View Poll Results: What size Airstream are you towing with your F-150 Ecoboost.
16' 1 2.44%
19' 1 2.44%
20' 3 7.32%
22' 0 0%
23' 2 4.88%
25' 9 21.95%
27' 7 17.07%
28' 10 24.39%
30' 6 14.63%
31' 0 0%
34' 4 9.76%
Multiple Choice Poll. Voters: 41. You may not vote on this poll
Old 01-23-2015, 08:35 PM   #29
Airstreamer in Training
ZBoater's Avatar
2014 30' Flying Cloud
I'm not sure I understand the reluctance to tow something larger than 25' with an F150. Some 30s are under 7000 lbs dry weight and under 900 lbs tongue weight, well within the specs of the F150. What am I missing?
ZBoater is offline   Reply With Quote
Old 01-23-2015, 09:32 PM   #30
SteveH's Avatar
Common Sense , Texas
The later models, especially the wide body models are much heavier, and also Airstream is notorious about stating tongue weights unrealistically low, like with no batteries, or propane. It's not uncommon for even a late model 25 footer to have a tongue weight in excess of 1000lbs.
Regards,
Steve
Old 01-23-2015, 09:45 PM   #31
ZBoater's Avatar
Ok, well this is confusing. If they state "Hitch Weight (w/LP & w/o options, water & cargo) (lbs.) 880" then I can't rely on that?
And is the 10-15% of trailer weight = hitch weight rule of thumb not apply to Airstreams?
I'm guessing a WD hitch will address some of this, but you are right. If I exceed my payload by a couple thousand pounds, I could understand the concern. But I can't get to that big of a discrepancy with my math.
2014 Airstream Flying Cloud 30' Recliner: Base weight 6422, GVWR 8800
2013 Cadillac Escalade Tow Vehicle: 6.2L, 403hp, 417 ft-lb., 4x2, 3.42 axle ratio, Max Payload 1573, Max Towing 8300.
Old 01-23-2015, 09:57 PM   #32
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
My 27FB tongue weight with a Sherline scale was 900lbs. That's ready to go camping. Empty according to Airstream is 770lbs.
kscherzi is offline   Reply With Quote
Old 01-23-2015, 10:09 PM   #33
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Interesting, so does your 900 LB include both propane tanks full? Also does it Include your hitch? I have always thought the 27 and 28' units were heavier than that. If they are not that's good news for me
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 01-23-2015, 10:36 PM   #34
Climber's Avatar
2012 27' Flying Cloud
Portland , Oregon
Originally Posted by ROBERTSUNRUS View Post
Hi, so far, I have to admit that I'm surprised at the count. If I counted correctly. For trailers that are 25' or less, I counted 10. For trailers larger than 25' I counted 21. This makes me more anxious to see how my F-150 will tow my 25' Safari and compare it to what my Lincoln has done for ten years.
I'm eager to hear how it compares to your Lincoln, especially in mountain driving. Cascades? Siskiyous? Please keep us posted.
2012 27' Flying Cloud FB (Bella)
2014 F-150 3.5L Ecoboost
Climber is offline   Reply With Quote
Old 01-23-2015, 10:48 PM   #35
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I am too; My Lincoln's 300 ponies probably drops to about 200 ponies in the high mountains. A super charged, turbo'd, or blown engine is supposed to hold it's horse power. So let's say I might be comparing 200 horse power to 365 horse power when I go back to Colorado. I thought that the Colorado mountains were going to kill my Lincoln, but my Lincoln proved to be tough. I'm just as concerned about engine drag going down those hills. Driving single my Lincoln seems to have a lot more engine drag than my F-150.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-24-2015, 08:21 AM   #36
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
My Airstream company Safari 25' stated tongue weight is 860 lbs.; however, my CAT scale weight is 990lbs.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 01-24-2015, 04:46 PM   #37
kscherzi's Avatar
Images: 24
Doug
Full propane tanks. Stuff under the bed, in the front storage area. In the front overhead etc. Weighed at the campground using a friends scale. Not including the hitch.
Old 01-24-2015, 06:35 PM   #38
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Originally Posted by paiceman View Post
Use to tow a 25' FC with a Ford F150 EcoBoost, terrific for that size trailer, but would not go any larger, at least for me. Payload, brakes et all. I did tow a 30' AS with it when we first got the 30' and did not like the overall performance.
Bud
What year and final drive f150?
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 01-24-2015, 06:45 PM   #39
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Originally Posted by rodsterinfl View Post
I am like you Robert, haven't yet as I don't have an ecoBEAST yet but one consideration is that there is a significant difference in those towing with pre-2015 models as the trucks are around 700 lbs heavier! That would have a definite impact on towing/torque power. As others have stated, that engine is a beast with very low torque RPM and lots of power. The only cutoff I believe would be tongue weight/payload and planned cargo for someone. The new F150 adds all that extra weight of the older models to its payload rating which is around 2100 or so on the regular tow pkg.
Are you sure about that payload figure? I emailed a dealer earlier today and asked them to give me the payload off a max tow 2015 f150 crew cab. was 1777 lbs.
That's very close to my 2012 crew cab with the 5.0 v8.
This is the 2015.
ID:	231047   Click image for larger version
Old 01-24-2015, 08:33 PM   #40
2015 27' Flying Cloud
Washington , Washington, D.C.
If you check the Ford website, I think you will find crew cab combinations in excess of 7000 lbs. GVWR that are available. For example 20" wheels and tires are usually rated for less capacity than 18 inches. But they look cooler, so the dealers order them. I'm pretty convinced that the typical 1/2 ton buyer isn't too concerned about carrying a ton of stuff in the bed or towing 10,000 lbs.
DC Bruce is offline   Reply With Quote
Old 01-25-2015, 08:01 AM   #41
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
When I ordered my 2015 I found it necessary to sit down with a savvy salesperson and item by item select the package that would give me MaxTow and MaxPayload. I ended up with the Platinum model and because it is a high end "luxury" model I was a little limited with maxing things out. Still ended up with 2000+lbs payload and I can't recall the tow but certainly adequate for my 30' Cloud.
TinCan
graysailor is offline   Reply With Quote
Old 01-25-2015, 08:44 AM   #42
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I looked up the VIN. On the label above. XLT 145" wb 7000 GVWR PKG.
There is a local 2015 XLT to me with a 157" wb with a 7050 GVWR pkg. I would expect the payload to be similar or slightly less since it has the 6' bed.
I test drove 2014 145" wb with a 7700 GVWR pkg with 1765 lb showing on the payload sticker. It wasn't an FX4 like the 2015s mentioned here which adds skid plate weight. 300lbs was not woth replacing my Tundra.
So the 2015s can offer similar payload with less GVWR. Will Ford have 2015 models with more GVWR without having to order the HD payload Pkg? I suspect they won't. It appears to get more payload we will have to special order one with the HD Payload pkg which is almost a $2k.
Kelvin
Ford 150 Ecoboost with Max Tow vs. Big Butt Trailer ShullsinUtah Tow Vehicles 15 09-17-2013 08:45 PM
Ford F-150 EcoBoost review JFScheck Tow Vehicles 387 05-28-2013 04:49 PM
Ford 150 EcoBoost experience GaRoc On The Road... 5 11-17-2011 04:59 AM
Ford 150 EcoBoost power in Mountains GaRoc Tow Vehicles 31 09-20-2011 05:14 PM
2011 F-150 Ecoboost mysecondjoy Tow Vehicles 33 02-11-2011 09:01 PM
