Old 11-05-2014, 10:03 AM   #1
Des Moines , Iowa
Enough Truck
I'm looking at a '98 Chevy Silverado with a 5.7L gas engine and a tow package. I have a 28' Land Yacht circa 1978. Being new to RV'ing and tow vehicles, I welcome feedback as to whether this will be a comfortable tow.
Shep
OldShepster is offline   Reply With Quote
Old 11-05-2014, 10:31 AM   #2
1984 31' Sovereign
Stockbridge , Georgia
Shep the truck itself will be fine, if not a little underpowered. It needs to have trailer brakes. Lots of Airstreams are towed with SBCs just don't be in a hurry.
Mike
1984 Sovereign 31
2002 Chevrolet Silverado 2500HD
slantflat is offline   Reply With Quote
Old 11-05-2014, 10:48 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Your biggest issue will be the hitch weight on your tow vehicle which counts towards your maximum payload that the tow vehicle can carry. Fortunately for you, older Airstreams have quite a bit lower hitch weights than do the newer ones. Still, if your trailer has a hitch weight of 600 lbs., for example, and your tow vehicle has payload capacity of 1,000 lbs., you are left with 400 lbs. for passengers and cargo in the tow vehicle. You'll probably need to do a bit of research to get the hitch weight of your trailer (check the Airstream web site) and the payload capacity of your tow vehicle.
And make sure to use a properly set up weight distributing/anti sway hitch. If you are not familiar with this, use the search function to find one of the many (too many!) threads on this subject. Most local hitch dealers in your area can get you set up. 99.99% of Airstream owners use such a hitch. The other .001% are taking a big chance.
Enjoy the road!
Bob Martel
WBCCI# 5766
Old 11-05-2014, 11:51 AM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The short story is to return the front axle weight when hitched to what it was when solo. FALR. Front axle load Restoration
Old 11-05-2014, 07:14 PM   #5
Des Moines , Iowa
Thanks to everyone for their responses!
Shep
Old 11-05-2014, 08:15 PM   #6
Wayward's Avatar
Cary , North Carolina
Plenty 'nuf truck.
I tow a heavier Airstream than that with a 2000 4.2L pickup.
Tow for a while and see how it goes. I would focus on the drivetrain.....
- 3.73 or 4.10 gears in the differential will take a load off the tranny and make for a more comfortable tow.
- Service the tranny and replace fluid with High Temp Redline synthetic. Make sure the torque fluid is drained too. Add a tranny temp gauge.
- D or E range tires eventually.
- Coolant flush and add Water Wetter to new coolant.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-05-2014, 09:30 PM   #7
Des Moines , Iowa
Thanks for the advice. The specifics are great!
Shep
Old 11-06-2014, 07:59 AM   #8
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
It looks like a 78 has these figures, depending on configuration:
1978 AMBASSADOR 28 TWIN 4630 550 19.5
1978 AMBASSADOR 28 DOUBLE 4690 575 19.5
So the dry weight is in the 4630-4690 range, and the tongue weight in the 550-575 range. Figure your truck requirements from there.
Lynn
WBCCI 21043
Old 11-06-2014, 01:15 PM   #9
Des Moines , Iowa
Dang...this is about the most helpful forum ever!!!
Thanks everyone,
Shep
Old 11-06-2014, 01:24 PM   #10
r carl's Avatar
Lin , Ne
Shep
Is it a 1/2 or 3/4 ton?
Old 11-06-2014, 02:49 PM   #11
Des Moines , Iowa
3/4 ton. I also stumbled on a 1983 Chevy one ton diesel dually with only 165K for mileage. Looks to be in great shape (no rust, clean interior). They are the same price. Those are the best two in my neck of the woods that are under my wife's budget for me :-)
Shep
Old 11-06-2014, 03:38 PM   #12
1994 34' Excella
Warren , Manitoba
You will have no problem with the 3/4 ton. I would stay away from the '80's diesel, as it is the 6.2L, which has very little torque or horse power. Had a friend that pulled a 1983 31' with that diesel. Even a slight hill on the prairies and he was down to 40 mph in second gear. Get a good hitch, brake controler, and you will be ready to hit the road.
CBWELL is offline   Reply With Quote
Old 11-06-2014, 03:42 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The 3/4 ton will be perfect. No worries. The 1 ton dually will work if you need it for some other purpose too, but my preference by far would be the newer 3/4 ton.
Tundra 5.7 Enough Truck for 27 ft Airstream? Phoebe2009 Towing, Tow Vehicles & Hitches 129 08-24-2013 07:58 PM
Do you have enough truck ? tailpipe Tow Vehicles 7 03-04-2013 08:07 AM
Is this F350 enough truck? Aluminumb Tow Vehicles 15 09-28-2007 01:37 PM
Insurance - When is enough enough Pop Rivet Insurance & Claims 6 06-27-2007 07:29 PM
2000 F150 -- Enough truck? Kinder Tow Vehicles 6 01-20-2006 03:55 PM
