Old 01-29-2005, 07:42 AM   #15
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Till, to put it into perspective, if I recall, you are not towing anywhere near 8k. The 5.8L w/ 3.54s will do just fine in your application if you are not near 8k. Dare I say far better than your Caprice of a rated 5k without any mods. The full floating axle is good, but really isn't gonna do much in your particular app. Can't hurt though. I've read that the 1 tons can be a bit harsh, but all you'd really have to do is take out one (maybe two) leaf(s) off the rear spring if you really had to.
There are folks here towing with 6.0L 3.73 GM trucks and though your van has about 90 less horsepower and possible less torque than the GM 6.0L, again, I'd be shocked if you're towing at ot more than 8k including gear, passengers, etc that you'd really see any problem. Even the GM 5.3L 1/2 ton w/ 3.73s is rated in a Suburban for 7400lbs.
The one area where I'd like to see 4.10s with that particular engine is if you planned to go to places like the Rockies. There 3.54s might be a bit shy, but for normal everyday use and towing in most areas, I think you'd be fine.
BTW, regarding a diesel, great power, perfomance, MPG towing, check with Norby. He has one too. I know he tows his coach all over creation and could also provide good feedback.
I agree that you should take your time on this one since it could be something you're gonna have in the stable a little while.
Old 01-29-2005, 08:45 AM   #16
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Tedd,
We use the Extended vans at work for crew vans, alll of ours are set up for towing, some are after thought set up, but they all tow up to around 6k with no issues. They are all V-8 some are the older 351 and at least one is the newer 5.4. Rear ends range from 3.55 to 4.10's. The 4.10 is in the oldest one that is refered to as "the beast"...smells like one too but that is another issue. I really like Ron's setup, hard to beat.
Ron,
How did you all like the Palo Duro? We went thru there back in Sept of 03 and had a blast. Get a chance to see the museum in Canyon?
Aaron
WBCCI #XXXX AIR #2495
Old 01-29-2005, 10:46 AM   #17
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Palo Duro
Aaron,
Palo Duro was neat! We did walk through the museum and took pictures at the top and bottom. We didn't even know it was there until the KOA people told us about it. It is second only to the Grand Canyon in size, in the US anyway, maybe more (I can't remember).
Unfortunately, we were on such a tight schedule (another story and lesson learned), we didn't spend much time there. There is a campground at the bottom that we drove by.
Like most Airstreamers, we purchased ours to travel, not camp out at the lake (although it does work for that also). We have put at least 5000 miles on it since we purchased it a year ago (not to mention all the restorations, replacements, and remods) and I really couldn't be happier with the towing setup. I was very intimidated with the diesel idea at first, as I know very little about them (I'm learning). While I hated to see the Silver Bullet go (my old silver 5.4 gas E-350), I'm very pleased with the replacement. And I am definitely of the mind that I'd rather have more power and towing capacity than I need, than near or at capacity.
ID:	10248   Click image for larger version
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 01-29-2005, 11:34 AM   #18
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Ron,
That was the same KOA we stayed in...did the bunnies come vist you all? Amarillo is one place I defintely want to go back and visit again. Santa Fe Railroad has a museum there with IIRC the largest steam locomotive ever built, the museum I was refering to was the one in Canyon, TX (just up the road) it has a massive collection of Texas history from dinosaurs to electric cars to wedding gowns, basically anything to do with that area of Texas.
We plan to travel in ours too, but right now we are using it as yard art
Aaron
Old 01-29-2005, 11:50 AM   #19
Big Dee's Avatar
2004 30' Classic
San Jose , California
Images: 24
Ron,
Just had to say you got one beautiful family. Six? And four of the them boys close in age? Well I bet that makes for some interesting roadtrips. I remember mine with my brothers and my mom's famous line, "you boys stop it right now or your father will reach back with his long arms..." Never could figure out how my dad could drive and reach all the way to the back seat of the stationwagon but sure never wanted to find out. I knew somehow he could manage it. Oh, what stories there were!
"It's the journey."
NorCal Fall Rally, Jackson Rancheria, October 7-9 2011 Click here for more info
Come rally with us.
Big Dee is offline   Reply With Quote
Old 01-29-2005, 04:24 PM   #20
PizzaChop's Avatar
1973 31' Sovereign
Images: 202
Exclamation Amarillo KOA & Road Justice
Aaron,
We didn't see any rabbits but we remember the airplanes taking off and landing, as well as the nice swimming pool. Wish we'd known about the museums, but we probably wouldn't have had the time anyway.
Big Dee,
Another feature of the extended van (just to keep with the thread) is the space available to administer the love and justice that all boys so often require. Unfortunately, there is no safe way to accomplish this without pulling over. While I've found that it can affect eta, it generally assures us of a quieter and more pleasant ride.
Ron Kaes
Psalm 112
www.paparonnis.com
Old 01-30-2005, 08:07 AM   #21
till's Avatar
Lisle , Illinois
Images: 108
AMEN!!! That is one of the big advantages to having a van let alone an extended van. With the extra space for the kids to spread out a little, the trip is a lot more pleasant.
I'm guessing that I will just hold tight and if the van deal works out I will give Fogdall (sp?) a call about hitching the Ambassalander to the extendo-van.
As a side note, my list of places to visit is growing every day that I read this forum.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Class B-190 Vans - engine size joysjoy600 Sprinter and B-van Forum 19 08-27-2015 01:22 PM
Extended Warranty dkekrksk 2002 - 2005 International 4 04-17-2015 09:00 PM
WBCCI Membership for free thenewkid64 WBCCI Forum 17 05-01-2011 10:17 PM
Extended Warranties lbrodsky 2001 Safari 7 12-26-2002 01:50 PM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 08:33 AM
