Old 02-26-2010, 11:40 AM   #1
big_john's Avatar
1986 25' Sovereign
Gainesville , Georgia
Excursion 7.3 Diesel Repair List - help!
Gotten lots of great advice so far. Looking to purchase a 2001 EX with 4x4 and 7.3L Diesel with 194k miles. Private seller agreed to part ways with it for $10,000. Buying from the second owner who has the service records back to mile 30,000. Includes all sched maintenance, oil and filter changes, and a few other semi major repairs including a starter and an alternator. Also received regular lube and fluid changes. And it runs like its been taken care of.
The interior is in decent shape, but the PO dinged it pretty good on teh rear quarterpanels (both of em). Those have nothing to do with the drive train and safety of the vehicle however. My mechanic gave it a full 2hr exam this morning and came up with the following:
- New Tires ($800)
- New Bump Stops ($200 part + labor)
- Tie Rods DS1438 and ES3427T ($344 P+L)
- Transmission fluid exchange ($160)
- Differential Fluid Change - dope, dextran, silicon ($304 P+L)
- Alignment ($63)
GRAND TOTAL ~ $2000
So I'd have $12k into the truck which isn't bad.
BUT - my mechanic did find "oil in the valley pan" which is apparently a common problem with these vehicles and can come from any number of things but said finding and fixing could cost another $500 - $1000 but it may be just a loose fitting...
Not sure I can find a better specimen for the price and knowing it was taken care of for the first 190k miles is a bit reassuring...I just cannot decide.
1986 Sovereign 25' CB - "Melody"
2001 Ford F-250 Super Duty 4x4 Crew Cab, 7.3L PSD
Air #41001
big_john is offline   Reply With Quote
Old 02-26-2010, 12:01 PM   #2
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Hi,
194k on a tow vehicle or any vehicle is a lot of miles.
I would be concerned that something major would go out on a long trip.
My 2 cents, I would pass on this one and keep on looking.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 02-26-2010, 12:19 PM   #3
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Oil in the valley, likely the high pressure oil pump fitting o-rings leaking. Very commen problem,very easy fix. You need a Ford part number 2C3Z-9G804-AB o-ring kit. Consits of 3 o-ring and a tube of loctite. Takes about an hour too change the o-ring on the pump fittings.
I have 300k on my 7.3, best engine out there in my opinion. Around here 10 grand for that rig would be a good deal. Adios, John
Diesel1 is offline   Reply With Quote
Old 02-26-2010, 12:55 PM   #4
2005 18' Westphalia
Batesville , Arkansas
Don't forget swapping the rear springs to F250 springs and adding a rear sway bar.
RibTickler is offline   Reply With Quote
Old 02-26-2010, 01:01 PM   #5
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Remember SilverWanabe, this is a diesel, It's just getting broken in good at this mileage. Fords Rock !!
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 02-26-2010, 01:29 PM   #6
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
I have two Ford diesels. My older one has the 7.3 and is nearing 300,000. Other than a serpentine belt and a fuel pump this truck has been trouble free and is still the one I find myself driving most of the time. If it has been cared for, I wouldn't be too concerned about the mileage.
GStephens
GStephens is offline   Reply With Quote
Old 02-26-2010, 01:47 PM   #7
Road Ruler's Avatar
Images: 38
Try offering $5,000. and plan on another 5 to get it right.
Old 02-26-2010, 02:03 PM   #8
Bing-Bing's Avatar
1994 34' Excella
Fulltiming , Out West
Althought I have a V10 2000 EX with 100k I havent had any problems pulling a 34' after adding a rear swaybar...Didn't need the heavier rear springs and went with Rancho shocks...A Ford diesel at 190k is still young according to the guys with them I run into...check the Excursion Forum for lots of info....happy trails.
Bing-Bing is offline   Reply With Quote
Old 02-26-2010, 02:12 PM   #9
HowieE's Avatar
Princeton , New Jersey
Images: 12
I added Hellwig sway bars front and rear to get a better level of control.
Some of the prices seam a bit high. The differential, and the trans fluid can be done at home.
2004 Excursion 4x4
Old 02-26-2010, 02:36 PM   #10
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I know a guy with over 600k miles on his Ford 7.3L Excursion. Diesels last a lot longer than gassers if you maintain them properly.
A beefed up Helwig sway bar is a must for the rear axle. I still have the stock sway bar on the front. I tried both Ranchos and Bilsteins on my Excursion and much prefer the Bilsteins. The Ranchos 9000s were too soft even on the max setting.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 02-26-2010, 03:28 PM   #11
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
What kind of fuel mileage can you expect with a 7.3 Excursion...towing and not towing?
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 02-26-2010, 03:44 PM   #12
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Frank
Mileage depends alot on the driver. We have essentially the same thing only in a pu. with 355 rears. We can get 20 not towing and about 16 towing.
If one is gentle with the diesel throttle ,and you let the engine make its torque first and then speed.Not expecting to go from 0 to 60 in 5.4 seconds you can get fuel mileage. We run around town here with ours and get 14 mpg on average in stop and go driving.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 02-26-2010, 04:14 PM   #13
Big John read my response to your other post. I am the original owner of a 2000 Excursion Power Stroke with 178,000 miles. I listed all of my repairs since new. I suggest you check and see if some of my repairs were performed by the present owner of your rig. If not you might budget for them in the future.
What weight are you planning to tow? I tow "light" a 25 Safari about 6000 gvw and don't feel I need sway bar modifications. The stock suspension controls my rig perfectly. I did upgrade to premium "Rancho" type shocks recently and feel the ride is more controlled. Not cushy by any means. The Excursion has leaf springs all around and is not known for its smooth ride.
I don't feel like I am a lead foot but I don't match Mikethefixit's mileage, mine is more like 17-18 solo and 13-11 towing but I do get 14 in stop and go town driving. I did notice about a 5% drop in mileage with ultra low sulphur fuel.
Based on the repairs needed and body damage, I think the price the owner wants for your prospective purchase is a little rich. If you are willing to examine pickup trucks also and also look at Cummins powered Dodges you could find one for 10k in better condition.
If you do go for the Excursion, you will have one of the ultimate tow machines and a great vehicle once you get done fixing it up.
handn is offline   Reply With Quote
Old 02-26-2010, 04:35 PM   #14
Diesel1's Avatar
1967 24' Tradewind
I think most if not all the Excursions came with 3.73 gears. The 7.3 with 3.55 gears went away in the late 90's(percieved lack of power).The 3.55 gearing got better milage. I would expect your milage to mirror Handn's. On my 1995 F350 4x4 with 4.10 gears(and a 7.3) I get 16-17 empty and about 14 towing. But my old trailer is lite and I tow at about 60mph.
At the risk of irritating a lot of folk I think the Ford is much more truck than the Dodge. And the resale values indicate that in my opinion. Adios,John
Ford Excursion (Diesel) Advice big_john Tow Vehicles 20 05-15-2010 10:15 AM
Ford Excursion Diesel tslanier Tow Vehicles 9 07-21-2009 10:20 AM
Diesel Excursion Owners! Bambi_Bandit Tow Vehicles 19 05-23-2006 02:50 PM
2003 excursion 6.0 diesel???? Bing-Bing Tow Vehicles 20 10-02-2005 06:42 PM
