Old 11-11-2018, 05:26 PM   #1
2019 22' Sport
Malibu , California
Escaping the Malibu fire
New Sport 22 in the driveway and Highlander LTD AWD is tv. We are packed and will leave if fire gets closer but that does not look likely. If we do go it is downhill 3 min to Pacific Coast Highway. Two lanes but about 800 feet of it is 19% grade with hillside on right and deep canyon to left
Never have tried up or down this road and always come a long way around (usually this would be where fire is). My wife said she saw a pick up drive by heading down the steep road with AS. She said thought same as ours. I know the guy and they have F150
Planned getting a Grand Cherokee but now wondering about 150. Is it able to tow my AS down 800 feet of 19%?
Garfish is offline   Reply With Quote
Old 11-11-2018, 05:42 PM   #2
Lily&Me's Avatar
Normal , Illinois
What a horrible, dreadful situation out there in that inferno.
Stay safe.
Maggie
Old 11-11-2018, 06:06 PM   #3
SailorSam205's Avatar
Northville , Michigan
I wouldn't hesitate with my 150. But really, any vehicle should be able to handle 800 feet. Start and stay slow. Put your vehicle in a low gear before you start down.
Good luck and best wishes to avoid the fires.
Al
2017 26' SOB, 2018 F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 11-11-2018, 06:25 PM   #4
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Yep start in low or first gear and manually use trailer brakes as much as needed
We were supposed to camp at pt mugu this weekend but it was inside the mandatory evac area.
Hope you fair well
AlinCal is offline   Reply With Quote
Old 11-11-2018, 06:27 PM   #5
BassCan's Avatar
2014 27' FB Eddie Bauer
Mobile , Alabama
Garfish,
Hope all is well with you and your family and your home and the Sport.
Heard on the nightly news that the city of Malibu has been evacuated.
What a horrible fire.
Wish I could send a little rain your way.
BassCan is offline   Reply With Quote
Old 11-11-2018, 06:28 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Who in the heck built a road with a 19% grade! Isn't that a 38 degree angle down (and up). It would be like towing the trailer down a black diamond ski run.
There are road designs with "switchbacks" to avoid steep grades.
I rode my ATV down what I estimate as a 45 degree angle from a mountain top last summer. No room here for switchbacks. The surface was loose gravel and dirt. I was skidding. If I skidded off the trail, well it would be a long tumble down the mountain. White knuckles.
Maybe your Highlander has a 4wd Low setting (if ). That would help the brakes some. Newer pickups sometimes have a "hill decent" control that helps on steep downhills also.
I would be no faster than 5 mph in the lowest gear possible with 4 way flashers on.
God I hate wildfires. Stay safe.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 11-11-2018, 06:34 PM   #7
2019 22' Sport
Malibu , California
The road was built over landslide that happened in 1984 that took out the access to PCH. Fire in 93 burned all the homes here, 250 or more because fireman would not come down through the fire to save our homes. So after 20 years we got ok to build this road (our cost, 5.5 million) so we could get out in emergencies. The only other way is up where the fires always come from. It is gated and only for homeowners and emergency vehicles. No choice but steep
Old 11-11-2018, 06:52 PM   #8
2017 28' International
Baileys Harbor , Wisconsin
Good that you have an AS. Not sure where everyone else will go. Just put in 4 wheel low if you have it and go slow and steady. Horrible situation.
Daquenzer is offline   Reply With Quote
Old 11-11-2018, 06:59 PM   #9
2013 20' Flying Cloud
Westerly , Rhode Island
It's a bit less than 11 degrees. Pretty steep but 800 ft. should be no problem. Hopefully you won't need to find out! Good luck.
smithcreek is online now   Reply With Quote
Old 11-11-2018, 07:03 PM   #10
2007 22' International CCD
Watching all the fire coverage from Corona, CA area. Do take care. Itís looking really bad on TV news.
The grade, in dry weather should not be a problem. 4WD, low range, and crawl down as slow as possible.
Recovery from this much fire is going to take a very long time...
Old 11-11-2018, 07:10 PM   #11
2015 30' FB FC Bunk
Ayer , Massachusetts
I was a firefighter on the 1993 Malibu Fire, I was on the Bitterroot Hotshot Crew out of Darby, MT. It was on of the most horrific things Iíve ever seen. Every time I see the California fires on the news I remember those times. Will never forget. Good luck to you, stay safe.
Ted S. is offline   Reply With Quote
Old 11-11-2018, 08:03 PM   #12
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Low gear in your tow vehicle and use your brake controller. Pinch the brake controller and use your trailer brakes. UYou have four sets of brakes to stop you or ease you down the grade. 800 feet is not a mountain pass.
Low gear and use the trailer to stop you. It will keep you straight.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 11-11-2018, 08:04 PM   #13
The dry brush around here can burn faster than a person can run. Itís super dry (10% RH or less).
Ted, thank you for coming all that way to help.
So far the woolsey fire is at 83,000 acres and 10% contained. Going to be a long, hard fight.
Old 11-11-2018, 08:04 PM   #14
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
One more thing. Do you have a gopro? I gotta see this!
Escaping kb0zke On The Road... 2 05-26-2016 02:59 PM
ESCAPING the INTERSTATE onto the MOTHER ROAD mountainborn On The Road... 0 09-06-2014 05:08 PM
Recessed oak panels are escaping Jenniflow Cabinets, Counter Tops & Furnishings 5 11-13-2012 09:55 PM
Escaping mud season... Death Valley? March 19-27 Stella On The Road... 1 03-08-2010 11:47 PM
FiRe, FiRe, FIRE, in the AiRsTrEaM!!!! TheBigRedTruck On The Road... 41 12-13-2008 10:29 PM
