Closed Thread
Old 01-18-2015, 10:17 AM   #29
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
There have been no accidents with light duty trucks on this forum?
It's not about breaking parts it's about control braking and general safety.Just because you can doesn't mean you should.
Moflash is offline
Old 01-18-2015, 10:20 AM   #30
dznf0g's Avatar
Oswego , Illinois
Originally Posted by rgwatkin View Post
Theoretically the risk of overload is bent or broken axles. When is the last time anyone has heard of this happening on a truck. I would bet all the truck manufactures are closer to +25-50% of posted specs. They have to be with dynamic loads. The trick is no matter what your loads are don't hit holes/things at high speeds...just a good rule of thumb!
Dynamic loads are taken into account when the static numbers are set....and your +25 - 50% is high.
-Rich-
dznf0g is offline
Old 01-18-2015, 10:37 AM   #31
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I can attest to Dodge/Ram, the axles are all rated at 3900lbs each. All Dodge Ram's are rated at 6500lbs GVWR, but the axles combined come in at 7800lbs, so that's 1000lbs of safety built in.
If you are running the stock 275/60R20 tire with the Goodyear Wrangler SR-A that Ram install's on it's truck, it has a max load of 2601lbs per tire, for 10404lbs; derated that's 9467lbs rating for the truck when aired to 44PSI per manufactures recommendations.
Folks who talk about damaging the suspension are not car or truck people and are usually talking sideways out their behinds.
Since the OP had a Ram truck and was concerned about 300# pounds, I am putting out there despite the payload police that you are not endanger of dying, or having a run away vehicle that will put everyone on the road at risk. Your axles are not going to break or bend and your tires won't explode. The truck will not be a death trap.
Now, that isn't a license to put a golf cart in the bed plus hook up the Airstream and go drive the Ike Gauntlet.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline
Old 01-18-2015, 10:52 AM   #32
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Exceeding Rated Payload
We could make a short journey around any metro area in the country and find contractors and others who either regularly or constantly have an overloaded half-ton. City streets and the far lying reaches from the highways. With or without trailers.
A vacationer traveling a few thousand miles annually who has otherwise done a good job with the hitch lash up has little reason to be concerned. Watch out for tire loads by using weight scale.
As to liability, that's a joke. The law looks to axle/wheel/tire loads. Commercial users of 1T pickups regularly exceed a 20k GCWR by more than 10k. Legally. And do it over a 300k mile lifetime.
Will a heavy load handle, brake and steer differently? Yes.
Is three hundred pounds over "heavy"? No.
slowmover is offline
Old 01-18-2015, 01:40 PM   #33
Kevin245's Avatar
This thread is closed for clean up.
Eleanor Roosevelt
Kevin245 is offline
Closed Thread
15 '' D rated verses 16'' E rated Tires hodges53 Tires 9 07-25-2014 07:16 PM
What do you do with the extra "water" impact on payload? switz Tires 5 12-10-2012 10:37 AM
2010 F150 payload question woof Tow Vehicles 71 10-15-2012 09:48 AM
Enhancing a 1/2 ton pickup's payload? davidmenges Tow Vehicles 21 03-27-2012 08:46 PM
Payload affected by Hitch Weight Tony S Hitches, Couplers & Balls 16 04-14-2011 10:45 AM
