Old 02-19-2010, 08:34 PM   #1
2010 27' FB International
Birmingham , Michigan
Extended Mirrors
I have a new 27 AS on order. Quick question. I have a 2010 Ford Expedition. Will I need extended side-view mirrors for towing my AS? Thanks for your help.
Aquabud is offline   Reply With Quote
Old 02-19-2010, 08:55 PM   #2
TinLoaf's Avatar
2006 25' Safari SS SE
Trenton , Illinois
Images: 22
The 25' and up are 8.5 foot wide trailers. You'll be much more comfortable if you upgrade. I have an F-150 which probably has the exact same mirrors as the Expedition. If so, you can upgrade to the nice extendable tow mirrors fairly easily. There are also slip on varieties that are much cheaper.
Here's an old thread from when I upgraded mine:http://www.airforums.com/forums/f238...ors-43426.html
Steve
TinLoaf is offline   Reply With Quote
Old 02-19-2010, 10:19 PM   #3
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Pine Swamp , North Carolina
Images: 38
Send a message via Skype™ to DreamStreamr
Tinloaf, you will definitely want and need extendable or clamp-on mirrors for your tow vee.
We tried, briefly, towing the wide body (8.5') trailer with normal mirrors and were pretty much in the dark whether someone was behind us or even pulling out to pass us until they were nearly full onto our driver's side. Lane changes were a pretty dicey thing for us until we bought a pair of clamp-on extensions.
A couple of Airstreamers showed us their aftermarket changes like Steve's. Very very nice and worth about whatever they cost. Except ---- GM was asking around a $1000 for our truck to replace our mirrors with extending electric ones. We're sure we can beat this and eventually will, but until then we're getting by okay with the clamp-ons.
Once you sit in someone elses towvee with good mirrors you're ruined for these compromise solutions, so we'll probably spring for the ones like Steve before long. Whatever you do, use some sort of wider mirror set so you can see beyond the rear corners of your RV.
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
DreamStreamr is offline   Reply With Quote
Old 02-19-2010, 11:06 PM   #4
2006 28' International CCD
Nashville , Tennessee
You definitely need extended side view mirrors. We are happy with our Mckesh. You may want to check them out.
McKesh Mirrors
dmoore is offline   Reply With Quote
Old 02-19-2010, 11:26 PM   #5
2008 31' Classic
Lake Charles , Louisiana
TinLoaf Steve... Thanks for the info. on the extended mirrors. We have a 2007 Expedition EL and tow a 2008 31 Classic. I use strap-on mirrors and they tend to vibrate at certain speeds. I'll have to check out your new ones and see if they will work in my application. Anyone here know for certain? Thanks for the info.
Steve & Mary is offline   Reply With Quote
Old 02-20-2010, 02:12 PM   #6
Fuil-Timers
Images: 38
McKesh mirrors
Good friend in our Unit back home has used McKesh with both of his Dodge 2500s and totally loves the McKesh mirrors. No vibration, no marks on the truck's body, and easy to put on/take off.
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
Old 02-20-2010, 05:48 PM   #7
Thanks for all the input. Just have to see if aftermarket extended mirrors are available for an Expedition. I know you can get them for F-Series vehicles.
Old 02-20-2010, 06:11 PM   #8
Western slope , Colorado
Bought mine from Powervision (Power Vision Mirrors | The Ultimate Towing Mirror) and could not be happier. Pretty easy to install on my 02 GMC
Streamside is offline   Reply With Quote
Old 02-20-2010, 07:01 PM   #9
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
I have found these to be good, inexpensive mirrors. They are big and go out far enough. What else is good is if you have mirrors now that fold in, then with these, you can still fold in for better room in parking spots.
Amazon.com: K Source 3891 Deluxe Universal Clip-on Trailer Towing Mirror 5" x 7": Automotive
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 02-25-2010, 05:20 PM   #10
pattimarty's Avatar
2011 25' FB Flying Cloud
Tenafly , New Jersey
Another mirror question - TV is a Ford Expedition (78.8" wide) and AS is 19' Flying Cloud Bambi. Do you think i need larger/extended mirrors? If towing experience is a relevant factor the most I've towed is a bicycle! Any info/opinions would be welcome. Thanks.
pattimarty is offline   Reply With Quote
Old 02-25-2010, 05:34 PM   #11
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Your Bambi is 96" wide. The mirrors need to extend beyond that width, so I would think yes you should get them.
