Old 11-14-2014, 05:29 PM   #1
1998 30' Excella 1000
Livingston , Texas
F-150--- How Do They Get These Numbers?
Just looked at the 2015 F-150 specifications. For a Super Cab with the 3.5l Ecoboost w/3.55 axle, they claim a GCWR of 17,100lbs and a Tow Rating of 12,100lb. That is more than 1,700 lbs and 1,000 lbs, respectively, than the max ratings for the Ram 1500 with the Hemi. And the Ecoboost has 8% less HP than the Hemi (but 3% more Torque). What am I missing?
Siegmann is offline   Reply With Quote
Old 11-14-2014, 05:49 PM   #2
ottawa (greely) , Ontario
Could it have something to do with the weight of the truck ,isn't the 2015 like 90% aluminum?
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 11-14-2014, 06:12 PM   #3
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Is it with their new 8 or 9 Spd trans? It is always possible on paper if the new trans. has a really deep 1st gear like GM's new 8 Spd.
George
gandttimes is offline   Reply With Quote
Old 11-14-2014, 06:14 PM   #4
Livingston , Texas
No where near. Just the body panels. Either way, that would not affect the GCWR. That would be determined by the powertrain.
Old 11-14-2014, 06:15 PM   #5
Livingston , Texas
It's only a 6-speed.
Old 11-14-2014, 06:21 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
If you believe any manufacturers claims for towing or MPG, I have some waterfront land in Florida I'd like to sell you.
Read the small print first. What conditions were the specs written for?
Cheers
Tony
Old 11-14-2014, 07:24 PM   #7
SteveH's Avatar
Common Sense , Texas
I've often wondered if the Ecoboost V6 engine is so great and wonderful (I'm not saying it's not) why can't you get it in the F250?
Regards,
Steve
Old 11-14-2014, 07:45 PM   #8
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
The EcoBoost has a lot more torque than the normally aspirated. That said, it's tow rating is only 600# higher than my '09 F150 with a 5.4L gas.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-14-2014, 07:58 PM   #9
1994 30' Excella
Mississauga , Ontario
My 2011 ecoboost has a tow rating of 11,200lb. Cargo capacity in the truck of 2740lb.
But it is a supercab with 8 foot box and heavy duty payload and maxtow. Most people don't like that setup and therefore have much lower numbers. It tows my 31 foot Excella as though it isn't there. Much better than my old 2001 E150 with the 5.4litre v8.
Al
Al and Jean
TAC ON-3
Old 11-14-2014, 07:59 PM   #10
1994 30' Excella
On edit that is weight of trailer. Combined payload is 17,100lb
Al
Al and Jean
TAC ON-3
Old 11-14-2014, 08:09 PM   #11
1994 30' Excella
That aluminum body took 750lb of the base weight of the F150. That's why the new numbers are higher than mine.
I've loaded 2500lb of marble in the bed of my truck and it made the truck sit level. That's proof that the payload numbers are true.
Al
Al and Jean
TAC ON-3
Old 11-15-2014, 05:15 AM   #12
I like to get something straight, I'm no Ford person but I think Ford makes a good f-150, mustang,and when they did the crown Victoria , I'm a retired automotive tech after 34 years in the trade , I hated working on fords because they always had a special tools needed to work on them and they designed them to be more work to get something apart to discourage the backyard mechanic,.now to get back to the topic ,if you have ,say a 100hp and the vehicle weighs 1000lbs ,it's more efficient and less stress on components, and can move (tow) more then a engine that has 100hp and that second vehicle weighs 2000 lbs, there are lots of other items that effect this ,suspention of the two vehicles,gear ratios ,( final drive rear diff) and how many gears in trans ( the more gears the more you can reduce the load on engine and keep it in its maximum power curve, cooling , aerodynamics of the vehicle, example a parachute weighs very little (say 40lbs)but takes a lot of power to pull it down the highway versus a (40lbs metal exercise weight) on its end like a flying saucer to reduce its drag further would take very little horse power to pull through the air.
FORD has reduced its f-150 by about 750lbs that's great they say there new truck is about 90% aluminum and it doesn't rust there right but it still corrodes as we all know owning aluminum airstreams, it has a lot to do with the way they prepare and treat ,grade of the aluminum and protect the aluminum from rub through the finish to the bare aluminum ( gaskets ,proper finish etc) the more power per cubic inch a engine develops the more stress on its components . The more cylinders a engine has the more the power lap ( on six cylinders or more)on the crankshaft ,it's like two people CONSTANTLY pushing a car versus two people pushing the same car but one taking a break on and off with two seconds intervals while the other is still pushing one person is going to be more STRESSED
Old 11-15-2014, 05:39 AM   #13
Gainesville , Florida
Rear ratio, tires, springs, body and bed size all figure in. Jim
Old 11-15-2014, 05:51 AM   #14
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
It's marketing mobo jumbo as we've all pointed out before. They'll always advertise the configuration with the best towing, but very few people ever buy that configuration. Ford is notorious for this slick marketing. Just look at around at all the confusion on this forum about max tow vs max payload.
I pointed this fact out in another thread, a Ford Advertisement with 11,000lbs towing rating in bold letters, showing a Ford King Ranch towing a boat, but in fine small print, it says, tow capability configuration may be different from actual model shown.
Most folks don't want a single cab 6ft bed with no options so they can tow 12000lbs. Most will buy a Platinum ecoboost and proceed to complain when they discover after leather and premium sound navigation plus sunroof and crew cab with short bed resulted in 400lbs of payload rating.
I exaggerate for effect, but the point remains the same.
It's also been well established that the ability to tow 12000lbs in theory doesn't mean much if the hitch weight exceeds the vehicles payload, so the numbers go right out the window.
It doesn't come down to which brand is better, because that's always a personal preference. It comes down to you doing your homework and being able to read past the marketing. The big three are kind of like politicians when it comes to their claims.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Serial Numbers on a '64-what they mean ts8501 1964 Safari 1 10-26-2008 08:19 AM
Towing numbers...not always what they seem Wayward Tow Vehicles 16 08-07-2008 08:27 AM
I need numbers, Part numbers that is. thenewkid64 Airstream Motorhome Forums 1 07-19-2003 10:51 AM
What do they call these?Awning?Glass Guard? Chitown AirStreamers Rock Guards, Segment & Window Protectors 5 05-16-2003 09:20 AM
They don't make them like they used to femuse Our Community 23 04-29-2003 07:15 AM
