Closed Thread
Old 01-16-2015, 04:01 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Exceeding Rated Payload
So what are the risks of exceeding the payload rating of your truck by two to three hundred pounds?
Hans627 is offline
Old 01-16-2015, 04:05 PM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Been overloaded for years. Can't tell no difference.
I am close to payload all the time. A couple of sticks of firewood and I'm over.
The truck doesn't seem to know or care.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is offline
Old 01-16-2015, 04:23 PM   #3
z , North Carolina
This oughtta bring about some tell tale responses.
Personally, I've never been a fan of pushing vehicles to their limits. I have always heard that manufacturers will have a ten percent rule that you can go over, but coming from a family with three lawyers, that's not going to hold up very well.
Overloading is done all the time, everyday. Each to his own. Not my cup o tea.
It does stress your engine, transmission, frame, tires etc more than what they are designed to handle. There's just no arguing against that.
FishinHatteras is offline
Old 01-16-2015, 05:15 PM   #4
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Why would you want to do that?
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline
Old 01-16-2015, 05:45 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
Hans627,
Just what I would do..
Go to the scales weigh your rig loaded for camping.
Ck the front and rear TV axle weights and compare to the ratings on the driver door jamb sticker.
Do the same for the trailer.
Check the load ratings for your tires. TV & trailer.
Check the hitch receiver ratings.
If your numbers are good...go camping.
ROBERT CROSS is offline
Old 01-16-2015, 05:48 PM   #6
Wayward's Avatar
Cary , North Carolina
No risk. That is why people use trucks - so we do not have to worry about a few hundred pounds here or there. I do not even know what the payload capacity is on my trucks.
I have been using 1/2 and 3/4 ton tucks my whole life for boats and construction. Never considered load calculations unless the rear end is squatting badly or the tires are bugled out.
Step back and take a look at the rig. Common sense goes a long way - and if that is not enough, E load range tires will do the trick.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Wayward is offline
Old 01-16-2015, 06:19 PM   #7
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Me too. If the tires look OK, it's not squating on the springs, and it drives OK, it's OK to go.
We usually put 150,000 to 175,000 miles on our trucks before buying new. Usually, somebody in the plant snaps up the old ones. Many of those go another 100,000 miles for the new owners. Nobody has experienced any problems due to overloading with our used trucks. (Of course, they're all GM trucks.)
terryV is offline
Old 01-16-2015, 06:33 PM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
They have to set some sort of reasonable figure based on serviceability, longevity, safety.
It isn't as though you will turn into a pumpkin if you go one pound over! The more you go over, the more you pays your money and takes your chances!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Wingeezer is offline
Old 01-16-2015, 06:37 PM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
You will just be riding on a fully compressed spring pack (rear springs) with little if any rear suspension travel,so a bumpy and very stiff ride.Your head lamp beams will also be high.Close to 80% of your braking is done with your front brakes and at maximum capacity the weight on the front is reduced reduced due to a maxed out rear load.Kind of like a teeter totter effect.So to sum it up it will ride like a dump truck, take longer to stop with headlights in the trees(exaggeration).
Moflash is offline
Old 01-16-2015, 06:43 PM   #10
And just how did we come to that conclusion? What did I miss?
100, 200, 300, 1000lbs over.
I just love blanket assumptions.
Old 01-16-2015, 08:47 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I don't worry about payload but I do worry about axle and tire ratings, so I weighed my loaded truck and trailer to be sure we were under. We use a well adjusted weight distribution hitch to distribute that load among truck and trailer axles. A truck and trailer with properly adjusted w.d. hitch will drive better at maximum payload than a truck with all the payload in the bed and no trailer.
Doug and Cheryl
dkottum is offline
Old 01-16-2015, 10:18 PM   #12
Moflash's Avatar
It's driving better do to the wheelbarrow effect your WD hitch has created but the weight is still there and is a constant.
It is as if you have filled your truck bed to capacity then jacked up the rear end with a bumper jack and welded the trailer to the truck with articulating braces,then removing the jack.Putting additional stress on the trailers tongue,loading the trailers suspension along with the additional loading of the trucks front suspension.
You are still maxed out but now it is more controllable.This does not mean it's the best way to tow or the safest way to do it.
Moflash is offline
Old 01-16-2015, 10:31 PM   #13
dkottum's Avatar
Thus it is controllable and comfortable, and safe. What's not to like.
Doug and Cheryl
dkottum is offline
Old 01-16-2015, 11:01 PM   #14
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, this could depend on what vehicle you are talking about.
Are you talking about a Falcon Ranchero, a 2013 Ram 1500, or a Kenworth? What is the factory payload rating of the vehicle you are asking about?
Are you planning to be overloaded constantly, for a decade and many thousands of miles, or for a few week end trips. I personally don't like going over the ratings, but some people think it's OK.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline
Closed Thread
15 '' D rated verses 16'' E rated Tires hodges53 Tires 9 07-25-2014 07:16 PM
What do you do with the extra "water" impact on payload? switz Tires 5 12-10-2012 10:37 AM
2010 F150 payload question woof Tow Vehicles 71 10-15-2012 09:48 AM
Enhancing a 1/2 ton pickup's payload? davidmenges Tow Vehicles 21 03-27-2012 08:46 PM
Payload affected by Hitch Weight Tony S Hitches, Couplers & Balls 16 04-14-2011 10:45 AM
