Old 07-08-2008, 06:10 PM   #1
TinLoaf's Avatar
2006 25' Safari SS SE
Trenton , Illinois
Images: 22
F-150 Extendable Tow Mirrors
I just got finished installing the 2007 and up F-150 extendable tow mirrors on my 2005 F-150. The mirrors are power adjustable with blinker and heat. They manually pull in and out.
These are a major improvement for seeing behind a 8.5 foot wide Airstream. They're even better than the mirrors on my old Excursion.
Installation took about an hour for each door and needed only a screw driver and a few socets. Very easy. The mirrors plugged right into the old wiring harness.
These tow mirrors have one feature that doesn't work on my vehicle. That's the additional puddle lights that shine down on the ground when you unlock the doors at night. I guess the 2007s have another wire for that. Other than that, everything else works.
Steve
ID:	63373   Click image for larger version
Steve
TinLoaf is offline   Reply With Quote
Old 07-08-2008, 06:48 PM   #2
zamboni's Avatar
I have them on my 2008 F250...power fold also. I love that feature when parking in grocery store parking lot.
zamboni is offline   Reply With Quote
Old 07-08-2008, 07:09 PM   #3
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Locust Grove , Virginia
Images: 8
Were they from Ford? or another aftermarket provider?
How much were they?
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 07-08-2008, 07:26 PM   #4
TinLoaf's Avatar
Trenton , Illinois
Images: 22
They are Ford part numbers
7L3Z-17682-AE Right Side
7L3Z-17683-AE Left Side
The dealership wanted $175 each plus $105 in labor per side totaling $560! I got them from tascafordparts.com for $134 each and installed them myself saving nearly $300.
Steve
Steve
Old 07-08-2008, 07:41 PM   #5
_
nice report tin!
thanks for sharing...
WHAT 250?
is this a work truck or are u gonna start pulling the moho and microbus with a superduty...
cheers
2air'
Old 07-08-2008, 08:33 PM   #6
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
Yes, these are the best mirrors around. You can see everything behind you! One of the best features on my 08 F250.
millvalleyca is offline   Reply With Quote
Old 09-18-2008, 07:45 AM   #7
Toronto , Ontario
Hey Steve,
Great looking mirrors! I'm sure they work great too giving you that extra distance. I'm definitely going to get a pair of these when I get my new AS next spring!
Was the install fairly straight forward? I would want to do it myself as well if I could.
echoroxy is offline   Reply With Quote
Old 09-18-2008, 11:01 AM   #8
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
I like that too... I guess I should go with that.
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 09-18-2008, 01:57 PM   #9
TinLoaf's Avatar
Trenton , Illinois
Images: 22
They are really helpful for seeing around a widebody 8.5' trailer.
Installation in my case was very straightforward because someone on the Ford Truck forums had done it with a Lariat and I knew it would work.
The only way I could see you running into trouble is if you have a model without heated mirrors and blinkers. In that case the truck might have a different wiring harness for the mirrors and more research would need to be done.
Steve
Old 10-17-2008, 07:00 PM   #10
Toronto , Ontario
Thanks for the info!
I also have the heated mirrors with integrated flashers (like the ones you took off). Glad to hear installation won't be too hard. It'll be one of my fall projects.
Old 10-17-2008, 07:26 PM   #11
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
man thats a real great set of mirrors. how could you run the extra wire to get the puddle lights?
Thanks for the info
Jerry
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
extendable, mirrors
Tow-N-See Mirrors Silvercamper Towing, Tow Vehicles & Hitches 59 08-12-2009 09:24 PM
Tow Mirrors nazz300 Community Polls 42 05-10-2008 10:56 PM
CIPA Extendable Mirrors gowyn Tow Vehicles 10 02-11-2008 04:46 PM
How to get Tow/Haul on an F-150 SilverCabin Tow Vehicles 10 03-08-2007 07:43 AM
Ford F-150 As a Tow Vehicle Cstar Tow Vehicles 16 05-02-2004 07:24 AM
