Old 11-12-2006, 02:55 PM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Expedition / Excursion owners
Just in the info gathering stage but I was wondering what ownersw of these big suvs think about them as a tow vehicle/ driver.
I am open to suggestions but 5.4 gas tow package equipped seems to be my possible choice.
Is the V10 worth looking at? I am familiar with the 7.3 PSD so no need to tell me how terrific it is. Gas powered is my more likely target.
Is the Excursion a 250 frame underneath and the Expedition a 150?
Any thoughts are appreciated.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-12-2006, 03:18 PM   #2
Baton Rouge , Louisiana
Images: 42
We just got through towing to Colorado and back this season with our 2000 V-10 Excursion. Went from Louisiana to SouthFork, Colorado with a 26' SunnyBrook (my 31' Sovereign wasn't ready). The SunnyBrook weighs in somewhere around 6,500 loaded with no fluids. The Excursion turned in a solid 12mpg all the way to New Mexico at 62mph and then it went to a rock solid 9.5mpg in the mountains. Not too bad for the power and comfort. Yep, the Excursion is essentially an F-250 with a shell. Most parts for the Super Duty will fit the Excursion (frame mounted anyway). As for an Excursion with the 5.4....in my opinion, too much truck and not enough engine. Most of the 8 or 9mpg horror stories come from the 5.4 owners that I have met. The V-10 will get the same mileage or in our case better and provide much more power and torque. Ours has 60,000 miles on it and it runs great, no problems at all. Hope it helps.
cobra93 is offline   Reply With Quote
Old 11-13-2006, 10:44 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
yes thanks, what of the V10 reliability any stories out there?
AIR #005
retired!
Old 11-13-2006, 01:33 PM   #4
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
I had a 5.4 Expedition when we towed the '74 Tradewind. I thought it was pretty maxxed out on towing capacity for that setup. Got just over 8 mpg. Moved up to a 7.3 Excursion when we upgraded to the 32'. Tows like a dream, have to keep checking the rearview mirror to see if it's still back there. Do better than 14 mpg with the diesel.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 11-13-2006, 02:57 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Sounds good thanks
AIR #005
retired!
Old 11-13-2006, 05:31 PM   #6
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Alan,
Our '99 E-350 had the 5.4 with a 3:55 rear end and it really struggled on hills with the Overlander. Normal highway mileage of 15-16 mpg dropped to about 8-10 mpg while towing.
The 5.4 is a great motor and I have one in my '01 F-150 and it tows the boat (about 3500 lbs) fine, but I don't think I'd want to take the Sovereign very far with it.
I think you need to accurately assess your towing plans. We upgraded to diesel because I envisioned us travelling the country (hasn't happened yet) and after our one cross country trip to Colorado, I wasn't disappointed. But if you're going to stay local, a diesel could be overkill.
The V-10 sure is in a lot of class C motorhomes though!
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is online now   Reply With Quote
Old 11-13-2006, 06:36 PM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I heard that those V10s are in tons of buses and such in Europe. They supposedly used for 500,000 miles or more.
AIR #005
retired!
Old 11-13-2006, 06:51 PM   #8
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Alan, you've undoubtedly read my tales with the Excursion and towing. I love ours and wouldn't trade it for anything (but the Duramax/Allison Sub someday maybe...)
The Behemoth was at the top end of what I was comfortable towing with the Ex. The new 25' Bigfoot doesn't even seem like it's behind it sometimes. There's that much difference, and the Excursion is such a competent tow vehicle.
We have the 2000 4WD V10 with the 3.73 rear end that we towed the Behemoth with. If you get one, you'll want to put better shocks under it than stock, make sure it's got load range "E" tires on it, install LandYot's radius rods, make sure you have a Helwig 36mm rear sway bar under the suspension and you'll be good to go. I'd avoid the 5.4l Excursions and the V10s with the 4.11's. Both get the rumored 9mpg. I average about 13-14 around town with mine, and with a K&N intake kit, I get about 17 mpg at freeway speed on trips (not towing, of course).
