudder Fix. It really works in the Merc. I put it in and voila, no shudder. The quantity is so small that I don't drain any fluid, just add it to the tranny. It's good for about 10000-12000 miles.
Lubegard 19680 - Dr. Tranny Instant Shudder Fixx | O'Reilly Auto Parts
Harleyyat is offline   Reply With Quote
Old 05-19-2011, 04:32 PM   #12
ibgl6's Avatar
Southport (Panama City) , Florida
Send a message via AIM to ibgl6
I have a 99 surburban and mine seems to shudder when coming to a stop would that also be a torque converter problem or do I just need a trans. rebuild it does have a 150,000 miles on it....SAM
Your Friend Sam In (Southport) Panama City Florida
Air#15607 TAC FL-2
Good Sam (LifeTime Member)
ibgl6 is offline   Reply With Quote
Old 05-19-2011, 05:34 PM   #13
withidl's Avatar
2002 31' Classic
Houston , Texas
If an auto box is maintained basis mfg. specs, and not subjected to abuse (i.e. shock loading, over heating), there should never be a need for "snake oil" additives.
Old 05-19-2011, 05:57 PM   #14
r carl's Avatar
Lin , Ne
I would be contacting Lucas.
torque converter, transmission, f-150
Converter Question henw Batteries, Univolts, Converters & Inverters 5 05-10-2011 07:55 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 03:06 PM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 04:02 PM
univolt converter switch position? godaddy64 Electrical - Systems, Generators, Batteries & Solar 8 02-25-2011 01:17 PM
