Old 09-26-2017, 03:01 PM   #1
DarrellT's Avatar
Longview , Texas
Equalizer hitch really needed on a F-250 Superduty?
Do we realize benefit from our Equalizer setup on a F-250 TV? Have never towed our 26U without it but wonder if we really need it? Of course the dealer sold it as if we needed it
Thoughts?
Darrell
DarrellT is offline   Reply With Quote
Old 09-26-2017, 03:14 PM   #2
Mollysdad's Avatar
I'd vote yes.
You don't need an extra 1000# on the rear hitch.
Old 09-26-2017, 03:41 PM   #3
interstateflyer's Avatar
2017 25' International
Los Osos , California
You might want to read this when you have time.
http://www.trucktrend.com/how-to/exp...-trailer-size/
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 09-26-2017, 04:15 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Simple answer: You need some sort of anti-sway / WD hitch. It does not have to be a specific brand. Some are better than others, do your research.
More complicated answer: Indeed, by the numbers, you could tow with a F-250 without exceeding a weight limit. There's more to it that that. The anti-sway built into the truck does work. By it's self it's not adequate. The WD gets more weight onto the front axle. That helps the ride and improves control.
Have I towed the 30' Classic without WD / anti-sway engaged? Yup, been there done that. I'm still here to talk about it. It's the "Uncle Bob Recommended" approach for maneuvering in and out of a campsite. Running down the interstate at who knows what speeds with the trailer loaded who knows how .... not so much. I'm crazy, but not *that* crazy
Old 09-26-2017, 05:34 PM   #5
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Yes you need it. Distribution of trailer weight is what it's all about not just looking level as you head down the Interstate!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 09-26-2017, 05:39 PM   #6
2012 19' International
Southeastern MI , Michigan
A lot smoother ride with less bounce and porpoising. But would tow OK without it too.
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is offline   Reply With Quote
Old 09-26-2017, 05:51 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We tow our 2015 25FB with our Silverado Duramax 3500. We always use a weight distribution/anti sway hitch. We wouldn't be without it.
Brian
SuEllyn & Brian McCabe
Old 09-27-2017, 10:27 AM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Not so much for weight distribution as sway control.
Yes.
Needed.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-27-2017, 10:46 AM   #9
1973 Vintage Motovator
Outbackga's Avatar
Dahlonega, GA & Maggie Valley NC , Georgia
YES,
Agree with others. Have you ever seen a trailer on it’s side with the tow vehicle upright? I have. Mine. Sway is the issue, not the TV. I had an Equal-i-zer hitch properly set up also. Cannot endorse any brand but I will use a Hensley or ProPride next time.
Dave
Outbackga is offline   Reply With Quote
Old 09-27-2017, 10:50 AM   #10
demijac
2014 27' FB Classic
Livingston , Texas
Send a message via Skype™ to demijac
Don't Even Think About It
For your protection and others as well, don't take shortcuts on sway control. Doesn't matter which brand as long as you are going with one of the market leaders. Anecdotally, we've had zero issues with our Equalizer and for us, we decided it was the best bang for the buck.
demijac is offline   Reply With Quote
Old 09-27-2017, 11:00 AM   #11
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I'm only one year into my Airstream adventure so I defer to the wisdom of those more experienced. I will offer my opinion and it is this, as one who's TV is a 2005 F250 diesel towing a 2017 28' Serenity International, I would not go down the road without a WD/Anti-sway hitch. I happen to have an Equal-i-zer hitch, mostly because that is what my dealer recommended. I have had great results - no sway, no movement from large trucks or buses blowing by me at 80 mph (I'm at 60) and most recently no movement in 20-25 mph cross winds. The WD also has been helpful to balance my axle loading (check it on a CAT scale) which makes my towing a lot more enjoyable. I do remove the bars when moving in and out of a camp site or my curved driveway. This is entirely due to the fact that many times when I have the AS level my TV is not which puts more pressure on one set of bars making it difficult to remove them. You can level the truck if you want to leave them on but that is extra hassle that is not needed IMHO if you remove the bars before hand.
VaTravelers is offline   Reply With Quote
Old 09-27-2017, 11:13 AM   #12
Anna Maria , Florida
Thoughts?
Darrell
Last December we upgraded from an F-150 to a F-250 Diesel. Initially I experimented with towing a 30' International and later our new 30' Classic with and without WD. As has been sated by others you do need the WD period. In my situation it distributed 450 lbs to the trailer axle and the front axle of the truck making for a very stable drive. Without WD I had to raise the hitch ball to get the trailer to ride level and I didn't have much road feel from the steer axle. Which gave me concern about being able to correct for any sway issues.
With your trailer being lighter it may be doable however since you do have the hitch you might as well put it to good use for an extra margin of safety. What are you saving, ten minutes at most.
franklyfrank is offline   Reply With Quote
Old 09-27-2017, 11:37 AM   #13
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Yes...insurance
You may consider it insurance; don't need it till you need it! In an earlier post from one of our commercial experts, Andy at CanamRV, I believe, best answer was given (with my interpretation): Think of it like airbags and seat belts in your car...seatbelt may work fine, but when you need the airbag in a sudden crash, you'll be glad you had it also to help.
Like Uncle Bob, I suspect many of us have pulled our AS's with our TV's and no WDH for short segments with no issues around campgrounds, or down the road to dump. I would not take my rig on the highway, however, without the WDH on my F250. Why take a chance with your investment or your lives?
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 09-27-2017, 12:19 PM   #14
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
If you have an AS and hang out on this board then absolutely, positively you need wd and sway control or you will surely die and your children be tossed away like leaves on a stormy sea.
If you are one of the millions of people who have SOBs, cargo, van, equipment or utility trailers and tow them billions of miles a year then you don't need those expensive add ons.
Ultradog is offline   Reply With Quote
250 meets 250 meets 250... "made for Germany" in Germany split window Classic Motorhomes 27 11-29-2016 12:44 PM
Any TV off road type tires? 2016 F-250. 250 vs 350? 6.7 Diesel or 6.2 Gas? Need help! Danattherock Tow Vehicles 53 07-19-2015 02:21 AM
250 MH :: 1990 Airstream 250 barend Airstream Registry Discussions 0 08-19-2011 09:32 AM
Really, Really, Really Hot swebster Airstream Motorhome Forums 8 11-16-2003 09:46 PM