Julia & Bob
W/ Deedee & Boo
AIR #30685
Old 02-25-2010, 07:15 PM   #12
pattimarty's Avatar
RLS....thanks. The mirrors on the TV are about 10 inches so it gives us perhaps a couple of inches past the trailer width. I assume that is not enough. Any recommendations of mirrors? Ford use to make a slip on extention mirror but seems to have stopped. Installing the mirrors mentioned above is probably possible but quite pricey. Thanks for the advice.
Old 02-25-2010, 08:29 PM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
McKesh Mirrors
Ditto...ditto...we had clip-on mirrors for a while but the McKesh are far superior and we would never go back...they are worth the money...we can actually SEE what's behind us now! What a concept!
TB & Greg and Abbey Schnauzer
#3954
Old 02-25-2010, 08:40 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the extention mirrors sold by Ford were made by CIPA and that is what I have, and use, on my Navigator. They work pretty good and are better than nothing, but I wish I could have [and I would pay the price] for the factory extendable mirrors like TinLoaf has. Unfortunately I don't have that option/choice.
Name:	IMG_0477 (Large).JPG
ID:	96989   Click image for larger version
Name:	IMG_1270 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-25-2010, 10:34 PM   #15
Bird's Nest's Avatar
2007 19' Bambi
2005 18' Westphalia
Evans , GA
We have the CIPA mirrors for our 2008 GMC and are extremely happy with them.
My husband is ultra picky and he would complain constantly if they even caused the slightest problem.
They are silent, do not vibrate and are simple and quick to install.
They do not cause any damage or wear to the truck's mirrors.
He thought he wanted the expanding towing mirrors option but now is happy that he doesn't.
He likes that he does not have to drive around daily with over-sized mirrors.
With these mirrors, what started out as make-do turned into just what we want.
Bird's Nest is offline   Reply With Quote
Old 02-26-2010, 08:39 AM   #16
pattimarty's Avatar
Thanks all. McKesh mirrors are sold at a new web address now www.safetowingstore.com.
Old 02-26-2010, 07:59 PM   #17
greatlakes's Avatar
2004 25' Safari
N/A , Michigan/Florida
I bought a pair of CIPA slip on mirrors from Campers World for my 2010 Expedition and they work just fine. They stay put and don't vibrate at any speed. They are fairly priced too.
___________________
Frank
2004 25' Safari
2010 4x4 Ford EB Expedition
greatlakes is offline   Reply With Quote
Old 02-26-2010, 09:07 PM   #18
Salem , Oregon
Images: 18
Hi, I will agree with most of what you said:
(1.) Price isn't too bad.
(2.) Easy to install and remove.
(3.) Don't vibrate and very seldom move or come loose.
(4.) Virtually no wind noise.
(5.) Vehicle has normal sized mirrors when not towing.
Dislikes:
(1.) Outside mirror would be nice if a bit larger.
(2.) Not quite wide enough to see whole side of trailer while backing into tight spaces; This makes it impossible to tell if trailer is perfectly straight with tow vehicle. [necessary when parking in places like my driveway]
(3.) These mirrors have and will damage the paint on some factory mirrors, mine did. I had to cover the inside tightening bar with cloth material to prevent this, but still get scrapes and marks on top of mirror.
Name:	My Picture CD 223 (Large).jpg
2005 Safari 25-B
Old 04-19-2011, 01:12 AM   #19
2011 23' FB International
1975 Argosy 30
Santa Barbara , California
Towing an 8' wide AS with a 4runner I tried the suction cup and clip-on extension mirrors. The suction cup ones drove me nuts because they block the most valuable space of my regular mirror and because I couldn't adjust my regular mirror the way I wanted (had to adjust it for the suction cup extension). The clip-on also limited the adjustment of my regular mirror. Neither was far out enough to see down the side of the AS. I ended up buying the McKesh with the extra parabolic mirrors: $$ well spent!
tvoneicken is offline   Reply With Quote
Old 04-19-2011, 05:58 PM   #20
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
I vote McKesh!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Extended Warranty dkekrksk 2002 - 2005 International 4 04-17-2015 09:00 PM
Extended Warranties - Yes or No??? Cracker Furnaces, Heaters, Fireplaces & Air Conditioning 10 08-27-2007 06:22 PM
Extended Warranties newtoairstre Buyer Guidelines 16 07-29-2006 07:30 AM
Extended Warranty tlake Our Community 4 05-12-2004 10:10 PM
Extended Warranty dkekrksk Off Topic Forum 1 05-12-2004 08:13 PM