The only problems that the V10s have are after the plugs have been changed, some of the heads will spit plugs. It's a common enough occurrance that there is a special helicoil style solid insert that mechanics install to replace the threads on plugs. Apparently it's only on some of the heads, and I'm not sure anyone has nailed down how you can tell if it's prevalent on a specific engine. Other than that, they're pretty bullet-proof.
The Excursion has a 3/4 ton chassis and the Expedition the 1/2 ton. The reason for the suspension mods I recommended are that the Ex only has a 4 spring rear stack, where the Superduty trucks have an 8 spring stack. The four springs aren't sufficient to keep the rear axle centered under the Ex, so you end up with rear-axle steering under load; not a fun thing when driving normally, and cause a white-knuckle experience when towing! If you do those couple of mods, the Ex tows like it's on rails. I wouldn't recommend the Expedition for serious towing; it's just not heavy enough.
Roger
Old 11-13-2006, 08:02 PM   #9
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
We have a 2000 Expedition with the small engine and have towed a 25' Airstream since the fall of 2003 with it averaging 10-12 mpg towing. Yes it is built on the 150 frame. We now have a new vehicle and chose to get a longer wheel base and bigger engine with the 3/4 ton Suburban. The Expedition isn't all the power you would want but it could be all you need. We never had any real problems with it, though under some conditions tiring and less stable than a heavier longer vehicle would handle. Acceleration and climbing will be where you may feel it fall short.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 11-13-2006, 08:49 PM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Go for the Diesel
Alan,
This is me and my F-250 gas 5.4L which weights less than the Excursion
Since my little accident gave me an opportunity to upgrade I went to a 6.0L Diesel. This is Michelle Towing her 8,000 pound trailer up hill at 7,000 Feet. .
Michelle TAC MT-0
Sarah, Snowball
Old 11-13-2006, 10:49 PM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, ALANDS. Did you say what you were planning on towing with these trucks? If you did, I missed it. This is my opinion; An F-250 or Excursion by themselves are too heavy for a 5.4 L engine. An Expedition with 5.4 L engine will tow 25' or less OK. Don't even consider a 4.6 L Expedition. I tow a 25' Safari with a [2000] 5.4 L Lincoln, but that's a different animal of the same size. [A lot more horsepower and torque] Note in the 25' range, I would not include the 1,000 lb heavier Classic.
Old 11-13-2006, 10:59 PM   #12
1960 24' Tradewind
santa barbara , California
The 5.4 and the v-10 do in fact blow out the sparkplug and the the threads .
word is that Ford does the repair in the vehical with the intake and all removed if your doing all or the rear plugs ,the fronts will be easier , the plugs and threads that hold them in are down 4" into the head at the bottom of the spark plug tube hole,as most are on many engines.so Id see if this repair has been done when purchasing these vehicals .
The new Ford prefered thread insert is pinned in the head to prevent any
further stripping out ,but is done with the heads off,but again Ford is doing
these repairs without pulling heads ,all in all it can be extremely expensive
to have the repair work done .Now other than that main thing ,these engines
have been very good over all in other repects ,reliable strong running .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 11-13-2006, 11:06 PM   #13
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I've heard "horror stories" about the fuel mileage on the V-10s, yet that doesn't seem to be the experience here. Yes? No?
Fyrzowt is offline   Reply With Quote
Old 11-13-2006, 11:42 PM   #14
Salem , Oregon
Images: 18
Hi, I can't conferm it, but people I work with at the Ford dealer say that the V-10's are quite thirsty.
Owner's manual Cheryl 1978 Excella 11 08-04-2012 09:35 AM
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 07:07 PM
CCD 2nd excursion ChrisAich 2002 - 2005 International 18 07-29-2003 04:34 PM
'67 Tradewind owners manual BentEar 1959-69 Tradewind 1 07-21-2002 05:15 PM
Argosy Motorhome Owners Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 03-02-2002 11:21 PM
